2015 Tacoma rear shock mounts changed - OME not an option?
Discussion in 'Suspension' started by aix42day, Jun 1, 2015.
  1. Jul 23, 2015 at 10:09 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Very interesting. I went and compared a 2007 and a 2015 that we had here in the parking lot, and I could not find any difference in the mounts. Must be just a hit and miss on some of the brackets.......
  2. Jul 23, 2015 at 10:14 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    so if this is an issue with OME, wouldnt it be an issue with other shocks?
    or is this specific to OME?
    bilsteins, kings, icons, etc..
  3. Jul 23, 2015 at 10:16 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Shocks like the Bilstein 5100s don't have an issue due to the shock body being on the top side.
  4. Jul 23, 2015 at 10:26 AM
    scocar
    scocar Patron of the Farts
    @YotaDan Is the 2015 a sport, an OR, or a base/SR5?
  5. Jul 23, 2015 at 10:28 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    TRD Off-Road
  6. Jul 23, 2015 at 10:30 AM
    scocar
    Thanks.
    And how much longer are your OME kits on sale for? I haven't spent engouth money with you on my 01, so now I need to spend it on my 15 o_O
  7. Jul 23, 2015 at 10:34 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    I think we will keep them at the price at least until Sep-Oct.
    scocar likes this.
  8. Jul 23, 2015 at 10:36 AM
    scocar
    Sweet. Still need to sell the 1st gen, and first kid due in August...many priorities to shuffle.
  9. Jul 23, 2015 at 10:37 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    I hear you on that. Always seems to be a Juggling act.
  10. Jul 23, 2015 at 3:59 PM
    Brjw
    Brjw Well-Known Member
    Brian
    Forest Grove, Oregon
    Could be debatable depending on shock body size, pinion angle, position of the axle etc. As an example, some springs move the axle back a small amount. Add in a pinion shim, and the drivers side shock mount (on the rear of the axle) could really have some clearance issues.
  11. Aug 11, 2015 at 12:19 AM
    yesmar
    yesmar Well-Known Member
    Ramsey
    Harrisburg, PA
    A couple cars
    can someone with a 2014/13 with ome shocks take a pic of the mount with the shock in compression?
    and maybe someone with a 2015 who's shock just went on no problems?
    i see the issue here and would like to see what the mounts looked like before this change
    Thanks Guys!
  12. Nov 19, 2015 at 5:27 AM
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    I have a 2014 TRD Off Road and the rear 60091 shocks are really close to the shock mount, maybe touching at full droop in the rear. When the truck is standing on its own, the shock body clears. It also took a little convincing to get the bottom of the shock into the mount. Wonder if I got a 2015 axle...
  13. Nov 20, 2015 at 5:49 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    I knew something was different on the '15's rear suspension. Switched my Firestone air bags over from a '12 Sport to a '15 Off Road, and it was not a straight swap over, had to re-angle the 90 degree air inlet to clear a new beefier bracket on there.
  14. Nov 24, 2016 at 10:38 PM
    srdoublecab2.7
    srdoublecab2.7 SRlifted&gifted
    Austin, Tx
    2017 DC SR 2.7 MGM
    Stock for a minute
    I just finished installing my OME loft tonight
    And was wondering when you installed the rear shocks was it a pain in the ass to get the bolt on the top of shock to sit down far enough so you could grab it with another wrench like a 5mm to tighten it?
    The top of the rear shock is very soft metal and I was pissed I kind of messed it up
    Still got the shock mounted up but damn lol pissed I messed it up I'm a little OCD
  15. Nov 25, 2016 at 6:31 PM
    #35
    Jtaoj0
    Jtaoj0 Well-Known Member
    So is it full drop where this will be an Issue? Just installed my lift a month ago, haven't been off-road yet. Just checked it sitting in the garage, and it is close. When I installed, the bushing fitment was really tight. Figured it was the bushing, didn't think the bracket may interfere with the shock body.
