2014 RWD Access cab mods
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tox897, Sep 7, 2020.
  1. Sep 7, 2020 at 8:40 AM
    Tox897
    Tox897 [OP] Member
    2014 tacoma
    Hey all,
    So I'm looking to make some changes to my stock tacoma. I'm over seas right now so I'm not around my truck but im trying to get an idea of what im looking to do to it will work.
    I plan on getting this lift
    Lift kit:
    https://www.bilsteinlifts.com/shop/...-75-lift-kit-for-a-2005-2016-2wd-5lug-tacoma/
    And to put on 265-75r16 tires with a 16×8 wheel. I'm not too well versed with making truck mods so I'm asking for a bit of help and to see if there may be any issues with this.
    I heard on a stock tacoma 265-75r16 will fit with no rubbing but I saw the link they recommend a 245-75-16r
    Would 265 be too big?
  2. Sep 7, 2020 at 9:03 AM
    Tox897
    Tox897 [OP] Member
    2014 tacoma
    Oh nice, thanks for the pointer, I guess I'll go with the size that's on the website though. Would there be anything else I'd need for the lift? Like new shocks or anything?
  3. Sep 7, 2020 at 9:07 AM
    Bishop84
    Bishop84 Well-Known Member
    That lift will work but it will ride rough, do you have original suspension still?
    If you have oem shocks, just change them in the front with a
    You shouldnt bolt spacers to old shocks, and you're removing them anyway, so change them
    I'd recommend the 4600's all four corners. It will ride much better.
    whatstcp likes this.
  4. Sep 7, 2020 at 9:14 AM
    Tox897
    Tox897 [OP] Member
    2014 tacoma
    Yeah i still have stock suspension, so 4600's are those blinstein shocks? I'm not worried much about the budget since I'm coming back from a deployment and have that little extra money to spend rn haha. So I'm a bit of a tard. So replace old shocks with new ones would be recommended for getting that type of lift? Also cut out the black box and would 31×10.5R15 be straight with it?
  5. Sep 7, 2020 at 9:18 AM
    Tox897
    Tox897 [OP] Member
    2014 tacoma
    I looked at the recommended size from the lifts site which says 245-75r16 is the size to go with and 31×10.5r15 is about the same size I'm just sick of the stock truck looking like a pool guys work truck and im trying to make it look a bit better without it skipping on leg dag
  6. Sep 7, 2020 at 9:18 AM
    Bishop84
    I don't have a ton of experience with 5 lugs, they are suuuuuuuuper rare in Canada. But when I searched for 5 lug lift, the 4600 bilstiens kept popping up, they will handle the spacer lift better and the longer travel of the rear leaf.
    4600's are the holy grail of replacement shocks, they are direct oem replacements but behave much better, very closely related to the 5100's which arent available to your truck unfortunately.
    Most people lower 5 lugs not lift haha.
    Tox897[QUOTED][OP] likes this.
  7. Sep 7, 2020 at 9:23 AM
    Tox897
    Tox897 [OP] Member
    2014 tacoma
    Yeah i hear you on that, its a bit difficult since everything is for 6lug trucks. Thanks for the help!
