2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Feb 21, 2018 at 8:27 PM
    #2501
    venezian
    venezian Well-Known Member
    Los Angeles
    2022 7545E
    I went the other way.. 14.2 stock tune and now at 15.9.. 100% City
    2016trdtacoma likes this.
  2. Feb 21, 2018 at 8:33 PM
    #2502
    JJ18ORDBSBMT
    JJ18ORDBSBMT Well-Known Member
    1.05 FOB 91 2018 Off road White DC M/T
    That’s solid. I’m prob 50/50. Filled up the tank this AM.
  3. Feb 21, 2018 at 8:38 PM
    #2503
    NerdTaco
    NerdTaco Well-Known Member
    Which is weird to me since the engine is smaller and the transmission has an extra gear.
  4. Feb 21, 2018 at 9:09 PM
    #2504
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    It will still take roughly the same amount of energy (fuel) to move both the old and new Tacoma. Both trucks are about the same weight. The advantage of the 3.5 is that its slightly more efficient so more of that energy is used to move the truck forward, the reason the new Tacoma is better on fuel but only when driven conservatively.
    Tharris242 likes this.
  5. Feb 21, 2018 at 9:09 PM
    #2505
    luminous
    luminous Well-Known Member
    Make the user click a button that says OV is not responsible for any damage by manually editing the files. Removes all liability. Lots of us have a background in tuning and prefer to fine tune a generic map for our specific car/truck. I have two 675cc engines (3 cyl, triumph daytona) that are built identically, but the ignition and fueling maps are different enough that running the same tune on either reduces power/doesnt run as well on the one that it wasnt developed for. Granted these are race engines and every single hp matters, but the same concept applies for all engines they are all slightly different. The ECU does a fairly good job of trimming out those differences but the closer the base tune is the better off the ECUs logic is at getting it right, there are also typically limits set to how far the ECU can actually adjust itself as well. Elevation also plays a massive role, the base tune of an engine at 5k feet will be very different then at 0ft.
    Personally the moment that editor is released is the day I rent out a dyno for a few hours and start fine tuning to my specific truck.
  6. Feb 21, 2018 at 9:18 PM
    #2506
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Yes thats all and well for you but the mass amount of people on the forum won't understand the fundamentals of tuning. I can see bad things happening.
    2016trdtacoma and MOC221_ like this.
  7. Feb 21, 2018 at 10:28 PM
    #2507
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    I’m forever on the fence for this tune as I’ve had bad luck with tunes in the past, but it blows me away people are getting sub-16.5 mpg. That’s the lowest I see in gridlock Hawaii traffic (1-1.5 hours to go <15 miles) on 33” ATs.
    Interested to see how a non-Atkinson cycle works out if it’s developed. This engine leaves a lot to be desired under 3,000 RPM.
  8. Feb 21, 2018 at 10:31 PM
    #2508
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Bad luck with Toyota Tacoma 3.5 tunes? Or......?
  9. Feb 21, 2018 at 10:54 PM
    #2509
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    Other vehicles. I’m just letting everyone else get the kinks out for this one :p
    jbruce likes this.
  10. Feb 21, 2018 at 11:07 PM
    #2510
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    I can confirm this
  11. Feb 21, 2018 at 11:10 PM
    #2511
    dYL0n
    Dyl0n
    New Orleans, LA
    :boom:
    Oh, you’re welcome.
    :cool:
    F*ck yes me too!
    Most NA vehicles; the time to shine is when it’s cold weather, not this bastard.
    JJ18ORDBSBMT and kakwvu[QUOTED] like this.
  12. Feb 22, 2018 at 3:17 AM
    #2512
    tekoma
    tekoma Member
    Apex, NC
    24 Tacoma TRD Off Road Manual
    Method MR318 17x8.5 Bronze BF Goodrich KO3 285/70R17 XPEL Partial PPF XPEL 70% tint windshield XPEL 35% tint front sides
    I have a 1.5 mile commute. Average fuel economy 13.5mpg. No change after tune, just get there faster
  13. Feb 22, 2018 at 3:31 AM
    #2513
    tekoma
    tekoma Member
    Apex, NC
    I echo the surge/hesitation between 2500-3000 rpm. 93 octane fuel, 87 tune, warm engine, 70 degrees F outside temp. Didn’t notice it until spending time on the highway. I too thought I was on a bumpy section of road, it’s a sine wave feeling of surging. It was most notable when holding the throttle at exactly 3000 RPM in 5th gear (75 mph) or 3rd gear (50 mph). I was able to actually hear the surging when holding 3rd at 3000. I was unable to replicate using cruise control.
    Still thrilled with the off the line acceleration, but as others have said now that I’m not deep in the throttle, I can feel the surging under normal acceleration between 2500-3000 rpm. Again, definitely more noticeable holding the rpm at a steady speed, don’t feel it at all coasting, under heavy throttle, or above 3k rpm.
    Hope this can be resolved. I can imagine long trips on the highway could get annoying.
  14. Feb 22, 2018 at 3:49 AM
    #2514
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Exactly^^
    @OVTune, I emailed you a log file output (.CSV) from OBD Fusion WRT my drive to work this morning. I tried to hold at the RPM/throttle where my truck was surging as long as possible, but alas - traffic lol.
    Again, the all cylinders misfire count was ZERO during the worst of the stutters - but I did get some when at cold idle and again at the end of my drive (parking the truck at work and hot idle).
    Thanks,
    Frank
  15. Feb 22, 2018 at 3:55 AM
    #2515
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Go back to your stock tune and see if it goes away. I have a 18 and have no surging whatsoever. I've tried too duplicate what some were complaining about and did notice any issue.
  16. Feb 22, 2018 at 3:57 AM
    #2516
    MOC221_
    Frank
    I agree with this.
    If you want to play with the tune yourself and know what you're doing, maybe email Mat and ask for an editor. He could ask a few questions and have you take full responsibility for your own fuck ups via EULA etc.
    I wouldn't offer it to the masses though. Bad stuff will happen, and you JUST KNOW if someone blows their shit up and Toyota says FUCK YOU, there are idiots who won't take responsibility and will try to go after OVtune.
    It's the world we live in these days.
  17. Feb 22, 2018 at 4:42 AM
    #2517
    dYL0n
    Dyl0n
    New Orleans, LA
    And he’ll be like “the EULA you agreed to says don’t touch me bro”
    APR (a popular VW/Audi tune) came out with this thing called APR+. It’s where they have an agreement with VW to tune a vehicle and still be covered by the dealer. It’s just a milder tune than the ones that’s usually sold.
  18. Feb 22, 2018 at 4:56 AM
    #2518
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Well I guess that would work for VW/Audi since they really don't give a rat's ass about emissions.
    dYL0n[QUOTED] likes this.
  19. Feb 22, 2018 at 5:27 AM
    #2519
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    Hum, I hope this does get figures out. Just got my kit so I'm almost ready to flash. Would be a bummer if this is a mostly universal issue.
  20. Feb 22, 2018 at 6:20 AM
    #2520
    Shellshock
    Iowa
    I’m sure it’ll get sorted out. I’m not worried
Thread Status:
