2016-2017 Cruise Control Mod!
Discussion in '3rd Gen. Tacomas (2016+)' started by moe2o4, Nov 13, 2015.
  1. Nov 17, 2015 at 5:01 AM
    rcsb jon
    rcsb jon Well-Known Member
    Pittsburgh
    '17 Ridgeline RTL-T | AWD | White | Ebony
    -WeatherTech liners
    so you didn't add anything to the clutch pedal?
    moe2o4 [OP] likes this.
  2. Nov 17, 2015 at 5:17 AM
    moe2o4
    moe2o4 [OP] Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    Thanks Man!!!
    Nope there is already a switch on the clutch pedal no the SR so there is no need to add it!!!!
  3. Nov 17, 2015 at 5:20 AM
    moe2o4
    Corey
    Pittsburgh PA
    My guess is Toyota adds the switch to the clutch pedal because if you want cruise control as a option they just charge you $500 to do what i just did for $67........
    0uTkAsT likes this.
  4. Nov 17, 2015 at 7:57 PM
    tacomanamedolga
    tacomanamedolga Well-Known Member
    SeviervilleTn
    2015 trd offroad
    Any news on adding fogs?!
    0uTkAsT and moe2o4 [OP] like this.
  5. Nov 17, 2015 at 8:04 PM
    moe2o4
    Corey
    Pittsburgh PA
    No fogs yet, im waiting for the dealership to get my bezels in I ordered!
    tacomanamedolga and 0uTkAsT like this.
  6. Nov 19, 2015 at 12:50 PM
    rj112275
    rj112275 Member
    Memphis
    2015 Access Cab 4WD
    Awesome, thanks for posting. I did check my 2015 and the clutch switch is already wired. I'm looking forward to an easy install. Thanks!
    EDIT: I'm stupid and was looking at the clutch safety switch. I knew it couldn't be that easy. I'll have to order a switch. There is an empty plug beside where the clutch disengagement switch would be located. I'm hoping that is the correct wiring for the switch.
  7. Nov 19, 2015 at 12:50 PM
    moe2o4
    Corey
    Pittsburgh PA
    Sweet man, I'm thinking it should be pretty similar on the 15!! Let me know I'm curious!
  8. Nov 20, 2015 at 5:37 AM
    DPJ
    DPJ Active Member
    NE Florida
    White DCSB 4 cyl 2WD automatic
    I just installed the cruise control unit. It took 20 minutes. It works like a charm. I can't believe Toyota gets almost $400 for doing the job and couldn't even tell me when or if one would be available for the 2016.
    Thanks for the information.
    Next is the intermittent wipers. I have a wiper stalk from a 2000 Tacoma and I'll check to see if it's the same. Probably not, but you never know.
    When you get that lead to gold thing figured out, let me know.
  9. Nov 20, 2015 at 5:40 AM
    moe2o4
    Corey
    Pittsburgh PA
    Your welcome man, glad I could help! BTW idk if you seen my write up on the Intermittent Wipers but here it is!
    https://www.tacomaworld.com/threads/2016-3rd-gen-intermittent-wiper-mod.397942/
  10. Nov 21, 2015 at 10:37 AM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    I assume that this install would be the same for my 09 Prerunner Base model?
  11. Nov 21, 2015 at 12:05 PM
    moe2o4
    Corey
    Pittsburgh PA
    Pretty sure they are all the same. Tske your air bag off and check it out!
  12. Nov 22, 2015 at 1:52 PM
    motoretro
    motoretro Well-Known Member
    Michigan
    09 Reg, Cab, 2.7 Four Cyl. manual trans
    I thought Intermittent wipers were standard on the SR this year....
    Motoretro
  13. Nov 22, 2015 at 2:01 PM
    Farmer_Ted
    Farmer_Ted I WANT A TACO!
    Mid West
    '16 Tacoma SR AC 4X4 MT
    Hardcore off road floor mats!
    How did you order your Tacoma with matching bumpers? Must not have gotten the Sr convenience package, because it comes with cruise control.
  14. Nov 22, 2015 at 2:30 PM
    moe2o4
    Corey
    Pittsburgh PA
    Nope
  15. Nov 22, 2015 at 4:08 PM
    #35
    motoretro
    Michigan
    It that a regional thing or?
    My local dealer sent me a build sheet for a allocation 2WD SR w/ utility pkg. back in September and it clearly shows Intermittent Wipers as standard equipment.
    Motoretro
  16. Nov 22, 2015 at 4:09 PM
    #36
    moe2o4
    Corey
    Pittsburgh PA
    Idk but I purchased my 2016 SR about a month ago and it did not come with Intermittent so I installed a switch myself!
  17. Nov 22, 2015 at 4:21 PM
    #37
    Ars3nalTRD
    Ars3nalTRD I Know Nothing!
    NoVA
    2016 BRM Tacoma TRD Sport
    Great write up OP... This is pretty cool, one would think adding Cruise Control would require changes to the ECU or something. Glad is a simple plug and play. What's next on the list? LOL
  18. Nov 22, 2015 at 4:26 PM
    #38
    moe2o4
    Corey
    Pittsburgh PA
    Thanks man!
    Idk lol already added the cruise control and the Intermittent wiper switch. I got a set of nfab 3 step running boards coming in tomorrow!
  19. Nov 22, 2015 at 4:30 PM
    #39
    checkers
    checkers Member
    mike
    16 crew cab tacoma 4x4
    none yet
    I just bought a double cab sr. My build sheet said intermittent wipers and it didn't come with them either. Can I ask, the ones you put in from the dealer or an after market deal/
  20. Nov 22, 2015 at 4:32 PM
    #40
    moe2o4
    Corey
    Pittsburgh PA
    They are a oem switch from a 2014 Toyota corolla. If @jshsltr still have some for sale possibly! And the same switch is in a 2015 Toyota camry also!
    Here is my link to the write up on the install!
    Link to the for sale post!
    https://www.tacomaworld.com/threads/fs-3rd-gen-intermittent-wiper-switch.397876/
    checkers likes this.
