2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Feb 21, 2018 at 11:22 AM
    #2461
    Shellshock
    Iowa
    I noticed it today on mine. It seems to happen under gradual acceleration. In city driving.
    Happens on my truck almost right at 2500 rpm.
  2. Feb 21, 2018 at 11:37 AM
    #2462
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    Hum, wonder what might be causing this.
    I hope to have mine flashed ASAP (I get my kit today) and I can offer some feedback as well. My truck is a 16
  3. Feb 21, 2018 at 12:09 PM
    #2463
    Shellshock
    Iowa
    Yea it’s kinda weird. Im guessing mat just needs to tweak something. I dont notice it cruising, only while accelerating and only in like 2nd and 3rd gear.
  4. Feb 21, 2018 at 12:25 PM
    #2464
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    It's the worst on mine in the 2000-3000rpm band. On my way home today, I was accelerating up a long hill on the highway in 4th and the truck was stuttering a lot. Not really deep into the throttle either. I'm currently running the 87 tune, because I thought it might have been a fuel issue causing the stutter while on the 91 file. Nope, they both do it.
    For shits n giggles I went out for another trip and this time logged the results. Weird thing was, at the time index where I re-created the stutter I did not see any misfires (using OBD fusion and monitoring the Toyota PID all cylinders misfire count).
    Other than this issue, the tune is fantastic. Man, so close...
    2016trdtacoma likes this.
  5. Feb 21, 2018 at 12:28 PM
    #2465
    2016trdtacoma
    Trevor
    Utah
    Wonder why this issue would surface all of a sudden.
  6. Feb 21, 2018 at 12:40 PM
    #2466
    MontysTruck
    MontysTruck Well-Known Member
    2017 Tacoma TRD Pro
    likely due to the ECU learning
  7. Feb 21, 2018 at 12:45 PM
    #2467
    Shellshock
    Iowa
    Likely because we are now starting to drive a little more reasonable instead of just driving like a bunch of crazies with all this new power on test drives.
    iexc, MOC221_ and mZiggy like this.
  8. Feb 21, 2018 at 12:48 PM
    #2468
    Shellshock
    Iowa
    So close but Ill take a little stutter over the anemic and pathetic stock tune
    iexc, 2016trdtacoma and JJ18ORDBSBMT like this.
  9. Feb 21, 2018 at 12:48 PM
    #2469
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    This is probably exactly it.
    I did already plan to put up another small review after a week or so with some more thoughts once my driving style has adjusted more and with anything I/we may have noticed.
    For now I'm still convinced that I was either imagining it or it was perhaps related to my driving off immediately after starting the truck, before it had warmed up, but I'll mention it even if I can't replicate it myself again .This many people bringing it up means something is there most likely .
    MOC221_ likes this.
  10. Feb 21, 2018 at 2:19 PM
    #2470
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    May be from another issue. I've seen this when water is present in the fuel. If the problem returns reload the stock tune and see if the problem goes away.
  11. Feb 21, 2018 at 2:31 PM
    #2471
    Shellshock
    Iowa
    One thing i really miss about my 2005 is no matter what fuel i put in, the truck always performed the same and fuel economy was consistent no matter what you did. The third gen is a princess and believes it should only have the best fuel. If you dont, it’ll either have weird issues or crap mpg or both. Mine is always unhappy in South Dakota.
    taco 16 and MOC221_ like this.
  12. Feb 21, 2018 at 2:36 PM
    #2472
    2016trdtacoma
    Trevor
    Utah
    Got my kit and sent dongle serial number to @OVTune 5 minutes ago. Hope to have the activation key soon and I'll be tuned!
    Livinserene likes this.
  13. Feb 21, 2018 at 2:49 PM
    #2473
    MOC221_
    Frank
    I've had hesitations or stutters since day one with my truck.
    On the stock tune (which I will never allow back into my ECU unless absolutely necessary), they were really only noticeable if you were loading the engine on a long steady grade at lower rpms (~1500 - 1800). They could be lessened somewhat with premium E0 fuel.
    Every tune version I've run since has given me stutters to a varying degree, but they were far less noticeable than with 1.03B 91 and 87 in the rpm range specified (2000-3000). I'm thinking @Shellshock is right, I for one was enjoying the extra power - but as the mundane daily drive becomes routine again, you begin to hone in on things you maybe didn't see or didn't want to see.
    I'm not discounting your theory outright @Ruggybuggy , it's just that I went from running 1.03 04B10 test tune to 1.03B on the same tank. Now my stutters are noticeably worse.
    Edit: I know I said in an earlier post that I switched to the 87 file to eliminate a possible fuel issue - my thinking on that was centered around the fact that previous tunes for my ECU didn't respond well to ignition mapping changes, and 1.03B is supposed to have major changes to ignition. SInce an 87 tune SHOULD be far less aggressive in that area, I thought I'd go that route and see if anything changed. TL;DR - shitty 91 fuel that's not quite 91 should work ok on 87 file.
  14. Feb 21, 2018 at 3:45 PM
    #2474
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    1200-2500 rpm, low throttle... this sounds like when the engine is in atkinson
  15. Feb 21, 2018 at 3:52 PM
    #2475
    17TRDOR
    17TRDOR Well-Known Member
    Ron
    Richmond Va.
    2017 MGM TRD off road
    3 inches, Ray10s, 34s, OVTuning, and driver mod for now.
    I don't know this Atkinson guy but he sounds hideous!
  16. Feb 21, 2018 at 3:52 PM
    #2476
    su.b.rat
    su.b.rat broken truck
    does this relate to roughness and/or stuttering? particularly when cold?
    MOC221_ likes this.
  17. Feb 21, 2018 at 3:53 PM
    #2477
    redaccount36
    redaccount36 Well-Known Member
    2017 DCSB Silver Limited
    Yep basically he only wants you to eat bacon and drink half-and-half. No cookies or cakes or bread.
  18. Feb 21, 2018 at 3:57 PM
    #2478
    su.b.rat
    lol. got it!
  19. Feb 21, 2018 at 4:01 PM
    #2479
    OVTune
    OVTune
    very likely, but something also important to know is that the ECU uses different mapping depending on the engine temperature for a lot of things, and when it's cold is when it performs the worst.
    su.b.rat[QUOTED] likes this.
  20. Feb 21, 2018 at 4:02 PM
    #2480
    su.b.rat
    that is fully evident over here, and i think many who have already reported would agree 100% with that. it's hard to control when cold and with ice, which has been the last 2-3 days.
Thread Status:
