2016 BBP audio build
Discussion in 'Audio & Video' started by Man of Steel TRD, May 2, 2016.
  1. Jun 18, 2016 at 10:53 AM
    #261
    hookembevo
    hookembevo Well-Known Member
    Austin, TX
    2016 Tacoma DCSB with 6MT
    Snugtop Rebel with some options Body Armor Rock Steps Rhino Mats Weathertech Mudflaps Radar detector hardwired to rear view mirror. Stereo upgrade: Amp: Arc Audio XDI805 LOC: AudioConnect LC7i Front Speakers: Hybrid Audio Technologies Claris 6.5 Rear Speakers: Hybrid Audio Technologies Mirus 5.25 Sub: Pioneer TS-SW2502S4 Box: Pioneer Ud-SW250T Bilstein 5100s OME 885 Springs Single Add-A-Leaf BFG KO2 265/75/16
    [QUOTE="holeinone604, post: 12593009, member: 36862"
    Finally got around to soldering all my connections.
    Did I get it right ? Only one I wasn't sure was the orange striped wire to blue wire...[/QUOTE]
    Why is the blue speedwire tapped in to a speaker wire rather than the red wire? What are you using the 9th wire for?
  2. Jun 18, 2016 at 10:59 AM
    #262
    holeinone604
    holeinone604 Well-Known Member
    Vancouver, BC
    16' TRD Sport Black Crew Cab
    Why is the blue speedwire tapped in to a speaker wire rather than the red wire? What are you using the 9th wire for?[/QUOTE]
    The blue speed wire (9th wire) isn't tapped into or soldered to anything. It's just sitting in the bundle unused. I'm not going to be running a processor of any kind so don't need the power wire. I'm wiring the speaker wire to the amps high level input.
  3. Jun 18, 2016 at 11:08 AM
    #263
    Man of Steel TRD
    Man of Steel TRD [OP] Ignorance is the new normal
    Jeremy
    Gilbert, AZ
    2021 Ram Limited Night Edition, 91 300ZXTT, 90 Toyota Pickup ECLB
    Tow package, LED interior lighting, led low beams, led fog lights, led licence plate lights, OEM bed mat, OEM mud flaps, OEM chrome raised tailgate letter inserts, nerf bars, AVS ventshades. Complete Kicker audio system (4 channel amp, mids and tweets in the front, 2 ways in the back, 2 10 inch comp rt subs, Zxsum8, alpine pdx 1.600 boxes and amp rack by Mr Marv), Pop & Lock, Mobtown locking bed storage doors, Bilstein 5100s, Katzkin Leather interior, Redline Hoodstruts, Backflip.
    The blue speed wire (9th wire) isn't tapped into or soldered to anything. It's just sitting in the bundle unused. I'm not going to be running a processor of any kind so don't need the power wire. I'm wiring the speaker wire to the amps high level input.[/QUOTE]
    You could use the 9th wire for your remote wire. You would just add it to the red switched power wire.
  4. Jun 18, 2016 at 11:33 AM
    #264
    holeinone604
    Vancouver, BC
    You could use the 9th wire for your remote wire. You would just add it to the red switched power wire.[/QUOTE]
    Yeah I was thinking about asking on this. The amp apparently turns on automatically when it senses signal. Is it worth running the remote wire just in case to be on the safe side ?
  5. Jun 18, 2016 at 11:38 AM
    #265
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    Well it's already ran for you inside the speedwire so I guess you could give the signal sensing a shot and if it doesn't work you could hook up the remote wire.
  6. Jun 20, 2016 at 10:33 AM
    #266
    hookembevo
    Austin, TX
    Has anyone ever run a 2nd speedwire from the amp back to the factory harness and used existing factory speaker wire? Honestly, I'll likely have the front ones unplugged/ unused and just solder in a connection to the crossovers from the speedwire. I want to make use of the factory wiring to the rear speakers, as I've already gotten the speakers soldered in to the OEM speaker wire in the rear doors.
  7. Jun 20, 2016 at 10:48 AM
    #267
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    I haven't but I don't see why you couldn't do that.
  8. Jun 20, 2016 at 7:17 PM
    #268
    hookembevo
    Austin, TX
    Well I'm doing it then. Got all my wiring done today and mock up of amp rack. Just need to install fronts and pull some cable.
