2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Feb 23, 2018 at 5:54 PM
    #2621
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    there is a exe in there (techstream one) replace the installed one with it
    I'll show you guys once I have some time
    2016trdtacoma likes this.
  2. Feb 23, 2018 at 5:55 PM
    #2622
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    @OVTune can you check on my dongle registration when you get a free minute or two??
    #2403
  3. Feb 23, 2018 at 5:56 PM
    #2623
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    I mean, kudos to @OVTune for his amazing work. He dialed it in so well, we now need a bit softer file. #6MTproblems :)
    I just want to leave my dads and go drive LOLOL, but alas, need to visit for a bit :)
    edit. I say I need to visit yet im refreshing this page every 30 seconds :rofl:
    su.b.rat likes this.
  4. Feb 23, 2018 at 5:58 PM
    #2624
    Shellshock
    Iowa
    Definitely not an issue I ever expected to have with this truck lol
  5. Feb 23, 2018 at 6:01 PM
    #2625
    2016trdtacoma
    Trevor
    Utah
    Ya, tell me about it! This is a great problem to have. I guess in the mean time I will have to use a higher gear so I don't break it loose and start drifting on the street. Good thing for traction control :)
    MOC221_ likes this.
  6. Feb 23, 2018 at 6:02 PM
    #2626
    su.b.rat
    su.b.rat broken truck
    seriously, no actual complaints over here... just helping along development and getting what we paid for. all good. happy camper. but this traction/throttle issue...
    lol
    MOC221_ and 2016trdtacoma like this.
  7. Feb 23, 2018 at 6:04 PM
    #2627
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    That’s where I’m lost.
  8. Feb 23, 2018 at 6:10 PM
    #2628
    Frank_Zuccarini
    Frank_Zuccarini Obscure Member
    Frank
    Chicagoland
    AC-TRD-OR-4x4-Barcelona Red
    I got the .rar file to download just fine, and then had to download a trial version of WinZip in order to unzip the .rar. The long key password worked fine, but as I said, I could not get it to work, so I can't help you. Very, very frustrating. Spent WAY too long trying.
    Sorry.................Frank
  9. Feb 23, 2018 at 6:11 PM
    #2629
    Shellshock
    Iowa
    The thought crossed my mind the other day that maybe I should put on bigger tires now that the trucks got plenty of power… this is the curse of tacomaworld
  10. Feb 23, 2018 at 6:12 PM
    #2630
    Shellshock
    Iowa
    Now there’s two franks in this thread and I keep getting confused when it’s not @MOC221_
    MOC221_ likes this.
  11. Feb 23, 2018 at 8:18 PM
    #2631
    2016trdtacoma
    Trevor
    Utah
    Ok, back home:
    I was able to drive at a fairly constant 60-65 mph (roads where still wet and slushy in spots) I drove in 6th gear as soon as I got up to freeway speeds and stayed there until I exited. Truck held speed and rpm's very well and mild acceleration was great (granted I was only about 2100-2200 rpm's going 60-65 so when I did accelerate a bit, it was not a huge jump as I was not in the power bad) but it did pull nicely and consistently.
    I did accelerate hard a few times a when the rpm's were around 2k-2100 @ 60 mph: Truck felt good with good pull and response. Acceleration and pull were not cray as the rpm's were still slightly low, but was very nice.
    @OVTune : The low end response/map/ or what-have-you, 100% needs attention. While I was leaving my dads neighborhood (roads still wet and mildly icy), she broke loose VERY easily. Traction control kicked in more or less instantly and I had to quickly shift into 2nd to maintain forward momentum and in one spot I had to shift fairly quickly from 2nd to 3rd (very mild to normal throttle input).
    I hope the torque and power down low do not change (only for the better :) ) if/when 1.03b get looked at again, but it most definitely needs some tweaking, but it does seem like the throttle response low is the culprit.
    I am trying to be as clean and detailed as I can about this but if you have any questions Matt, feel free to PM me and I will do my very best to offer as much feedback as I can to help.
