2016 BBP audio build
Discussion in 'Audio & Video' started by Man of Steel TRD, May 2, 2016.
  1. Jan 16, 2017 at 8:05 PM
    #661
    SlowComa666
    SlowComa666 Well-Known Member
    San Antonio TX
    2014 SR5 Access Cab 2WD
    How/Why is this thread a sticky?
  2. Jan 16, 2017 at 10:57 PM
    #662
    Man of Steel TRD
    Man of Steel TRD [OP] Ignorance is the new normal
    Jeremy
    Gilbert, AZ
    2021 Ram Limited Night Edition, 91 300ZXTT, 90 Toyota Pickup ECLB
    Tow package, LED interior lighting, led low beams, led fog lights, led licence plate lights, OEM bed mat, OEM mud flaps, OEM chrome raised tailgate letter inserts, nerf bars, AVS ventshades. Complete Kicker audio system (4 channel amp, mids and tweets in the front, 2 ways in the back, 2 10 inch comp rt subs, Zxsum8, alpine pdx 1.600 boxes and amp rack by Mr Marv), Pop & Lock, Mobtown locking bed storage doors, Bilstein 5100s, Katzkin Leather interior, Redline Hoodstruts, Backflip.
    Didn't know it was. Why do you care?
  3. Jan 17, 2017 at 1:49 AM
    #663
    SlowComa666
    San Antonio TX
    it wouldn't help if i did.
  4. Jan 17, 2017 at 8:05 AM
    #664
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    Well I guess you should not worry about it then and go be a little ray of sunshine somewhere else. :thumbsup:
  5. Jan 17, 2017 at 11:13 AM
    #665
    RugglesTarlek
    RugglesTarlek Well-Known Member
    California
    basic basic basic 14 AC
    Hmm, pictures and clear instructions, plans for sub boxes, factory pinouts, couple of vendors adding good information, buncha guys helping each other out...
    [sarcasm] Yeah, you're right to ask why this is sticky. [/sarcasm]
    OverIt and Man of Steel TRD[OP] like this.
  6. Jan 18, 2017 at 6:08 AM
    #666
    zackdippolito
    zackdippolito Well-Known Member
    zack
    2012 SR5/2014 TRD Sport/2017 TRD Sport 6M
    Probly good for 17 oem radio too? Anyone confirm this?
  7. Jan 18, 2017 at 3:47 PM
    #667
    solscooter
    solscooter Sh!t Outta Luck
    Brian
    Minnesota
    2016 TRD OR DCSB 4x4
    The headunits llok the same as the 16. I'm going to say yes
    Man of Steel TRD[OP] likes this.
  8. Jan 18, 2017 at 3:52 PM
    #668
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    Agreed, the pinouts have been the same for even other gen tacomas. The metra harnesses I used are for older Toyota Tacomas too. As long as you don't have the jbl system
  9. Jan 18, 2017 at 4:03 PM
    #669
    T-rev
    T-rev Resident Mall Crawler
    Tempe, AZ
    2017 TRD Offroad
    I just had everything installed. Still adjusting everything to my liking.
  10. Jan 18, 2017 at 5:42 PM
    #670
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    shit, we never got to meet up. did you end up going with the JL audio stuff?
  11. Jan 18, 2017 at 5:55 PM
    #671
    T-rev
    Tempe, AZ
    2017 TRD Offroad
    Sure did!
  12. Jan 18, 2017 at 6:08 PM
    #672
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    well I'm glad you got it all figured out. sorry I didn't have any time over the weekend.
  13. Jan 18, 2017 at 9:13 PM
    #673
    zackdippolito
    zack
    Thanks boys
  14. Jan 19, 2017 at 1:58 PM
    #674
    RugglesTarlek
    California
    Just realized that I hadn't figured out tweeter mounting plates for my 2014 2nd gen access cab (tweeter in door). So, maybe this'll save someone time if they want to fab up their own plates before tearing into the door.
    Not that you haven't seen this a million times, but here's the tweeter as found:
    For reference as well, the bracket out, and the bracket all alone:
    Now, the template:
    Bigger template here: https://s23.postimg.org/khb495o4b/tweet_template.jpg
    .pdf here: https://www.dropbox.com/s/30jiqupnsq2i46u/tweet template.pdf?dl=0
    If you print it out, and the grid isn't 1/4", then something is wrong. Even so, it's pretty easy to fake it... the center for the tweeter is 1/4" below the line between the two mounting holes. I know I measured it out as being a millimeter off center, but centered would be fine. As far as tolerances go, you'd get away with +1/2" easy on the top and bottom. (There's no lip on the bracket, so no problem overhanging.) I'd stick pretty close to 4-7/16" overall width, though. Clearance holes for the mounting bolts should be 1/4" or maybe 5/16" to give a little wiggle room.
    If anyone wants more dimensions/angles on the drawing, just say so.
    Finally, if you happen to have tweeters that need a 2-1/4" hole, you can just cut the old tweeter out of the plate, as noted by this guy: https://www.youtube.com/watch?v=HEbTl6hFq3M
    Edit to add one last note: I used 1/8" plexiglass for the tweeter adapter plate and had no issues mounting it in front of the bracket. If you go thicker (not sure how thick is "too thick" -- sorry!), then you might need to tuck the entire assembly behind the bracket, which would mean little bit of cutting. (********* has a notch in their plate, for example.)
  15. Jan 23, 2017 at 9:41 PM
    #675
    toyomaniac71
    toyomaniac71 Well-Known Member
    Dave
    Colorado
    16 DCSB Sport
    Toytec 2.0 Boss 2" lift; Fuel Boost 18"; Nitto G2 275/65/18; BAMF Grille
    Have not posted for some time.... loving my system thanks to ALL of your help.
    I'm too old for this stuff.... had to google what a sticky thread was. One of the most helpful threads in my opinion, so well deserved
  16. Jan 24, 2017 at 5:21 AM
    #676
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    Thanks you sir. I'm so glad this has been a help to others. That was my only goal starting it and sharing my experience with my own install.
    OverIt likes this.
  17. Jan 26, 2017 at 6:18 PM
    #677
    Dhannah
    Dhannah 2017 Tacoma OR DCSB
    Daniel
    North Carolina
    '17 DCSB OR TRD 4x4
    Under Construction
    What Head unit are you running?
  18. Jan 26, 2017 at 6:22 PM
    #678
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    The stock entune touchscreen nav head unit. It's so integrated into the truck I didn't want to do an aftermarket head unit. That's why I used the kicker zxsum8 to take the high level signal to low level RCAs.
  19. Jan 26, 2017 at 6:23 PM
    #679
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    Hopefully you were talking to me @Dhannah.
  20. Feb 2, 2017 at 2:05 PM
    #680
    j5Taco
    j5Taco Well-Known Member
    Had a question about adding this LOC SL2 and its wiring to add an amp and sub. I kept getting pointed to this thread so I think that this would help others as dumb as me :D