  9. Jun 20, 2016 at 7:20 PM
    #269
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    Looks good. Hopefully the sub doesn'thit the pocket when it is moving. I like your amp rack.
  10. Jun 20, 2016 at 7:27 PM
    #270
    hookembevo
    Austin, TX
    Thanks man. Appreciate you responding. I'm going to put a wedge under it so it clears the front of the pocket, although there's about an inch in front of it now. That Pioneer sub looks like it's made for the truck. Hope it sounds good, but I'm leaving plenty of wiring back there so I have some options. I may pull out the plastic and go for a ported box/ amp rack down the road. Thought I'd try this for now, and I have high hopes.
    I'm running a Mr. Marv setup that I bought in the For Sale section.
    Arc Audio XDI805 5-Channel Amplifier
    Claris 6.5's up front and the Mirus 5.25s in the back along with the other stuff you see here.
  11. Jun 20, 2016 at 7:37 PM
    #271
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    That's a really good idea. I think it will sound great. It's not a problem at all and I'm glad to help. Can't wait to see it all done.
  12. Jun 20, 2016 at 7:57 PM
    #272
    hookembevo
    Austin, TX
    Maybe I missed it, but where did you find a spot to mount the crossovers? I pulled off the tweeter grate today and see that there's room in there but it would be hard to get in there to mount them without pulling the whole dash. I was thinking maybe zip ties. I'm really trying not to make any rattles.
  13. Jun 20, 2016 at 8:04 PM
    #273
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    On the drivers side I tucked the left crossover up behind the wires up close to the firewall and the right one I tucked it behind the center console at the floor. There is a perfect little spot for it there. I haven't had any issues with any rattling from either of them.
  14. Jun 21, 2016 at 1:42 AM
    #274
    JasonT87
    JasonT87 Well-Known Member
    Southern California
    '16 TRD Sport DCSB
    Total Chaos mid-travel front. JD Fab SUA rear.
    Do you think there's room to mount 2 crossovers under the center console?
  15. Jun 21, 2016 at 6:40 AM
    #275
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    I think it depends on how big they are. I tired to get both of them in that little nook behind the center console and they wouldn't fit.
  16. Jun 21, 2016 at 8:28 AM
    #276
    wudbuchr
    wudbuchr Well-Known Member
    Linnie
    Lexington, TN
    2016 (7128A) BBP 4x2 - TRD Sport Access Cab
    * Clear Bra (full front) * BBP (8T0) Side Body Molding * Tinted Windows with AWS window shades * Romik Running Boards * Color matched Undercover Lux bed cap and BedRug bed liner * MobTown Locking bed storage doors, Tailgate skin and cap * Chrome Tailgate Script lettering * G-Tec Fab Door Sill Protectors and OEM Mud Guards * Fumoto Valve * ScanGauge-II * LED Interior, Stop, tail, Bed, OPT7 LED H11 low beam and fog lights * WeatherTech floor mats * Clazzio seat Covers * Removed jump-seats & rear seat-belts * Sound deadened back wall, rear posts, rear doors and front doors with a layer of RAAMmat, a layer of Ensolite, and a layer of EzCool * Insulated the roof with two layers of EzCool * GT series Image Dynamics speakers (6x9 fronts, 6.5 rears) * Audio Control DQ-61 DSP, 5-channel amplifier and sub woofer. * Redline Tuning Quick Lift Elite hood struts * Thinkware F770 (Dual) Dashcam with Cellink Battery B * Lexus SmartKey Transmitter and Emergency Key
    Try using velcro instead of quick-ties. it works great.
  17. Jun 21, 2016 at 9:48 AM
    #277
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    You could make a little board to house the crossovers/LOC/Small amp like I did:
    All wired up it fits snuggly under the passenger seat enough where peoples feet won't be mashing on your equipment.
    EB Group, Siblue, surfpops and 2 others like this.
  18. Jun 22, 2016 at 2:21 AM
    #278
    surfpops
    surfpops Well-Known Member
    '16 MGM DC Sport
    What amp is that?
  19. Jun 22, 2016 at 8:50 AM
    #279
    gkomo
    San Diego, CA
    2014 MGM AC SR5 4x4
    Its an Image Dynamics MQ150.2. Powers my front door speakers/tweeters only. Quality little piece... I am an Image Dynamics fan to the core tho.
  20. Jun 22, 2016 at 9:16 AM
    #280
    surfpops
    '16 MGM DC Sport
    Thanks!
