2016 3rd brake light Leak
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jaybird67, May 1, 2017.
  1. Aug 1, 2017 at 2:56 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    i'd be on the phone with corporate then.
    Jchip, 623miller and mcharfauros like this.
  2. Aug 1, 2017 at 3:04 PM
    Blazingbluesport
    Blazingbluesport Well-Known Member
    The OC!
    2016 TRD Sport 4x4 double cab.
    Mine just started after almost 2 years and 20k miles. 351 on back order, 4000 more ordered from manufacturer. My service manager said he was told about it at a Toyota corp meeting. 2-3 month wait to get the part, they have to replace the entire third brake light assembly. It was caused by a robot over torqing the gasket on double cabs. They told me to put clear packaging tape over it until it can be replaced. I called Toyota.. sorry about that sir but we can't do anything to speed up the process. I was told do not, do not try to seal it with silicone. It will void the warranty as trying to make a "permanent" repair.
    mcharfauros likes this.
  3. Aug 1, 2017 at 3:18 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    Lemon law time. Black mold could grow on the damp seats and carpet so it's a safety issue.
    mcharfauros and boogie3478 like this.
  4. Aug 1, 2017 at 3:20 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Seems like they were not very helpful
  5. Aug 1, 2017 at 3:20 PM
    rewted
    rewted Well-Known Member
    2017 Black TRD Off-Road Double Cab Short Bed
    Warn Zeon 10-S, BFG KO2 265/75/16, Bakflip MX4, Split Dual Battery System, TRD Pro Grille, Tokonsha P3 Brake Controller, ScanGauge II
    Lemon Law requires a recurring issue with the same vehicle and you have to give the manufacturer time to fix it. This is his first incident. I would however bring up the fact that the inside did get soaked and there's the possibility of mold growth, at a minimum I might ask that they pay for a real cleaning. I doubt you'd win that argument though. Dealerships have no soul, Corporate even less.
  6. Aug 1, 2017 at 4:25 PM
    Blazingbluesport
    The OC!
    For whatever it's worth they gave me a platinum extended warranty. 7 years $0 deductible for complaining tactfully about my issues. Fortunately they had records that I have been a Toyota customer since 1986 so I played the loyal customer you need to take care of me card.
  7. Aug 1, 2017 at 8:26 PM
    Samtk38
    Samtk38 Member
    2016 Tacoma Limited
    My 2016 was built in Baja. Light seems to be the only issue.
  8. Aug 1, 2017 at 8:42 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    I fixed mine myself(although I didn't have a problem yet) When installing my new 3rd brake light, I put a Bead of silicone around the edges and bolted it back in. No problems thus far
    "BACKORDERED light for months" is a joke. THE LIGHT IS FINE. It's just the stupid gasket and the design. if TOYOTA really wanted to speed up the process they would redesign the gasket and just send them out to dealers. A lot cheaper than a brand new light assembly(that will probably have the exact same foam crappy gasket the stock one did)
  9. Dec 15, 2017 at 6:44 PM
    Surfguygriff
    Surfguygriff Well-Known Member
    Just happened to my 2017 4 door, 4x4 TRD OR and is only 3 months old. I noticed some dampness on the rear seats then lots more after a rain storm. Brought it to the dealer in RI and 2 weeks later this thing is a disassembled mess!
    They confirmed that the rear light on the cab was the culprit and replaced it at once, and they pulled the entire interior out.
    Toyota ordered a mold test (the cab smelled really bad when the pulled the carpet and headliner down) and now they are making the dealer hand scrape all of the black, tar like sound deadening material off the floors. They then need ServePro to come out and sanitize/disinfect the whole cab, reapply the sound deadening material, have another mold spore test done, then put in a whole new interior in! All for a bad $5.00 gasket at the cab light!
    3-4 week wait due to no headliners available right now.
    TacomaEd2017 and mcharfauros like this.
  10. Dec 15, 2017 at 7:14 PM
    MESO
    State of Jefferson
    That sucks. My worst fear for a brand new truck is having someone ELSE rip it down to bare metal. Hopefully they are competent on fitting everything back like factory.
