2016 BBP audio build
Discussion in 'Audio & Video' started by Man of Steel TRD, May 2, 2016.
  1. May 15, 2016 at 12:57 AM
    #121
    surfpops
    surfpops Well-Known Member
    '16 MGM DC Sport
  2. May 15, 2016 at 3:33 AM
    #122
    JasonT87
    JasonT87 Well-Known Member
    Southern California
    '16 TRD Sport DCSB
    Total Chaos mid-travel front. JD Fab SUA rear.
    Definitely would be helpful in a step by step
  3. May 15, 2016 at 6:34 AM
    #123
    toyomaniac71
    toyomaniac71 Well-Known Member
    Dave
    Colorado
    16 DCSB Sport
    Toytec 2.0 Boss 2" lift; Fuel Boost 18"; Nitto G2 275/65/18; BAMF Grille
    Hey Jeremy - I did not recognize the new profile pic. I'm still debating on hiring someone or doing this myself. REALLY anxious to see how your rewire with the Metra harness goes. When I spoke with Mr. Marv I thought he mentioned something having to do some small adjustments with the harness to make sure the Entune system is not affected. Quite honestly, my head was spinning at the time as I could not visualize what he was talking about at the time.
    DEFINITELY turning into a high quality/worthwhile thread here! If you guys can guide a schmuck like me to do my sound system myself, I will be forever grateful. I apologize in advance for any stupid questions I may need to ask.
  4. May 15, 2016 at 6:58 AM
    #124
    neoogeoo
    neoogeoo Well-Known Member
    geo
    2016 mgm taco trd off road
    Billies 5100 ome 885 springs nv wheels w/ duratracs
    Excellent I have all my parts..... so please post pics so I can follow along......I ran the wire for the amp.....my main concern is making the harness
  5. May 15, 2016 at 9:14 AM
    #125
    Mr Marv
    Mr Marv 1-831-383-0308 7am-10pm pst Vendor
    Marv
    Monterey Bay California
    Custom Built Enclosures/speaker adapters etc
    Sorry I haven't had a chance to post this as promised to several guys however Jeremy will most likely do a more detailed job of it anyway! I'll just post a couple of pics of a simple trick I use showing how to easily re-pin the harness for the additional wires and what it should look like. I use a tiny pick tool however a heavy sewing needle works well also...
    The simple trick is to clamp the wire to a bench or in a vise.....
    Stick the pick into the narrow section of the "T" slot contacting the tab that holds the pin in. Push in on the tab and pull up on the plug and the wire will pop out.
    I remove the blue wires (cut off the small jumper wire) and re-pin them to use as the replacement for the additional button light wire and this is what it looks like ready to wire together..
    paxton306, Russtty, surfpops and 2 others like this.
  6. May 15, 2016 at 11:08 AM
    #126
    Man of Steel TRD
    Man of Steel TRD [OP] Ignorance is the new normal
    Jeremy
    Gilbert, AZ
    2021 Ram Limited Night Edition, 91 300ZXTT, 90 Toyota Pickup ECLB
    Tow package, LED interior lighting, led low beams, led fog lights, led licence plate lights, OEM bed mat, OEM mud flaps, OEM chrome raised tailgate letter inserts, nerf bars, AVS ventshades. Complete Kicker audio system (4 channel amp, mids and tweets in the front, 2 ways in the back, 2 10 inch comp rt subs, Zxsum8, alpine pdx 1.600 boxes and amp rack by Mr Marv), Pop & Lock, Mobtown locking bed storage doors, Bilstein 5100s, Katzkin Leather interior, Redline Hoodstruts, Backflip.
    Thanks for posting this Marv!! I was actually going to call you again for the details for the job again before I started on it.
  7. May 15, 2016 at 1:22 PM
    #127
    toyomaniac71
    Dave
    Colorado
    16 DCSB Sport
    Brian - Thank you so much! This pretty much the exact thing I want to do! I am reusing my setup I had in my Mustang that I traded in for my Tacoma - it was hard but the right thing to do. I had it professionally installed but I am inspired to tackle it myself after seeing this thread. I have Focal K2 130KR for my front mid and tweeter http://www.focal-america.com/product/130-kr/ My rear coaxial are Focal k2 130KRC http://w ww.focal-america.com/product/130-krc/
    I don't fully understand the crossover boxes that come with both my front and rear speakers. When you have a sec, could I bother you to draw another wiring diagram with the crossovers included.
