2014 Tacoma back up camera!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by McCurry3, Jun 6, 2021.
  1. Jun 6, 2021 at 9:23 AM
    McCurry3
    McCurry3 [OP] New Member
    Matthew
    2014 Toyota Tacoma 4 door black
    None yet
    New to the group. I recently bought a 2014 Tacoma base model. It didn’t come with a back up camera. But a friend of mine gave me one off his 2014 before he traded it in. The wiring is in the tailgate. But I plug it in and get nothing. Someone said check the yellow audio/video plug in the back of the factory radio. I did that today and there is not one there. And there is no place for a audio/video plug in the radio. There is a open space for a plug but not the audio/video. Can anyone give me any insight as what I need to do?
  2. Jun 6, 2021 at 1:37 PM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    2019 T4R TRD OR
    Sold my 2015 Taco to get the 4runner
    My '15 base 4cyl Taco didn't have a camera, but I had success with buying the cheapest one on Amazon, plugged it in and had an image. Any chance the the camera you were given is broken? There is a good write up buried somewhere within this forum that shows how to install one in a Taco that was never wired for one, but it seemed that the general consensus was that all of the "late" 2nd Gen Tacos were prewired.
    McCurry3[OP] and elioregon like this.
  3. Jun 6, 2021 at 4:30 PM
    Joeyourbro
    Joeyourbro Well-Known Member
    Joe
    Vegas
    2015 2.7 5MT
    Yup I did the same thing it was like $50 and plugged right in. I’m assuming if OPs wiring is there up to the tailgate it’s an issue with the camera
    McCurry3[OP] likes this.
  4. Jun 6, 2021 at 4:37 PM
    Clearwater Bill
    Billy
    Largo Florida
    I'm not sure all headunits are capable of display.
    Hopefully someone will be able to chime in on that
  5. Jun 6, 2021 at 9:11 PM
    McCurry3
    Matthew
    None yet
    Thanks for your guys info. It goes in the morning to have the remote start wired in so I’m gonna have the tech check it out and see what I need to do. The camera may have went bad or something. But everything I’m reading is saying about the yellow audio/video plug and I don’t see it anywhere’s on mine.
  6. Jun 6, 2021 at 10:59 PM
    TacoTuesday831
    TacoTuesday831 Well-Known Member
    2014 Tacoma 2.7
    Do you have a link or the name of the one you got? I’m looking to get one too. Thanks
  7. Jun 7, 2021 at 7:38 AM
    Joeyourbro
    Joe
    Vegas
    2015 2.7 5MT
  8. Jun 7, 2021 at 8:23 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2004 Limited 4Runner 4.7L
    I have a 2014 base model non-JBL non-NAV head unit. I also added a backup camera. I ordered a OEM Toyota camera off eBay. It plugged right in and worked like a charm without any other modifications. I wonder if your camera is busted.
  9. Jun 7, 2021 at 9:46 AM
    TacoTuesday831
    2014 Tacoma 2.7
  10. Jun 7, 2021 at 12:40 PM
    Joeyourbro
    Joe
    Vegas
    2015 2.7 5MT
    No need to be sorry. The pigtail harness in your tailgate will just plug into this camera once you put it in place IIRC. Throw the truck in reverse before you button it all up to test it there you have it. Good luck
  11. Jun 8, 2021 at 2:40 PM
    snacsnoc
    snacsnoc Active Member
    E
    2014 Tacoma 2.7L
    Did you check if the plug underneath the rear bumper is plugged into the tailgate? I had the exact same thing, 2014 base Tacoma no back up camera. $20 camera from eBay, plugged it into the tailgate and nothing. Then I realized there was a (factory?) disconnected plug, and voila it worked!
  12. Jun 8, 2021 at 7:50 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Not all 2014s are prewired. Most are prewired at the tailgate but only some have the full harness running to the radio. I believe that if you can see the 4 wires running from the tailgate to the cab, you are good to go. If there's only one wire, then not prewired. Personally, not worth the costs of sourcing the harness. I prefer just buying a cheap aftermarket 12V camera with rca outputs to an aftermarket radio. There's nothing special about the OEM radio or camera to warrant the insane pricing. OEM even makes it difficult to hook up with aftermarket HU's by equipping Tacomas with a 6V tailgate camera vs. the common 12V.
    Clearwater Bill and JGO like this.
  13. Jun 8, 2021 at 10:34 PM
    Michaelo
    Michaelo Well-Known Member
    Michael
    PNW
    2014 Regular Cab 4x4 5 Speed
    Mine was like this too. Prewired in the tailgate but not to the head unit. I ended up buying the pop n lock camera and installed that with the lock.
