2014 Sport - sudden loss of steering control
Discussion in '2nd Gen. Tacomas (2005-2015)' started by whomung, Jul 11, 2020.
  1. Jul 11, 2020 at 1:36 PM
    whomung
    whomung [OP] Member
    2014 Tacoma TRD Sport 4x
    Hi...
    I have 2014 Sport, lifted 2". 60K miles on the Truck, approx 10K miles on the lift.
    In the last two weeks, the steering has cut out seven (7) times...so far, it happens when making right turns on sweeping curves, traveling around 50 miles an hour. There is a clear and sudden loss of control, and a lurch to the outside of the curve by a foot or so.. Accompanied by a low grinding sound.
    The loss of steering lasts about one (1) second, maybe two and then steering control is regained. This is scary as hell... I live in a very mountainous area, daily commute through steep, rugged canyons on two lane roads with many logging trucks. Sudden lurches on the outside of a curve could be catastrophic.
    Searched for similar issue in the boards here, didn't find one. Any help would be appreciated
    Thanks,
    whomung
  2. Jul 11, 2020 at 1:42 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  3. Jul 11, 2020 at 1:43 PM
    whomung
    whomung [OP] Member
    yes, 2" frame lift... thanks for the link..
  4. Jul 11, 2020 at 1:57 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Body lift?
    It is somewhat common to have to recalibrate the stability control after suspension lifts but not sure about body lifts.
  5. Jul 11, 2020 at 1:58 PM
    Muddinfun
    Muddinfun Well-Known Member
    VSC needs to be calibrated. The VSC thinks you’re starting to drift and it attempts to “help” you.
    TRDSport10, Jimmyh, TnShooter and 2 others like this.
  6. Jul 11, 2020 at 2:07 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    no doubt its apparent the issue is the steering system
    reservoir / capacity
    pump
    steering rack
    lines getting pinched or air in the system
    put on jack stands have someone steer side to side whileU stand up front
    LOOK & LISTEN ............
    thats what they will do initially when U take it in
    good luck
    whomung[QUOTED][OP] likes this.
  7. Jul 11, 2020 at 4:14 PM
    whomung
    whomung [OP] Member
    Will
    Yes... Thought this might be issue, since it's intermittent, but always happens at speed.
    Thanks... good diagnostic procedure.
    Was talking with local mechanic... He knows of two other taco's lifted by same shop that had the identical issue over the last few years... He lost track of one, so doesn't know resoluti0n... The second taco owner went back to same shop, spent THOUSANDS over several months, never got it fixed, so sold it... Have no idea if the steering issue was disclosed or not, but the shop failed to resolve it.
    Could something funky happen during the process of installing the lift? Is this where lines might get pinched? Rack or bushings damaged? VSC thrown off?
    This doesn't appear to be too common... Hoping for a reasonable fix
    Thanks to all
  8. Jul 11, 2020 at 4:27 PM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    If it's intermittent it's most likely related to stability control (VSC) as stated above. It's common after a lift. Search recalibrate VSC in the 2nd gen forum and try that before paying anyone to diagnose.
    TRDSport10 and Muddinfun like this.
  9. Jul 11, 2020 at 4:43 PM
    whomung
    whomung [OP] Member
    How to reset and calibrate your VSC computer - The Easy way
    Awesome thread... reading through the posts, this sounds like the problem and solution ... Thanks very much. I'll report the outcome.
    https://www.tacomaworld.com/threads...ibrate-your-vsc-computer-the-easy-way.467485/
    stickyTaco[QUOTED] likes this.
  10. Jul 11, 2020 at 6:47 PM
    ROAD DOG
    FEW
    sounds like the shop that has done 3
    is stepping in the same dog pile each time..........
    hope the VSC recalibrate will help
    id be condition orange until i knew it was
    good luck
  11. Jul 11, 2020 at 7:05 PM
    whomung
    whomung [OP] Member
    Definitely not taking the truck back to same shop... agree about condition orange... going to be pretty cautious..
    But the VSC thread really sounded promising... Read all the way through it... Including possibility of ABS / VSC sensor wire pinched... All the way to pulling the fuses.. Don't know if this is it, given it just showed up after 10K miles on the lift,but the symptoms sound the same... definitely feels like the right place to start looking...
    Thanks again.
  12. Jul 11, 2020 at 7:17 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Have you checked your steering shaft where it connects to the end down by the engine?
    It sounds like a traction control problem but make sure it's not mechanical.
  13. Jul 11, 2020 at 7:22 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I highly doubt any of that is an issue. He lifted the truck and now the VSC needs to be recalibrated for zero to compensate for the lift.
  14. Jul 11, 2020 at 7:26 PM
    whomung
    whomung [OP] Member
    Given it's intermittent, I think I should look at everything... Sounds like VSC, but probably smart not to take that for granted
  15. Jul 11, 2020 at 9:08 PM
    ROAD DOG
    FEW
    ' grinding noises ' .............................
    VSC not calibrated = grinding noise
    i hope orig poster remains safe & his Taco gets repaired
    iv read countless post on ' lifts '
    not once have i read its a requirement to recalibrate VSC
    i have seen that it is a backup 10 yards & punt matter
    be certain to get an explanation & a written receipt
    good luck
    whomung[OP] likes this.
  16. Jul 11, 2020 at 11:00 PM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    VSC acting up doesn't impact all lifted trucks but it is a known issue. I'd guess the 'grinding' noise is the abs kicking in which is part of the VSC.
    The shop likely hasn't figured it out with the previous trucks they've worked on because they are looking for a mechanical issue.
    Jimmyh and whomung[OP] like this.
  17. Jul 11, 2020 at 11:23 PM
    ROAD DOG
    FEW
    if my ' abs ' activates
    goin or comin i hope i dont hear ' grinding ' ........................
    while there are possibilities software........computer.......... servo or mechanical
    i hope he comes out proper & correct
    whatever shop/ mechanic thats gets it right
    be certain to get a written explanation/ receipt................... now i will take a minute
    while it hasnt happened to me directly............... i know for a fact the following
    some modifications in this neck of the woods in the event of an accident
    all but voids the insurance policy
    sometimes its good to be aware...informed ....correct
    on inspection after an accident ( serious injuries/ death )
    certain systems ( ECMs.....ABS....GPS......AIR BAGS .......VSC.......Cameras )
    can be accessed by state troopers by either or both insurance companies
    in my county those HI LIFTS are illegal......Bumper Heights dont match
    youngster less than 21ended up on top of a full sized Pontiac resulting in fatalities
    if the mods are made & not Certified................ opens a can o Worms !!!
  18. Jul 11, 2020 at 11:44 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    The VSC uses the ABS System to control the brakes independently as in Vehicle Stability Control. The grinding noise is the ABS Pump and the very rapid actuation of the valving system cycling on and off. There is also a buzzer in the cab.
    https://parts.olathetoyota.com/vehicle-stability-control
    TRDSport10 and stickyTaco like this.
  19. Jul 11, 2020 at 11:53 PM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    @ROAD DOG, not sure how recalibrating would void a warranty or expose him to insurance liability. He's not overriding it.
    it's no different than recalibrating the compass except if he doesn't do it it could lead to an accident instead of a wrong turn.
  20. Jul 12, 2020 at 5:41 AM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    It's been said already but I believe it's the VSC. my truck did the same,would yank me into oncoming traffic,scarie crap. When I pulled the ABS#2 fuse problem went away. My issue was the type of tire I was running with my lift. New tires fuse back in all is ok.
