2015 Double Cab Audio Build - Complete Audio Install
Discussion in 'Audio & Video' started by jaddik, Aug 23, 2015.
  1. Aug 23, 2015 at 8:02 PM
    jaddik
    jaddik [OP] Member
    2015 Tacoma DC TRD OR
    HEAD UNIT
    Factory OEM Entune Premium Audio w/Navigation
    AMPLIFIER
    JL Audio HD Series HD900/5. Marv Amp Rack
    SIGNAL PROCESSOR
    Rockford Fosgate 3Sixty3
    FRONT SPEAKERS
    Hybrid Audio Clarus Components C61-2. Marv Adapters
    REAR SPEAKERS
    Hybrid Audio Imagine I61-2. Marv Adapters
    SUBWOOFER
    JL Audio 13.5” Shallow-mount Subwoofer 13TW5v2-2. Marv Custom Enclosure
    DASH CONTROLS
    JL Audio Amp Remote Control HD-RLC, RF DSP Remote Control
    DEADENING
    Dynamat Xtreme Door Dampening
    Thanks to Marv! For a good installation procedure see this post. I wanted to keep the factory head unit and replace all speakers, add a subwoofer, amplifier, and signal processor. I did the entire install myself, it took quite a few weekends but was worth it. The most time consuming part was the dynamat and running the wires. The wires through the front door was a pain, and some wiring was not long enough to reach the back (rookie mistake). Overall the difference is huge, love the sound quality so far.
    Marv subwoofer box with JL Audio 13.5. The fit was perfect in the double cab.
    Marv amp rack with amp, processor, crossovers, fuse and power distribution. I made a few mods to this, drilling a hole for a bolt to secure it in place, and a hole to fit the child seat tether. I only had to cut one child seat tether on the left side to fit the sub.
    Dynamat all doors. Did the inside behind speaker and the entire outside. Best Buy had a great deal on Dynamat, I was able to do all four doors for $110.
    Solder and heat shrink all wiring. Soldering is a must!
    Amplifier and DSP controls. Can be hidden in the cubby. Outside looking in no one can tell an audio system has been installed. The far left knob is the amplifier bass control. I really like the dash controls to adjust the bass as some songs need more and some need less.
    One of the reasons I went with the 3Sixty3 processor is the wired remote control and presets. Knobs for bass and volume, four presets, and selectable inputs (head unit, bluetooth, AUX, optical). The four presets are the best feature and wish they had more. This gives the ability to change the speaker gains, delay, and crossover settings depending on the type (or quality) of music you are listening to.
    The 3sixty3 has a very easy user interface. So far I did basic crossover settings of all speakers: set the gains, delay, and a couple presents, but just recently bought a microphone to fully tune the system.
    For the power distribution I kept all power separate from the speaker wire. This is just a personal preference and not wanting any possible noise into the system. Not shown is the battery wiring with a master fuse.
    More pictures...
    Factory speaker magnet vs Clarus speaker magnet. The factory speakers are a joke. I would say that for all six speakers cost Toyota no more than $10.
  2. Aug 23, 2015 at 9:57 PM
    azhiaziam
    azhiaziam Well-Known Member
    The reef
    I'm doing this same build as we speak good to hear it kicks ass. I've been looking for a spot to put my bass control and well bingo you just found it for me!! Great job
  3. Aug 24, 2015 at 8:29 PM
    North222
    North222 Well-Known Member
    How much difference did your signal processor make? I keep debating on whether I should add one to my factory Entune system
  4. Aug 25, 2015 at 12:14 AM
    orangeglo
    orangeglo ¯\_(ツ)_/¯
    Los Angeles, CA
    2011 DCSB OR
    If you only have a bass knob. This is where I put mine. I grinded a little plastic off the back to fit everything nice and flush.
  5. Aug 25, 2015 at 12:23 AM
    orangeglo
    orangeglo ¯\_(ツ)_/¯
    Los Angeles, CA
    2011 DCSB OR
    Thats a great setup. Mine is very similar. Mr. Marv is great.
    If you think it sounds good now, just wait til those Clarus speakers break in. It's going to get even better. It looks like you did a great job. Esspecially sealing those doors. It's such a huge difference between a sealed door and an unsealed door. I had one sealed and one unsealed for a couple days and the difference in sound from the sealed door was just unmistakably way better than the unsealed door. It made the unsealed door sound really terrible in comparison.
    I probably would have ended up with the JL HD 900.5, but I already had the HD600 and found a great deal on the HD750.
    It was a ton of work huh? I spread it out over a couple weekends, I had a ton of help from friends and family and it was still brutal. I also did MLV through the entire floorboard. That was a day worth of work on its own.
    Kenwood DNX9909HD
    HAT Clarus C61-2
    Hat Imagine I61-2
    JL HD 600.4
    JL HD 750.1
    JL 13TW5
  6. Aug 29, 2015 at 11:22 AM
    Tacoma951
    Tacoma951 Member
    Danny
    951
    15 4x4
    Nice system. What type of RTA are you going to use? By chance are you located in SoCal?
  7. Aug 29, 2015 at 1:56 PM
    jaddik
    jaddik [OP] Member
    It's an improvement to the system, especially because of the factory head unit. You can be more versatile with crossover and delay settings. It is an added cost and setup time, and the RF 3sixty.3 does have its quirks and isn't perfect. I suggest researching it.
  8. Aug 29, 2015 at 2:02 PM
    jaddik
    jaddik [OP] Member
    Nice system. It was quite a bit of work, but a good learning experience. Would I do it again? probably not ;)
    orangeglo likes this.
  9. Aug 29, 2015 at 2:08 PM
    jaddik
    jaddik [OP] Member
    Behringer ECM8000 Mic + Icicle Mic converter/preamp + Room EQ Wizard software. About a $100 setup. Nope, New Mexico
  10. Sep 7, 2015 at 12:25 AM
    orangeglo
    orangeglo ¯\_(ツ)_/¯
    Los Angeles, CA
    2011 DCSB OR
    Come back and let us know how room EQ works out for you.
  11. Oct 2, 2015 at 7:55 AM
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    Looks like an awesome set up, I'm thinking about doing something similar but maybe without the speakers. Do you think I would be able to do something like this with the JBL head unit in my 2009?
  12. Oct 14, 2015 at 4:32 PM
    jaddik
    jaddik [OP] Member
    Definitely. I kept the head unit and works great
  13. Oct 14, 2015 at 8:18 PM
    Tacoma SS
    Denver
    Awesome to hear, picture of your set up?