    I think I will go ahead and order my Metra harnesses today!
  8. May 15, 2016 at 1:45 PM
    #128
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    Follow his diagram but you will run wire from the amp to the input of the crossovers, they should be clearly marked and there will be 2 clearly marked outputs on the crossovers to go to the mid and the tweeter.
  9. May 15, 2016 at 2:38 PM
    #129
    JasonT87
    Southern California
    '16 TRD Sport DCSB
    Crossovers go between the amp and speakers
    Man of Steel TRD[OP] likes this.
  10. May 15, 2016 at 3:24 PM
    #130
    toyomaniac71
    Dave
    Colorado
    16 DCSB Sport
    Thanks Gentleman - Does it really matter if the crossovers are closer to the amp vs closer to the speakers? Mr. Marv is making a sub box (10" sub) with a amp/LOC rack for me - not sure if there will be enough room to place crossovers there or not. Opting not to place amp/LOC under seats for various reasons.
  11. May 15, 2016 at 3:31 PM
    #131
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    NOTE: THIS IS ONLY FOR THE NON JBL ENTUNE SYSTEM!
    Ok, I just de-pinned the harnesses as @Mr Marv explained above. I will try to go step by step and try not to be confusing. (I feel like I can be sometimes..Sorry everyone) I actually used a dental pick to remove the pins.
    These are the harnesses that plug INTO the back of the head unit and what you have to leave or remove.
    This harness you will completely LEAVE ALONE
    This harness you will remove the two blue wires
    BEFORE
    AFTER
    The next harnesses are going to plug into the harness FROM the truck
    This harness you will REMOVE the PURPLE pair and the GREEN pair and insert the BLUE wire you take out of the next harness coming up.
    BEFORE
    Thelse are the blue wires you remove from the next harness I will show. You will clip the extra wire off where the arrow is pointing in the pic.
    You will insert this wire in the pin location shown
    AFTER
    You will remove the BLUE, WHITE and GREY wires from this harness
    BEFORE
    AFTER
    Hopefully this will clear up any questions about the way the harnesses should be pinned.
  12. May 15, 2016 at 3:33 PM
    #132
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    It doesn't, I just tucked my crossovers away under the dash so I didn't have to run two sets of wires all the way up to the doors and the tweeter location from the back of the truck. If they are at the front of the truck you will only have to run one wire to the crossovers.
  13. May 15, 2016 at 4:34 PM
    #133
    Mr Marv
    Marv
    Nice job Jeremy! :thumbsup: One thing I should mention is that not all of the harnesses come with the orange/black wire as yours did and in those cases you will have to take the other blue wire and put it in that position as seen in the second photo below (no reason for the blue wires other than those were the only 2 of the same color that won't be used)..
  14. May 15, 2016 at 4:45 PM
    #134
    JasonT87
    Southern California
    '16 TRD Sport DCSB
    I wonder if this is the same for both Entune with AND without JBL... @Mr marv do you have the answer?
  15. May 15, 2016 at 4:46 PM
    #135
    Mr Marv
    Marv
    Only WITHOUT the JBL!
  16. May 15, 2016 at 4:47 PM
    #136
    JasonT87
    Southern California
    '16 TRD Sport DCSB
    What is the proper setup for Entune WITH JBL?
  17. May 15, 2016 at 4:50 PM
    #137
    Mr Marv
    Marv
    You will need to take your signal from the output of the factory amp using a processor that has signal summing capabilities due to the processing done in the amp.
  18. May 15, 2016 at 4:53 PM
    #138
    Mr Marv
    Marv
    This is assuming you are trying to add an aftermarket amp!
  19. May 15, 2016 at 5:01 PM
    #139
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    I thought of saying something about that then I figured I would mention it when I did the next step and hooked them all together. Thanks Marv for the help and that. Glad you looked at it just in case something didn't make sense or I messed up on anything. We're a pretty damn good team sir!!
    AgnstAllOdds21 likes this.
  20. May 15, 2016 at 5:01 PM
    #140
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    And thank you for this as well because I didn't know the answer
