2015 backup camera
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nessmuk, Oct 17, 2014.
  1. Oct 17, 2014 at 6:44 AM
    Nessmuk
    Nessmuk [OP] Well-Known Member
    Bob
    Charlottesville, Va
    2.7 5sp AC w/SR & convenience pkg
    New to the forum. I just traded my 98 regular cab 4x4 after 17 years for a 2015 base access cab. I have the Etune radio and convenience package.
    I have a warning on the radio when starting the truck about watching the camera while backing, warning label on the rear passenger side of the bed about disconnecting before removing tailgate, and 4 wires coming out of the connector under the bed on the passenger side.
    All of this leads me to belive I just need the camera and it is plug and play. My question is this: I can find the camera for 2014s right now, but no 2015s listed. Does anyone know if the 14 will fit or did they change the rear latch this year? My guess is they are the same?
  2. Oct 17, 2014 at 6:47 AM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Yep they will fit as they are the same as 14's
  3. Oct 17, 2014 at 7:00 AM
    Nessmuk
    Bob
    Charlottesville, Va
    Thanks, I figured they were the same. It's crazy that they just don't throw the camera in with the convenience package. It can't cost them much. They installed everything but the module itself.
  4. Oct 22, 2014 at 12:41 PM
    midwestfourwheel
    midwestfourwheel Member
    Also have a new Access Cab, if you are successful at the 2015 camera install, could you make a recommendation on which camera package or parts to purchase? I've looked at fleabay and am not certain what I've seen includes what is necessary to be plug n play. Thank you
  5. May 5, 2015 at 7:19 AM
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    :popcorn:
    I have a 2015 coming, AC with Convenience Package also and might look into the reverse camera if it's indeed plug and play!
  6. May 5, 2015 at 7:24 AM
    SMHdavid
    SMHdavid Well-Known Member
    David
    California
    Sport
    There's a video floating around YouTube on how to do the install for it.
    I'm on my phone and didn't have luck searching but I have seen it before.
  7. May 15, 2015 at 8:23 AM
    rj112275
    rj112275 Member
    Memphis
    2015 Access Cab 4WD
    I have a 2015 base/utility model access cab without the camera. Warning came on at start up. Yellow sticker by the tailgate. You should be good to go.
    I ordered and just installed the camera OEM part 86790-04021. It was a simple plug and play, about 10 minutes to take the cover off the tailgate. You'll need a torx wrench (I forgot what size? T-30?)and 10mm socket. Easy cheesy. Unfortunately, I couldn't find any smoking deals, so about $400 for the part.
  8. May 15, 2015 at 8:45 AM
    DanceswithWolves
    DanceswithWolves palabra a tu madre
    Jerry
    Roosevelt UT
    13 DCSB OR
  9. May 15, 2015 at 8:52 AM
    SeanP
    SeanP Well-Known Member
    North Florida
    '15 DCSB
    3" lift w/ 5100's, 887s, AAL. 275/70/18's Hankook ATm 18x9 XD Monsters
  10. May 15, 2015 at 9:05 AM
    Mhartley
    Mhartley Member
    Michael
    Lexington, KY
    2015 2.7l access cab 4x4 5spd
    I bought Rostra 250-8412 for $175 on ebay. Easy install and works great.
  11. May 15, 2015 at 3:35 PM
    SeanP
    North Florida
    '15 DCSB
    Yeah my previous post is the Rostra 250-8412.
  12. May 15, 2015 at 5:07 PM
    dofartshavelumps
    dofartshavelumps Well-Known Member
    NH
    2015 SR DCSB 4x4 4.0 MT
    I'm going this route. I ordered the one from camera source and it requires you to run their harness to behind the bumper. When I took the tailgate cover off I realized I was wired up to the handle so I am returning the camera source one and going with OEM. They were great to deal with and I recommend them, just a matter of preference on my part, didn't want to rip out a factory harness when I didn't have to - I would have saved ~$200 though. May be T-30 not T-49 though, can't remember.
  13. May 16, 2015 at 10:25 AM
    rj112275
    rj112275 Member
    Memphis
    2015 Access Cab 4WD
    Oops. Yes, not a T-40 Torx, probably T-30. The T-40 I used to install the tailgate protector. Smaller one needed for removing the tailgate cover.
    Back to camera parts, the OEM requires no additional wiring. You simply remove the camera cover that was there and bolt on the camera, plug the 6-pin plug and you're good to go.
  14. May 16, 2015 at 11:32 PM
    APG
    APG Member
    2015 Tacoma AC
    I put the camera in from Camera Source and it worked like a charm. Not much wire removal at all to install their camera. Route through tailgate and plug in behind bumper. Very simple, works great.
  15. Jun 15, 2015 at 7:34 PM
    Greenbean
    Zack
    Western NC
    Thanks for the factory part number,
    I am going to look into this once my truck arrives.
  16. Aug 23, 2015 at 12:53 PM
    rhmeyer50
    rhmeyer50 Member
    Rob
    HI All,
    New (to me) 2015 Access Base owner here. If I am reading correctly, I DON'T have to pull the radio and fish any wiring through the dash? Just install the camera in the tail gate? Which brand of camera to be sure? TIA Rob
  17. Aug 23, 2015 at 1:03 PM
    rj112275
    rj112275 Member
    Memphis
    2015 Access Cab 4WD
    rhmeyer50
    Correct. No work to be done in the dash or console. Just take the cover off the tailgate with the torx wrench and socket. Plug and play. My 2015 base access cab took about 15 minutes to take apart, plug in, and put back together. See my post above.
  18. Aug 23, 2015 at 1:23 PM
    dofartshavelumps
    NH
    I am not 100% sure but I think the convenience package gets you pre-wired for the camera. Pop the tailgate cover and follow the harness to underneath by the spare tire and make sure it plugs in somewhere and also make sure it has ALL of the wires. Do a search and you will see what I am talking about, I think you need 4 wires or something like that that continue on from the tailgate/spare tire harness connection back to the head unit.
    I installed my OEM one 3 weeks ago and it took longer to get the tools out. There are 2 different length screws for the tailgate cover so pay attention, not hard to figure out after the fact but it is one less thing to worry about.
    Good luck.
  19. Aug 23, 2015 at 1:51 PM
    rhmeyer50
    rhmeyer50 Member
    Rob
    Thanks all, just gotta come up with the bucks. Best, Rob
  20. Sep 1, 2015 at 8:49 AM
    CFLengineer
    CFLengineer New Member
    2015 Tacoma Access Cab
    Rear view camera, receiver hitch, bed mat, fog lights
    I have installed the Rostra 250-8214 rear view camera on my 2015 Tacoma Access Cab with the convenience package. The truck was pre-wired for the camera as stated by others in the thread. The Rostra kit was $160 with shipping from SavingLots.com. Best price I could find on the web. The factory camera sells discounted online for about $450, so the Rostra kit is the way to go, which replaces everything from the connector under the bed to the camera on the tailgate latch. Installation is so easy that if you have ANY mechanical skill it is a no-brainer. I am very meticulous, and even with that I was done in 45 minutes. I used all the original cable stays inside the tailgate and the pass through protectors between the tailgate and bed. No electrical splices, and only used a T30 driver, 10mm socket, some electrical tape (to secure harness to factory cable stays) and some foam tape for rattle protection. Once connected the camera is fully plug and play. Put truck in reverse and Entune displays camera view.
