2016-2017 Cruise Control Mod!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by moe2o4, Nov 13, 2015.
  1. Aug 30, 2017 at 8:16 AM
    #181
    Thirty8special
    Thirty8special Well-Known Member
    Lucas
    AL
    2017 Tacoma SR
    Grill, lights, wheels & tires
    Just bought a '17 SR and already have the cruise control switch on the way! Thanks for the write up and pictures! Hoping to install it this weekend
    mcharfauros likes this.
  2. Aug 30, 2017 at 10:06 AM
    #182
    MarcosBalderas
    MarcosBalderas Well-Known Member
    Marcos
    San Antonio Texas
    2015 Jeep Wrangler Rubicon, 2017 Tacoma SR 4x4
    Just did the mod and love it works great
    Got the switch on Amazon for $25 and the cover at the dealer for $5. Combined $30 and it's perfect. Another win for Tacoma World
    gulzeb and mcharfauros like this.
  3. Sep 16, 2017 at 4:13 PM
    #183
    sn0zz
    sn0zz New Member
    Mark
    2017 white tacoma sr 4x4
    None yet!
    Hey, guys. Just got a 2017 sr, and I'm wanting to do this and the wiper mod. I was wondering if there are other Toyotas that have a similar interior that I could yank the parts out of? If so, what years? I've searched nearby pull your own parts shops, and no one has any tacomas. Thanks in advance!
  4. Sep 24, 2017 at 3:13 PM
    #184
    TPMO
    TPMO Well-Known Member
    2017 Tacoma SR Utility 4x4 MT
    Add me to the list of those thankful for the help!
  5. Oct 5, 2017 at 4:12 PM
    #185
    jsr813
    jsr813 Well-Known Member
    Cranberry Twp., PA
    2022 Tacoma SR5 V6 DCSB 4x4
    None yet
    Another happy cruiser! Thanks for the write-up. It is awesome.
  6. Oct 5, 2017 at 8:28 PM
    #186
    Hartge
    Hartge Member
    Sean
    Tacoma 4x2
    None
    Will this mod work on an SR 2.7 ?
  7. Oct 5, 2017 at 8:36 PM
    #187
    Hartge
    Hartge Member
    Sean
    Tacoma 4x2
    None
    Link says does not fit my base SR EXTENDED. Yet it says fits 2017 Tacoma
  8. Oct 6, 2017 at 10:08 AM
    #188
    jsr813
    Cranberry Twp., PA
    None yet
    I have seen several people say that they have not seen a 2017 that was not prewired, but it is easy enough to check.
    If you take the air bag off the steering wheel (instructions at the beginning of this thread), see if you have the open connector at the top that the cable goes in. If you do, with the key in the 'on' position very carefully take a paper clip or a very small flat screwdriver and temporarily short the bottom two pins. (I take no responsibility here). This should turn the crusie control indicator on on the dashboard. Another temporary short will turn it off. If this works, your truck is definitely pre-wired. As far as the switch goes, I guess just make sure that your mounting holes look the same as the mounting holes in the guide. The cover is only a few dollars so you can order that, or you can just drill out about a 1.5" hold in your existing cover.
    I can tell you that i had all the same trepidations that you have, but I went ahead and ordered from the guy on ebay (who was just fantastic), made sure he knew the model I had and it all just worked. It took me about 15 min to install. One note is that those torx screws that hold the airbag in are very tight. I had to use a pair of pliers to turn the torx screwdriver to get them to budge. I would recommend that you tighten them back up just as much as they hold the airbag and there is a lot of forces in play should that ever blow. I have seen some people say that you should disconnect the neg on the battery first just in case, but I didn't.
    Good luck to you.
  9. Oct 8, 2017 at 10:36 AM
    #189
    Hartge
    Hartge Member
    Sean
    Tacoma 4x2
    None
    In the sellers thread for switch he mentions horn wire needs to be cut and required to his OEM cable. I noticed in the pic that the blue wire looks like it is snipped. Is this true? Must the wire be cut and wired to new harness wire? Thanks
  10. Oct 13, 2017 at 12:32 PM
    #190
    jsr813
    Cranberry Twp., PA
    None yet
    With the parts I ordered, I did not have to do that. The cable from the switch went to the open connector and that was it.
  11. Oct 25, 2017 at 9:39 AM
    #191
    Dr. Mantis Toboggan
    Dr. Mantis Toboggan Well-Known Member
    2017 TRDOR 4x4 & 2000 TRD TACO 4x4
    Do you have a link for the items you bought? That's a great deal.
  12. Oct 26, 2017 at 1:50 PM
    #192
    QuickBurn
    QuickBurn Well-Known Member
    Thank you for the write up. ordered the switch for $15 bucks off Ebay, and will pick up cover plate from the dealer later today. Win. Next up... Wiper stalk.
    Dr. Mantis Toboggan likes this.
  13. Oct 26, 2017 at 1:54 PM
    #193
    Dr. Mantis Toboggan
    Link to that auction?
  14. Oct 26, 2017 at 8:05 PM
    #194
    QuickBurn
  15. Oct 27, 2017 at 12:30 PM
    #195
    Dr. Mantis Toboggan
  16. Oct 27, 2017 at 2:00 PM
    #196
    QuickBurn
    My research says nope plug and play. Get it all installed . Drive to dealer to get the correct pop over plate. Done
  17. Nov 4, 2017 at 6:07 PM
    #197
    Dr. Mantis Toboggan
    Got everything in and installed today. Couldn’t have been easier. Best part is it only cost me about $20 and I never had to step foot in the dealership.
  18. Nov 8, 2017 at 7:29 PM
    #198
    SouthernMD
    SouthernMD New Member
    2017 Tacoma SR 4x4
    Looking for Cruise Control, Keyless entry to start
    I obtained the Cruise Control Kit off the ebay site, but was looking for instructions on installing the wiring harness if my Tacoma SR (2017) is not prewired. Does anyone have the instructions for installing the harness?
    Thanks
  19. Nov 10, 2017 at 7:05 AM
    #199
    jsr813
    Cranberry Twp., PA
    None yet
    See post 195 to check if you are pre-wired, my guess is yes.
  20. Nov 17, 2017 at 4:07 PM
    #200
    mweidl
    mweidl Well-Known Member
    Mikey
    Southern California
    2017 Tacoma SR 4x4 Auto
    I just pulled everything apart and went to install but there are no bolts provided with the Cruise control that I bought. I looked but couldn't find a parts break down. Does someone know the thread and size of the bolts I should buy?
