2014 radio into 2013
Discussion in 'Audio & Video' started by TxStVanWilder, Apr 4, 2016.
  1. Apr 4, 2016 at 4:35 PM
    TxStVanWilder
    TxStVanWilder [OP] The Pale Horse
    Tx
    2013 TRD Sport
    Ok so I have a 2013 DCLB TRD Sport. I bought it used and it came with the regular stock touch screen. I have found a local seller on CL that has a 2014 with XM/HD radio. Mine has no XM and I have no clue what entune is so doubt i have that either. I tried to do reading before posting this but I'm not well versed at all in Toyota products (I've had a GM since I was 15).
    The seller has a unit with a number of 57090 at the bottom corner, I hope this helps anyone with identifying it. My unit has no markings or numbers that I saw. I just want to make sure the swap will work and what might be needed to make it function properly.
    I have included 2 pictures of the sellers item and one picture of my head unit now. Any info or insight you audio gurus could help me with would be wonderfully appreciated.
  2. Apr 4, 2016 at 8:39 PM
    DunkinDal
    DunkinDal Active Member
    South of Boston
    2015 TRD Off Road
    I did the same swap and can tell you what you will run into.
    1. If you dont have the bezel from 2014 you will need that
    2. If you want entune "Weather and traffic on this model" you need a nav antenna heres a link put it behind radio in gap in the ducts http://www.ebay.com/itm/2004-2009-T...ash=item3d152bf5e2:g:vPoAAOSwxvxW8bES&vxp=mtr
    3. if you want the xm buy this xm antenna it will work http://www.amazon.com/gp/product/B0009J6PYW?psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s00
    4. if you want backup camera on radio search for it here lots of post on moving from the mirror to radio
    and take a look at this post https://www.tacomaworld.com/threads/mod-day-4-installing-2014-oem-radio-into-2013-pictures.310362/
    rest will just plug right in.... hope this helps
  3. Apr 5, 2016 at 4:59 AM
    TxStVanWilder
    Tx
    2013 TRD Sport
    That's perfect. It does come with a bezel and I'm pretty sure it has the XM antenna. But that's all perfect information I appreciate it!
    I was going to go with the iPad in the dash but with the overheating and lack of parts now I figured I would just upgrade my radio this way.
  4. Apr 6, 2016 at 9:02 PM
    TxStVanWilder
    Tx
    2013 TRD Sport
    @DunkinDal PM sent with GPS antenna question.
