2015 Tacoma Drivetrain Problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cbarw2, Feb 12, 2020.
  1. Feb 12, 2020 at 10:34 AM
    cbarw2
    cbarw2 [OP] Member
    Hello fellow TW members!
    I am fairly new to this site, so I apologize if this has been brought up/answered in the past.
    I have a 2015 DCSB 4wd taco that has just started giving me some trouble. Upon applying pressure to the gas pedal I am getting a chirp/squeak. This noise is only there when I am on the gas and I can primarily hear it when Im giving the pedal above average pressure. Also when accelerating, I am feeling a slight shudder and the truck seems to be very sluggish (this was the first thing I noticed.) This seems to be something that is rotating and doesn't sound like a suspension problem.
    I have crawled underneath the truck to see if the U-joints had any play and they do not. What do y'all think it is?
    Thanks!
  2. Feb 12, 2020 at 11:18 AM
    rayban1
    rayban1 Well-Known Member
    Seattle
    2015 tacoma sport 4x4
    truck covers usa roll cover, popnlock remote lock, iron cross running boards, p2 trailer Brake, rear view mirror upgrade with auto dim temp and homelink, yakima rack bars , goodyear wranglers, heated side mirrors with directional signal.
    Are you sure it's not your serpentine belt. My belt was chirping and squeaking.......replaced it........
    Blockhead, cbarw2 [OP] and TnShooter like this.
  3. Feb 12, 2020 at 3:28 PM
    TnShooter
    TnShooter Well-Known Member
    07' TRD Off-Road, Auto
    STOCK
    Does the noise happen in park or Neutral?
    If so, it is probably not the u-joints.
    I’d inspect the idler pulleys and Belt Tensioner Pulley.
    If it happens only while driving and you are a 4x4 truck,
    I would grease all the u-joints and see if the noise changes.
    BassAckwards and cbarw2 [OP] like this.
  4. Feb 12, 2020 at 3:30 PM
    Benny123
    Benny123 Kid from the late 70s
    Ben
    South Charlotte, NC
    2005 Speedway Blue Tacoma AC V6 TRD Off Road 4x4
    Replacing everything worn, broken, and rusted.
    Yes, check for any play in your u joints. Chrisfix has a good video on how to check them and replace them. As does Kflos Tacoma build.
    cbarw2 [OP] likes this.
  5. Feb 12, 2020 at 4:11 PM
    cbarw2
    cbarw2 [OP] Member
    This noise does not happen in neutral or park. Only when I am in drive and accelerating or under load.
  6. Feb 12, 2020 at 6:20 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Troy
    Las Vegas
    2017 Pro/2015 Tacoma
    Lifted
    Driveline shop can check it for you.
  7. Feb 13, 2020 at 9:21 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    My guess...Dry U-Joints!
    Jimmyh likes this.
  8. Feb 13, 2020 at 9:42 AM
    will.i.was
    will.i.was Well-Known Member
    Houston, Texas
    07' SS MICA DCSB
    U joints or carrier bearing. Usually the carrier bearing will squeak because the rubber bushing starts to give out or move around in the carrier itself.
  9. Feb 13, 2020 at 4:15 PM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    Play in U joints does not always tell the story. I had NO play in my rear U joint only because it was frozen solid and the grab and shake test didn't show a thing. Replacement did.
    Jimmyh, cbarw2 [OP] and TnShooter like this.
  10. Feb 14, 2020 at 1:25 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You cannot tell if a universal joint is defective solely by looking and wiggling it on the truck.
    Pull the drive shaft and check each joint for excessive tightness or looseness while out of the truck.
    I too vote for a worn universal joint.
  11. Feb 14, 2020 at 5:37 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    And if the worn out (probably seized up) universal joint is tight enough to cause the OP's symptoms of sluggish acceleration, I'd be replacing it post haste to avoid a possible catastrophic failure.
    BassAckwards, cbarw2 [OP] and Jimmyh like this.