    I made an effort to shift through the 2-3k band where some were experiencing some shuttering/hesitation. I was not able to experience any at this point but I made sure to shift into 3rd while still accelerating modestly and then into 4th. I will continue to test this on my way to and from work tomorrow.
    I am also going to try and get to an area about an hour away that has some off road areas to play in to test 4lo/4high/locked, etc if there is not an over abundance of snow (pretty sure I still will try a little while I'm out there :) ).
    More to come...
  12. Feb 23, 2018 at 8:46 PM
    #2632
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    @OVTune I know I wouldn't mind if you dialed back the throttle a bit. It's not something you don't get used to, but it is just a hair on the obnoxious side. Plus, it's not a race truck, so it's no biggie I think if it's not a rocket off the line. That's what the twin turbo kit will be for lol and even with that it would be nice for it to be nicely drivable
  13. Feb 23, 2018 at 9:12 PM
    #2633
    nxcess
    nxcess Well-Known Member
    '17 Tacoma MT 4x4
    OVTuned
    Drive it like you stole it. I like how the throttle feels. I’ve driven about 200 miles so far. Much better than stock where I had to floor it and wind 1st & 2nd to have some semblance of acceleration.
    BallsDeep09 likes this.
  14. Feb 23, 2018 at 9:14 PM
    #2634
    2016trdtacoma
    Trevor
    Utah
    I agree, but when I got to accelerate with very mild throttle and it breaks loose in conditions that it never had before, I feel its a tad too aggressive. This I'm sure will be a difficult balance for Matt as some will like it and other would like a milder feel. I'm sure a balance could be found.
  15. Feb 24, 2018 at 1:40 AM
    #2635
    17TRDOR
    17TRDOR Well-Known Member
    Ron
    Richmond Va.
    2017 MGM TRD off road
    3 inches, Ray10s, 34s, OVTuning, and driver mod for now.
    I think the throttle sensitivity isn't terrible in my opinion, it makes the 34s get their ass moving appropriately. Obviously I have not had the truck off road yet and we're pretty much done with snow here in Central Virginia.
    iexc likes this.
  16. Feb 24, 2018 at 4:58 AM
    #2636
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    I'm the Cray Cray one :thumbsup:
    Gotta go put some more kms on the truck and see if the stutters calm down.
    Did those A/T clowns get 1.03?
    JK :mudding:
    2016trdtacoma and TRDOBSESSED like this.
  17. Feb 24, 2018 at 5:16 AM
    #2637
    MOC221_
    Frank
    Oh and, in for a throttle tweak if Mat is around this weekend :)
    Sorry guys, I don't wanna sound too "nitpicky".
    mZiggy and Ares32 like this.
  18. Feb 24, 2018 at 5:50 AM
    #2638
    2016trdtacoma
    Trevor
    Utah
    Truck felt good on my normal 7.6 mile drive to work this morning. I can actually use 5th and 6th now around 40-50 mph without the truck feeling anemic and dead. I usually use 4th to keep power avaliable, but I was able to keep it in 5th or 6th for the entire drive once I got up to speed.
    All I want to do is go drive and find new roads to play/test this tune out. Working for Costco has amazing benifit, working on most Saturday is certainly not one of them.
    MOC221_ and nxcess like this.
  19. Feb 24, 2018 at 5:57 AM
    #2639
    Ares32
    Ares32 Well-Known Member
    America
    2016 MGM TRD off road DCSB M/T
    Just to report back from a 04B10 perspective. Throttle is touchy but I personnel like the feel. When lifting off the throttle from a hard acceleration I have a slight clunk but it seems like it's getting better. When parked and idling I can see my RPMs jumping slightly. I'd say some slight adjustments would take care of all these items. Over all I'm one happy ass 04B10 owner!
  20. Feb 24, 2018 at 6:09 AM
    #2640
    RedBeard1
    Red
    All you guys be like :burnrubber:
    I’m over here at work like :notsure: waiting for my registration key...lol
Thread Status:
