2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Oct 18, 2017 at 8:19 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    2016+ OVTune Tacoma 3.5L Manual Transmission 1.03 Calibration Release
    This thread will serve our Manual transmission customers specifically, and will have all of the information regarding our Tune kit and ECU Reflash for the 2016+ Manual transmission 2GR FKS 3.5L Tacoma.
    Our Tacoma Reflash serves two purposes:
    - Bring more power to the Truck safely.
    - Create a better drivers experience
    Things that are changed in our Tune are :
    Engine :
    - Drive By Wire Throttle maps = Enhanced Throttle angle targets (base)
    - Gear Dependent Driver Demand Torque = Tailored Throttle response by gear
    - Torque Control = Finely adjusts the stock Torque request maps
    - Exhaust and Intake Valve VVT = Smoother power delivery, more power, more torque
    - Power Enrichment AF Target = Adjusted Full throttle demand AF to be target from 12.7-12.4 vs stock 11.9x - 10.0
    - Ignition timing - Ignition timing calibrated for better efficiency on higher octane fuel
    - Base D.I. Fire calculation WOT = Adjusted Base D.I. Fire calculation during high load ( smoother WOT fuel transition than stock where it just dumps rich)
    Response:
    Time was taken to tailor Throttle response by gear through various torque target maps to enhance response and create an "instant response" effect on the throttle when you step on the accelerator in gear. This is matched to the base Throttle angle target vs accelerator angle map to create a much faster throttle opening rate. Video below :
    1.03 Release information -
    1.03 map release will come with 3 map options, with 87 octane versions of each.
    Map options will be :
    A- Torque throttling - stock
    B- Torque Throttling - Hybrid (lower gears torque changes adjusted for maximum response. higher gears stock)
    C- Torque Throttling - Peak (all gears adjusted for maximum response)
    - personal notes - this really helped with what I felt was an immediate bog when engaging into 1rst gear from a stop or low speed. This also makes Rev Match downshifting a lot easier.
    Dyno day result:
    Conditions for testing was okay. Dyno room was quite warm (temperature on the screen that I took the pics are not what the dyno is actually recording. Temps were around 87-90*
    Dyno runs were done in 3rd gear.
    Stock result was 211 at the wheels. (however the truck did not have stock wheels. I suspect this affected the result)
    Tune results on the truck were less that I had expected, in comparison to the AT.
    Gains on the low end were still good but not identical to what we have seen before. Gains of average of 10-15ft lbs fro 2200 rpm to 3500 rpm with top end gains being about 4-5hp.
    Note - Peak ignition on these runs was only 21* advance. Not nearly what we have seen as safely possible. Temperature plans a factor here.
    Ideal ignition timing we have found is around 27-28* peak advance at WOT. So we're down 6-7*. Unfortunately that was all the truck would take before knock. Not common with what we have seen on other trucks logs.
    The truck did only have 1000 miles
    Just some ideas to that I am considering why the truck responded less than what was expected.
    AFR on pulls were 12.7-12.4.
    We plan to have the truck back on in a month when it has some more miles
    How it works-
    You will need a mobile pc or tablet with 2 USB ports (or USB splitter) with windows operating system.
    You load our software to your computer, and plug in the tune kit tools.
    Provided in each kit is a software security module (dongle) and OBDII reflash cable.
    The dongle is your LICENSE to use the software.
    Product:
    https://www.ovtuned.com/collections/tacoma/products/toyota-tacoma-2grfks-calibration
    A easy to understand video of how the process works has been created by the user @Dylon so that people can better understand the process :
  2. Oct 18, 2017 at 8:23 PM
    Toytaco2k17
    Toytaco2k17 Well-Known Member
    Kenneth
    Chapmansboro Tn
    2016 Nissan Titan XD Pro4x Diesel
    Stock
  3. Oct 18, 2017 at 8:30 PM
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    :goingcrazy::goingcrazy::goingcrazy::goingcrazy::goingcrazy::goingcrazy::goingcrazy::goingcrazy::goingcrazy::goingcrazy:
    nevadabugle likes this.
  4. Oct 18, 2017 at 8:32 PM
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Been waiting all day for this. :drool:
    AdventureKid and RedBeard1 like this.
  5. Oct 18, 2017 at 8:37 PM
    Axxra
    Axxra Well-Known Member
    NC
    2017 DCSB TRD OR 4x4 6MT
    Ditto. Need some more 87 tune info.
    Roddy13 likes this.
  6. Oct 18, 2017 at 8:38 PM
    nevadabugle
    Elko, NV
    I hope the silly engine breaking letting go at 1400 rpms is gone. If so I am buying immediately.
  7. Oct 18, 2017 at 8:41 PM
    Reluctanse
    Reluctanse Granny shiftin, not double clutchin
    Sam
    Newberg, Oregon
    '17 Tacoma DCSB Inferno TRD OR 6MT
    OVTuned, Grabbers, 5100s, Bakflip VP
    In!
    MOC221_ likes this.
  8. Oct 18, 2017 at 8:43 PM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
  9. Oct 18, 2017 at 8:43 PM
    Av8rJake
    Av8rJake @Cali_Raised_Offroad
    Jake
    Anaheim, CA
    17 TRDOR DCSB MT 1G3 TACO FTW
    2019 Tacoma TRD Offroad 4x4 Black (Shop Truck) 2018 Tundra Platinum 4x4 BBP (Daily) 2018 TRD Offroad Premium 4Runner MGM (Wife's Daily) 2017 TRD Offroad 4x4 Manual Trans (Sold - Worst mistake ever... miss this thing)
    Subb'd...
    I'm itchin to go pick this thing up!!!!!
    Ares32, sphilly28, MOC221_ and 2 others like this.
  10. Oct 18, 2017 at 8:43 PM
    BlakeM
    BlakeM Well-Known Member
    Blake
    Gonzales, LA
    2023 T4R.SR5.4WD.OMG.LOL.WTF
    :playball:
    MOC221_ likes this.
  11. Oct 18, 2017 at 8:53 PM
    nevadabugle
    Elko, NV
    I need to go to bed but I can't wait to see the results.....so I'll have another.:cheers:
    2016trdtacoma and MOC221_ like this.
  12. Oct 18, 2017 at 9:18 PM
    su.b.rat
    su.b.rat broken truck
  13. Oct 18, 2017 at 10:16 PM
    derf77
    derf77 Well-Known Member
    Fred
    South Chesterfield, VA
    2017 TRD DCSB OR MT Silver
    6112's 2.75 in. lift front, Icon UCA's, 5160s w/res, Deaver mini pack in the 1.5 in rear lift, TJM Rock Crawler front Bumper, Baja Squadron Sport lights, TJM Rock crawler lights, SPOD w/touchscreen, Rokblokz rear mud flaps, Method NV Wheels, 285/70R17 Nitto Ridge Grapplers
    SOLD OUT!
    Greeny and stealthmode like this.
  14. Oct 18, 2017 at 10:39 PM
    RedlineTRD
    RedlineTRD Well-Known Member
    Kyle
    Peyton, Colorado
    2017 Tacoma TRD OR DCSB MT
    Working on it.
    Excited to see the numbers.
    MOC221_ likes this.
  15. Oct 18, 2017 at 11:54 PM
    JackSmith
    JackSmith Well-Known Member
    Tony
    SJC, CA
    '16 TRD OR DCSB 4x4 Manual
    Thanks for loaning your truck.
    su.b.rat and MOC221_ like this.
  16. Oct 19, 2017 at 12:40 AM
    beers@1600
    beers@1600 Well-Known Member
    North Carolina (some of the time)
    2017 TRD OR DCSB MT 4x4 MGM
  17. Oct 19, 2017 at 12:43 AM
    bodean
    bodean Well-Known Member
    Shawn
    Crowsnest Pass, AB
    02 Taco RCSB, 16 Taco AC6MT, 07 FJC, 22 Bronco
    Sub’d
  18. Oct 19, 2017 at 1:01 AM
    0331
    0331 Well-Known Member
    Seattle
    16' DCSB TRD OR 6MT
    But will it let me fit 285’s?
    In all seriousness... looks cool, looking forward to seeing results!
    Boxerocks and MOC221_ like this.
  19. Oct 19, 2017 at 2:34 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    :woot:
    @OVTune , what do you have in mind WRT a release schedule, and do you see any delays porting the tune to different ECU versions?
    Ares32 likes this.
  20. Oct 19, 2017 at 2:36 AM
    MOC221_
    Frank
    Right on man :cheers:
    Mods, we have a nominee for member of the year^^^^^^^
    Av8rJake[QUOTED] likes this.
Thread Status:
