2014 : Remove Switch from Dash .. .. ..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoLarry, Mar 24, 2014.
  1. Jun 29, 2017 at 2:35 PM
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR/W-UpGrade Package.
    My ditch lights.
  2. Jul 3, 2017 at 6:57 PM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Is there room to work behind the blank w/ the screw in it? The blanks on my left side are all full...
    lpfe42 likes this.
  3. Oct 14, 2017 at 2:33 AM
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    You can access the bottom three by popping out the coin tray. Top three, you will have to remove that part of the dash. They won't come out from the front without depressing the tabs. The above link is no good.
  4. Oct 14, 2017 at 2:56 AM
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    Dash removal isn’t needed for the upper three,
    Just go under your dash with an 18” or longer screwdriver/tool and a flashlight, look up in there and you can see the back of the blanks, insert tool and push a tad, get one out then you can carefully reach in with your fingers and pop the others if needed.
    If done it that way on all three 2nd Gens I’ve had to add the factory fog light switch.
  5. Oct 14, 2017 at 3:43 AM
    cabo wabo
    cabo wabo Well-Known Member
    billy
    virginia
    2019 dbc short bed trd sport
    Used a small trim panel tool to remove the small blanks when I installed the switch for daytime running lights and a voltmeter.
  6. Oct 18, 2017 at 10:13 AM
    presta24
    presta24 Well-Known Member
    chris
    Cincinnati
    2014 Taco TRD 6spd, 2k3 SR5 4runner V8
    Scratches, dents, lots of squeaks.
    How did you run the wiring up there? I have it in the cab but haven't run it behind the panel yet. I am using that exact location for ditch lights.
  7. Oct 18, 2017 at 10:19 AM
    Soul Surfer
    Jimi
    I ran a clothes hanger up behind the drivers side of the console near the gas peddle, and pulled the wires down then ran them to the fuse box.
  8. Nov 26, 2017 at 6:03 AM
    RandySavage
    RandySavage Well-Known Member
    Rob
    Cape Breton Island, Canada
    2010 Tacoma TRD OR MT
    Never Satisfied
    Im looking to rewire my rear diff with the factory button, the button is on the top 3 and cant just be popped out with a screwdriver. How do you take apart the upper left dash panel?
  9. Apr 10, 2018 at 10:25 AM
    energygeek
    energygeek WassawBound
    Santa Clara, CA
    2015 Tacoma TRD Offroad
    Current Setup: Tire: 33" KO2 Wheels: SCS Front: Bilstien 6112 Rear: Bilstien 5100 & OME Leafs Storage: Decked and SnugTop Brakes: Extended Stainless Lines Roof Rack: Prinsu Towing: Tacoma Tow Package with REDAC brake controller Kayak Bunks: 3" PVC. :) Sleep Setup: In shell or on roof with Plywood and Big Agnes Fly Creek II Cooler: RTIC 65 Liter Future Mods: Winch: MileMaker 12000, install in progress. Bumpers: Any Suggestions? Dual Battery: Roof Top Tent: FSR Power Management: SPOD Brake Upgrade: 4 Runner Conversion Needs Fixing: Wheel Wells Broken Sway Bar bolt
  10. Jun 30, 2018 at 6:03 PM
    DWrekTacos
    DWrekTacos Member
    Derek
    2014 Mag Gray TRD O/R
    5100's, OMU Dakar, CamperShell
    Does anybody know of a part number for the center console blank covers?
  11. May 5, 2019 at 9:52 AM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Lower panel is easy to work with, upper panel is damn near impossible. Sorry to bring up an old tread. But I’m working on it now and although the lower panel has push retaining clips on both sides, the left side seems to not want to come out.