  11. Dec 15, 2017 at 7:24 PM
    SNIPES760
    SNIPES760 Well-Known Member
    Manny
    2016 White Tacoma TRD Offroad 4x4
    This happened to me as well :(
    shakerhood and mcharfauros like this.
  12. Apr 5, 2018 at 1:37 PM
    JukemJake
    JukemJake Active Member
    Jacob
    Kent, WA
    2017 Red Toyota Tacoma TRD Sport
    Goodyear MTRs with Kevlar (285 70 17) SCS Ray 10 Wheels 3" level lift Vision x grille lights
    Just ran into this as well for my 2017 Tacoma. It has also caused water to run over top of the cab into floor board on driver side. I usually back into driveway that has an angle and finally noticed after some rain showers. I had it parked in the garage up until then. Unfortunately, that brake light is on back order :confused:. Seems like this is common...
  13. May 18, 2018 at 8:10 AM
    Gates9
    Gates9 New Member
    Brent
    2016 Toyota Tacoma
    3” Level Lift with 33” Falken AT3 on Fuel Hostage Wheels
    Why hasn’t Toyota done anything to resolve such a low cost issue that really can damage your truck to keep customers happy and warranty costs down? Mine has done it and of course it is past the 36,000 mike mark so they want 207.00 to repair their manufacturing issue.
  14. May 18, 2018 at 10:05 AM
    JukemJake
    Jacob
    Kent, WA
    That sucks. I caught it early and who knows. They showed me the bill with labor and all. They ended up charging like $650 back to Toyota directly. To me, since they were on back order this should be more of a recall. Service at Toyota said it's not a recall but they have seen a lot? Is that not the same thing :confused:
    TacomaEd2017 likes this.
  15. May 21, 2018 at 2:14 PM
    #35
    623miller
    623miller Member
    Todd
    2016 Barcelona Red Tacoma
    None
    Mine leaking too. Anybody want to get a class action suit going? I'm being ignored by dealer and Toyota.
  16. May 21, 2018 at 2:47 PM
    #36
    Chucked
    Chucked Active Member
    Chuck
    Middle River, MD
    2018 DC SB SR5 V6
    Has this been repaired on 2018's?
    BSFord likes this.
  17. May 21, 2018 at 4:15 PM
    #37
    623miller
    623miller Member
    Todd
    None
    That's a good question for Toyota... From the response from my dealer and from Toyota USA... They are denying an issue. So I doubt they have fixed. My opinion is leak is small and unnoticeable until after water has frozen over a winter and made leak point larger then dealer blames you for damage.
  18. May 21, 2018 at 4:18 PM
    #38
    wirenut
    wirenut I like this place
    Andrew
    NH
    98’ T4R
    OME/5100 - 300lb 3.5” loft setup Prinsu 3/4 rack
    Mine did it after 3 months. 2 days at the dealer and it was all fixxed. The gaskets junk from the factory so they replace the gasket and add a little silicone where the wires go through. I haven’t had an issue since.
  19. May 21, 2018 at 4:23 PM
    #39
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    Had this same thing happen in my 2008.
  20. Jul 13, 2018 at 4:54 PM
    #40
    Chauparker
    Chauparker Member
    Chau
    Texas
    2017 Tacoma Sport 4X4
    TRD pro grill Trd Pro exhaust Toytec Boss lift Clazzio Leather seats Black Red stitch TRD Pro Wheels 17” Toyo AT2 tires 265/70/17 TRD Cold air intake LED fog lights bulbs Lasfit LED head lights bulbs MostPlus C Quartz UK ceramic coating Red TRD emblem Tacoma and 4x4 emblem black Weather tech floor line TRD Pro Skid Plate powder coated.
    I just had my truck leaked everywhere a couple of weeks ago and it is still in the shop. They had to removed all the seats front/back, replaced the carpet. I will definitely get them to pay for my customer leather seats.
