2016 BBP audio build
Discussion in 'Audio & Video' started by Man of Steel TRD, May 2, 2016.
  1. Feb 27, 2018 at 2:41 PM
    #821
    vietjdmboi
    vietjdmboi Well-Known Member
    Hieu
    Orange County
    '18 Tacoma TRD Off-Road
    Can anyone confirm that the stock speaker channels produce full range signal?
  2. Mar 11, 2018 at 8:13 AM
    #822
    taco_medic
    taco_medic taco_medic
    Wayne
    lower alabama
    2023 TRD Offroad 4x4
    DoYouEvenMall!!
    Great build page if that’s the right lingo!!?? Awesome knowledge of audio installations by all. Was tempted to install my own amps, processor, and sub with box from @Mr Marv. I was understanding till around page 18-19 then went to full mental block. I don’t understand how y’all process all that info. Not giving up gonna re-read every page and take notes. It’s like I’m back in college. All you audio guys suck!!! JK thanks @1sttruckguy78 for starting this page.
  3. Mar 11, 2018 at 9:01 AM
    #823
    Man of Steel TRD
    Man of Steel TRD [OP] Ignorance is the new normal
    Jeremy
    Gilbert, AZ
    2021 Ram Limited Night Edition, 91 300ZXTT, 90 Toyota Pickup ECLB
    Tow package, LED interior lighting, led low beams, led fog lights, led licence plate lights, OEM bed mat, OEM mud flaps, OEM chrome raised tailgate letter inserts, nerf bars, AVS ventshades. Complete Kicker audio system (4 channel amp, mids and tweets in the front, 2 ways in the back, 2 10 inch comp rt subs, Zxsum8, alpine pdx 1.600 boxes and amp rack by Mr Marv), Pop & Lock, Mobtown locking bed storage doors, Bilstein 5100s, Katzkin Leather interior, Redline Hoodstruts, Backflip.
    No problem. I hope it helps and please don't hesitate to ask if you have any questions. We are all here and like to help out. That's why I took the time to make this thread.
    taco_medic[QUOTED] likes this.
  4. Mar 11, 2018 at 9:03 AM
    #824
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    I can't provide any documentation but it seems to and it seems everyone that has done an audio upgrade with the stock head unit have had good luck and good sounding systems.
  5. Mar 11, 2018 at 9:05 AM
    #825
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    I never posted all my gains. I can snap a pic if you want but depending on your setup it will be different.
  6. Mar 11, 2018 at 9:44 AM
    #826
    taco_medic
    Wayne
    lower alabama
    DoYouEvenMall!!
    @1sttruckguy78 couple of questions. Don’t understand how you get feed from HU to amp/processor then back to HU then to the speakers? Read about meta harnesses suppose to be plug and play but don’t look like it. I bought the speakers from the page about $250 audio build. Started that project and listen to a fuctard and put brackets on upside down so that’s a hold up. Going with a sub either already pre-built or a @Mr Marv box. Do I need two amps one to power the 6 speakers and other amp for sub? And if I need two amps what is the install process on that? Thanks in advance
    Man of Steel TRD[OP] likes this.
  7. Mar 11, 2018 at 10:38 AM
    #827
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    I didn't go from the processor back to the head unit. It is just the output to the processor then the rcas take that signal to my amps. Then speaker wire from the 4 channel amp into the doors. You don't have to have two amps if you don't want to. There are 5 channel amps you can run for everything.
  8. Mar 11, 2018 at 10:51 AM
    #828
    taco_medic
    Wayne
    lower alabama
    DoYouEvenMall!!
    Thanks @1sttruckguy78 for info. I’ll do a search for proper way to use the factory wiring.
  9. Mar 11, 2018 at 10:58 AM
    #829
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    What do you mean?
  10. Mar 11, 2018 at 10:58 AM
    #830
    hookembevo
    hookembevo Well-Known Member
    Austin, TX
    2016 Tacoma DCSB with 6MT
    Snugtop Rebel with some options Body Armor Rock Steps Rhino Mats Weathertech Mudflaps Radar detector hardwired to rear view mirror. Stereo upgrade: Amp: Arc Audio XDI805 LOC: AudioConnect LC7i Front Speakers: Hybrid Audio Technologies Claris 6.5 Rear Speakers: Hybrid Audio Technologies Mirus 5.25 Sub: Pioneer TS-SW2502S4 Box: Pioneer Ud-SW250T Bilstein 5100s OME 885 Springs Single Add-A-Leaf BFG KO2 265/75/16
    Best way is to run speedwire factory head unit to amp, run new wires from amp to speakers. Sounds daunting but not that bad.
  11. Mar 11, 2018 at 11:00 AM
    #831
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    I tried to say this but I guess I wasn't clear. Thanks man for the assist.
  12. Mar 11, 2018 at 11:02 AM
    #832
    taco_medic
    Wayne
    lower alabama
    DoYouEvenMall!!
    I read on a post that you can buy harness that will allow you to hookup from HU to amp/processor then from amp to speaker connections behind HU. Not electrical/audio savvy but have done it before. I have a new truck and don’t want to chop it up. Plug and play is more my speed.
  13. Mar 11, 2018 at 11:03 AM
    #833
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
  14. Mar 11, 2018 at 11:04 AM
    #834
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    It is plug and play and you do not have to cut anything. Just have to run speaker wire into the doors from the amp.
  15. Mar 11, 2018 at 11:04 AM
    #835
    Friedtacolover
    Travis
    Ontario, Ca
  16. Mar 11, 2018 at 11:09 AM
    #836
    taco_medic
    Wayne
    lower alabama
    DoYouEvenMall!!
    Wasn’t being rude @1sttruckguy78 just didn’t understand that post. It sounded like Chinese.
  17. Mar 11, 2018 at 11:10 AM
    #837
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    Oh, I know that sometimes I am not clear enough. No offense taken at all.
  18. Mar 11, 2018 at 11:15 AM
    #838
    taco_medic
    Wayne
    lower alabama
    DoYouEvenMall!!
    Thanks @Friedtacolover but I don’t think that harness from that site will work. I have the Subaru tweeters and read they are hooked up in series to the door speakers. I’m thinking I need to just sell these speakers I bought and go a different route.
  19. Mar 11, 2018 at 11:46 AM
    #839
    Friedtacolover
    Travis
    Ontario, Ca
    I would. I got kicker component 6x9’s and tweeters and placed the crossovers behind kick panels. But either way this is the harness you referenced that you heard about
  20. Mar 11, 2018 at 11:53 AM
    #840
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    I second getting a set of components.
