2015 Tacoma Entune (NO JBL) Frequency Response?
Discussion in 'Audio & Video' started by rhallmcp, Jan 3, 2017.
  1. Jan 3, 2017 at 8:27 AM
    rhallmcp
    rhallmcp [OP] Well-Known Member
    Upstate NY
    2018 Trd Pro
    I curious about the frequency response on the Entune Plus head unit in my 2015 Tacoma.
    I upgraded the audio system with 5 channel amp, and all new speakers, running Speedwire to the Rockford Fosgate amp for hi level inputs. most everything sounds good, but im getting really "mushy" bass, and not getting any really hard hitting low frequencies. Im thinking that maybe its the Rockford P3SD4-10 sub, and was thinking about upgrading the JL Audio 10TW3-D4 instead.
    Any thoughts on the frequency response output before i upgrade the sub?
    here is a post on my build: https://www.tacomaworld.com/threads/my-2015-tacoma-double-cab-stereo-install.446845/#post-13336204
  2. Jan 3, 2017 at 11:15 AM
    SlowComa666
    SlowComa666 Well-Known Member
    San Antonio TX
    2014 SR5 Access Cab 2WD
    it outputs flat as far as some of us have tested
    why not try test tones to see where things are going bad?
  3. Jan 3, 2017 at 12:03 PM
    rhallmcp
    Upstate NY
    2018 Trd Pro
    would you say 20-20K then?
  4. Jan 3, 2017 at 1:08 PM
    dmb1650
    dmb1650 Well-Known Member
    2012 Blk Tacoma TRD sport DCLB
    Whats the details on the subwoofer box? sealed or ported? volume? Was it custom made for your sub or just made to fit in our trucks?
    Also, what have you been using for music? poor quality MP3s and poor streaming sources can make music sound bad. Also, Bluetooth streaming doesn't sound as good as USB or AUX.
    Try playing a CD with some good low notes and see how it sounds.
  5. Jan 3, 2017 at 1:12 PM
    rhallmcp
    Upstate NY
    2018 Trd Pro
    sealed fiberglass box .58cuft. built for the truck, and for either the JL or the RF sub at that CU FT. box is sealed very tight, and i have plenty of power going to the sub.
    i have listened to all kinds of CD's, (metal, rap , 90's hip hop) some new some old. I even have some "old school bass" cd's from the 90's and they seem to just not hit low and hard.
    i have just assumed that the stock head unit wasnt responding to the low frequencies very well.
  6. Jan 4, 2017 at 8:57 AM
    SlowComa666
    San Antonio TX
  7. Jan 4, 2017 at 9:44 AM
    rhallmcp
    Upstate NY
    2018 Trd Pro
    Sorry, i just double checked, and the box is .95 cu ft. Totally my mistake on that one, as i was thinking of something else when i typed it
  8. Jan 4, 2017 at 7:00 PM
    SlowComa666
    San Antonio TX
    you may be able to port that enclosure. it's almost big enough [specs call for 1cu ft]. you'd need to model the enclosure and sub to get the port size correct.
    you'll still have an F3 of 36Hz+. not sure how low you are trying to go but physical limitations are going to prevent you from going crazy
  9. Jan 4, 2017 at 7:10 PM
    rhallmcp
    Upstate NY
    2018 Trd Pro
    It's just "mushy" sounding. So I'm thinking of either replacing the head unit to get pre-outs and more realistic fine tuning. Or possibly replacing the sub with the JL audio 10TW3-D4.
    The issue i am having with replacing the head unit is simply the cost of it all. If i get a new one, i want something nice, so its going to be $600 for the HU and then $250 for all the extras for the install. and i typically only keep a car/truck about 2 years... so if i dive deeper in, the wife is going to "suggest" that I keep the truck a little longer :)
  10. Jan 4, 2017 at 8:55 PM
    SlowComa666
    San Antonio TX
    well it is firing into a hard plastic seat barely inches away. i don't think the head unit is the issue here.
    might be your tuning or just how that sub sounds at those frequencies. are you using bass boost of any kind?
  11. Feb 5, 2017 at 7:51 AM
    rhallmcp
    Upstate NY
    2018 Trd Pro
    Replaced the factory HU with a Kenwoood DDX-9903S and the system sounds amazing now. The sub is getting the lows that i expected from it
  12. Feb 5, 2017 at 2:57 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The factory head unit has poor base response. For others future reference, replacing the head unit is one option, another would be to run an specialized amp designed to be run on OEM head units that has controls to fill in the base EQ, like the AudioControl LC-4.800:
    https://www.crutchfield.com/p_161LC4800/AudioControl-LC-4-800.html?tp=115
    Another option is to run a digital signal processor before the amp.
