2014 Sport - sudden loss of steering control
Discussion in '2nd Gen. Tacomas (2005-2015)' started by whomung, Jul 11, 2020.
  1. Jul 12, 2020 at 5:48 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Check the obvious. Power steering fluid level. Power steering pump. Steering rack. I had an intermittent loss of PS issue with a Ford. Cost $3k for a new steering rack.
  2. Jul 12, 2020 at 6:58 AM
    Taco Wake
    Taco Wake Well-Known Member
    South Carolina
    Considering a VSC recalibration requires no parts and very little time, it is the first thing I would try. You can always load up the parts cannon later if the recalibration doesn't help.
    whomung[OP] likes this.
  3. Jul 12, 2020 at 6:10 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    there have been actual cases whereby investigation by law enforcement
    by insurance after a serious accident modifications by NON certifed mechanics
    have resulted in negative residual results
    ( both will obtain access at dealer......... wrecker or impound yard )
    notably with brake systems
    more notably with air bags
    jakd up too high................laws already on the books when bumpers dont meet
    driving after an air bag activation repair by a non certified mech after activation
    ANY Dealer doing the above.........there are shops in this area that will NOT touch
    owner modifications
    not my opinion
    actually loosely enforced ................... mores when accidents are serious
    or the Accident Team is called out ON Scene !!!
    just sayin
  4. Jul 12, 2020 at 7:25 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    What does this have to do with recalibrating VSC?
    TnShooter likes this.
  5. Jul 12, 2020 at 7:33 PM
    ROAD DOG
    FEW
    i was replyin to a differnt response
    im thinkin i wont hear ' grinding noises ' unless its something mechanical
    some seem to think its routine is the ' VSC ' needs to be recalibrated ( i would assume by dealer )
    no less arbitrary if the truck is lifted......... sometime yes sometimes no
    while that may be possible
    i dont think so
    no less i mentioned how from the symptons mentioned b4
    in my neck o the woods
    ONLY certified Techs can work on certain systems
    many in my area adhere to the matter
    in that if a serious accident occurs ................its considered
    it can have repercussions
    U dont have to agree
  6. Jul 12, 2020 at 7:51 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Absolutely nothing.
    Just saying...
    Muddinfun and TnShooter like this.
  7. Jul 13, 2020 at 11:34 AM
    whomung
    whomung [OP] Member
    2014 Tacoma TRD Sport 4x
    Process update:
    Just spoke with the guy in the shop... He drove the truck for about an hour over the weekend... Was able to make the symptom happen once... His initial diagnosis was that the the ABS was coming on for a second... With the lift, larger tires and rims with an offset, he felt the computer was thinking I was on ice and in a skid...
    He heard the "low grinding noise" I mentioned and felt it wasn't mechanical. In his opinion, it was the ABS doing rapid pumping... He mentioned driving the truck for a week or so with the ABS turned off to see if that was it before pouring a ton of money into the repair.
    I told him about this thread and sent him the link to it, as well as the "reset your VSC" for his review... But sounds like his initial diagnosis and the groups were pretty similar.
    jimmyh...I think that you and mechanic are right about the "grinding sound" - that its the ABS pumping, not mechanical... In retrospect, that sounds correct..
    RoadDog... you make a very good point about Toyota certified mechanics and liability... Failure on this could be beyond personally horrible for myself or others... It could involve serious finances as well... Thanks
    StickyTaco... Thanks for pointing out the VSC issue and the link... Which also led me to the "turn off the ABS" thread
    Really appreciate all the support from the group... This was my first post here, and you guys were most helpful... probably saved me a ton of time, money and certainly anxiety - particularly if I taken the truck to the shop that did the lift. Your advice also gave me a lot of confidence in my mechanics diagnosis, and gave him further info regarding the fix.
    Very nice.
    I'll post again in a few days to report if the problem was solved, but seems hopeful right now
    Thanks
  8. Jul 13, 2020 at 11:49 AM
    Muddinfun
    Muddinfun Well-Known Member
    If you read up on VSC and understand what it does, you will get a better understanding of why it's causing the symptoms you have and why recalibrating it will fix the problem. In the time it took you to write that post, you could have fixed your truck. Instead, you chose to take the advice of a idiot mechanic and disable safety features.
    Thuguon2.7, Jimmyh and Too Stroked like this.
  9. Jul 13, 2020 at 11:52 AM
    whomung
    whomung [OP] Member
    Haven't disabled anything yet, trucks not in my possession... But Definitely going to re calibrate the VSC
    Jimmyh likes this.
  10. Jul 13, 2020 at 5:00 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Thanks for the feedback. Keep us up to date.
    A quick VSC Calibration will make you happy. I am suprised that the "mechanic" didn't just go ahead and do it.
    Muddinfun likes this.
  11. Jul 13, 2020 at 5:03 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    as long as we're guessing>steering shaft loose or disconnected
  12. Jul 13, 2020 at 5:07 PM
    BillsSR5
    bill
    2014 SR5
  13. Jul 13, 2020 at 5:34 PM
    whomung
    whomung [OP] Member
    Just got the truck back... Mechanic did the VSC calibration recommended... His own diagnostic this morning led him to the ABS... When I sent him a link to the VSC thread, he was like "OF COURSE -- THAT'S *IT*" - made complete sense to him.
    So truck is re-calibrated... I feel a whole lot better... He charged me $50, and thanked me for showing him the link and this site... I'll road test the truck locally tonight, and take it up and down canyon tomorrow... about 180 mile round trip... That should confirm it.
    Thanks to all
  14. Jul 13, 2020 at 7:34 PM
    ROAD DOG
    FEW
    sounds like U have found a good decent mechanic
    its not about me being right .....................no matter what
    i hope you get it corrected & be safe
    good luck
  15. Jul 13, 2020 at 10:28 PM
    #35
    Jimmyh
    SC
    2012 Prerunner SR5
    Thanks for the update.
    I do feel it should have been free.... Whatever.
  16. Jul 13, 2020 at 10:58 PM
    #36
    Muddinfun
    You’re too kind. The mechanic should have paid whomung $50 for a valuable lesson since he now has the knowledge to charge future customers $50 for a 5 minute service. The mechanic should also pay everyone in this thread that suggested VSC calibration, an additional $20.
    Jimmyh[QUOTED] and whomung[OP] like this.
  17. Jul 14, 2020 at 2:15 PM
    #37
    whomung
    whomung [OP] Member
    Well... I just drove 80 miles down canyon... and it happened again... only once, as opposed to three times last week.. but same loss of control and abs pumping for about 1.5 seconds on a sweeping right turn doing 50 mph... kinda bummed... and I still got to go back home
  18. Jul 14, 2020 at 2:18 PM
    #38
    whomung
    whomung [OP] Member
    I almost thought he was going to pay me... and all of you... but looks like fix didn’t quite do it...
  19. Jul 14, 2020 at 2:41 PM
    #39
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    this is the oddest problem on the forum. good luck. i have nothing.
  20. Jul 14, 2020 at 2:45 PM
    #40
    Muddinfun
    If it only does it on sweeping right turns, and not sweeping left turns, I’m gonna guess the calibration still isn’t right. It would be something if he charged you $50 and didn’t do it right.
    Jimmyh and TnShooter like this.
