2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Feb 24, 2018 at 9:11 AM
    #2661
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    I can say that this seems to be right on. I let my truck idle for 5 minutes after flash, turned off the truck, then started it and went for a drive. I do not have any idle issues thus far. Idle sits solidly about 6-700 rpm when warm.
    I'll use my OBD to minutes it more closely.
    MOC221_ likes this.
  2. Feb 24, 2018 at 9:12 AM
    #2662
    2016trdtacoma
    Trevor
    Utah
    I'm pretty sure I'll be going to my off road area after work to test 4lo. I'll try and get some video clips and keep a close eye and ear on how things react.
    MOC221_ likes this.
  3. Feb 24, 2018 at 9:19 AM
    #2663
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    I was going to call BS on this, or call it a one off, but I took a couple of 40 mile drives today and I didn't feel a damn thing. Well, maybe something very slight, but nothing I could attribute directly to the tune. The weird thing is the surge was present on my way home from work last night, but I am now right around that 400 mile mark, and I filled up with a fresh tank of 87 this morning.
    I'm going to reserve final judgement once I drive it more, but I think the ECU has compensated for something. Why it happened overnight is a mystery.
    2016trdtacoma and MOC221_ like this.
  4. Feb 24, 2018 at 9:20 AM
    #2664
    Shellshock
    Iowa
    Another 90 miles or so on mine and still not having the 2-3k rpm issue again
    JJ18ORDBSBMT and MOC221_ like this.
  5. Feb 24, 2018 at 9:25 AM
    #2665
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    :fingerscrossed::fingerscrossed::fingerscrossed: I hope the same happens with my truck, because this stutter is starting to really annoy me on the highway!
    Thanks for posting guys :)
  6. Feb 24, 2018 at 10:40 AM
    #2666
    scareurpasenger
    scareurpasenger Well-Known Member
    Roswell, ga
    2022 TRD Pro MT
    I guess some have more luck. My stuttering at ~2500 isn’t as bad but is noticeable enough for passengers to comment on it.
    Looking forward to the reduced throttle version, I think that will make this more fun to drive smoothly. It should also highlight the power when full throttle better.
    2016trdtacoma likes this.
  7. Feb 24, 2018 at 10:42 AM
    #2667
    MOC221_
    Frank
    UPDATE (edited 28/02/18) - While everything below was true at the time, the stutters have returned.
    Took Mat's advice and let the truck go to school at idle. Cold to operating temp, didn't touch a thing and it took about 20 min to get there.
    First thing I tried after that was 4lo 1st gear to see if the surging was gone - it was. Deleted my previous post with that video. You gotta understand, it was doing the surge yesterday.
    Highway drive revealed that the obvious stutter/surge from 2000-3000rpm was either gone or I couldn't notice it over the bumpy damn roads!
    Notes:
    1. I'm still on the same tank as before, 91 E0 gas;
    2. 1.03B 87 loaded;
    3. Mileage since last flash - exact distance unknown, but definitely less than 400 miles.
    4. Weather here today is sunny and +8 Deg C - that's quite a bit warmer than the last few days.
    Now, I'm not going to say with any kind of certainty that the idle learning did the trick, or if it was that in combination with the miles of driving. Something changed, and it was definitely for the better.
    I'm now going to flash the 91 tune again and start over (I know, fucked right?).
    Two reasons:
    1. I want to further prove/disprove this idle learning hypothesis and reset all the variables; and
    2. I like the 91 tune better :)
    Oh, and my low fuel light is on but I'm not going to add any gas just yet (don't want to add variables).
    Edit: Flash to 91 file complete, now waiting for the truck to cool off, so it can learn not to be retarded from stone cold. Tick tock lol
  8. Feb 24, 2018 at 10:44 AM
    #2668
    2016trdtacoma
    Trevor
    Utah
    Very good to hear. I will give this a go as well later tonight or in the morning. I'm not experiencing these issues as of now, but perhaps this will help them not start at all.
    nxcess and MOC221_[QUOTED] like this.
  9. Feb 24, 2018 at 11:30 AM
    #2669
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Hey Matt something I noticed. I hooked up the Toyota techstream to clear the codes from flashing and the techstream could not clear them. I got a unsuccessful code clearing window. Tried it a couple of times and gave up. Did another health check and the codes were gone. ???
  10. Feb 24, 2018 at 11:50 AM
    #2670
    Livinserene
    Livinserene Thejerkyguy
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
    Hopefully not before tues,, I want to experience this ,,,
    2016trdtacoma and RedBeard1 like this.
  11. Feb 24, 2018 at 11:52 AM
    #2671
    Livinserene
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
    Hopefully makes a separate file so we have an option ,,
    2016trdtacoma[QUOTED] likes this.
  12. Feb 24, 2018 at 1:04 PM
    #2672
    2016trdtacoma
    Trevor
    Utah
    I'm betting he will. I'm no tuner expert, but I'm sure its a fairly easy fix for him.
    Don't get me wrong, it's freaking amazing. Perhaps it will mellow off after some miles, but man, it's so responsive and gritty, in a great way
  13. Feb 24, 2018 at 1:15 PM
    #2673
    Boxerocks
    Boxerocks Well-Known Member
    Washington State
    2017 Tacoma TRD Sport DCSB Manual
    OV Tuned, OME 887 coils, Headstrong 3 leaf AAL, Bilstein 5100's, JBA uca's, Level8 MK6 wheels, BFG KO2's 275/70R17, mesh front grill, Rally Armor mudflaps
    @OVTune I'm having some trouble with the files downloaded from the flash manager. I was able to download flash manager from the link you posted in here a couple days ago, and I downloaded the 1.03B files from there (both 87 and 91 octane) but PCM keeps giving me the error message below when I try to write either of them to the ECU. It will still let me write any of the older versions that I had previously, it just won't work with any of the ones downloaded from the new flash manager, any ideas?
    Thanks
  14. Feb 24, 2018 at 1:23 PM
    #2674
    fzj40
    fzj40 Well-Known Member
    R
    2017 TRD OR MGM 6MT
    I love the throttle, and I'm still running a PC set on sport. Can't imagine turning it down - but then again I have been running AC non-stop. Hottest February on record here in FL.
    2016trdtacoma and Boxerocks like this.
  15. Feb 24, 2018 at 2:28 PM
    #2675
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    Come on clock tick your way to 19:00...
    Needz this tune installed!
  16. Feb 24, 2018 at 3:14 PM
    #2676
    MOC221_
    Frank
    UPDATE ON 1.03B STUTTER ISSUE - FIXED
    Well gents, in MY CASE I can call the 400 mile learning thing busted.
    As eluded to in my previous post, I wanted to start fresh with the 91 tune and try again. So, after flashing with that file again and allowing the truck to cool off completely, I started it back up sat at idle until fully up to temp (~20 min). I did not touch the throttle or anything that would cause the rpm to change during that period(ie brakes/HVAC controls/steering). Once warmed up, I slowly brought the rpms up and held them at various points such as 1000, 1500, 2000, 2500 to see if the engine would surge as it had before - nope.
    Got on the road, and to my absolute delight the truck was pulling very smoothly after only ~20 km. Got out on the highway and re-created the same conditions where I had severe stuttering before, now I really have a hard time discerning between bumps in the road and maybe a slight hesitation or two. I'll attribute that to the truck still learning a few things.
    The only odd thing I feel now is the slight clunk on lift, and maybe a little weirdness a hair before that (while I'm backing off).
    Total distance covered 78km - It was fine way before that, but I was having fun!
    Anyway, really glad I flashed back to the 91 file. The difference on the highway pulling in 6th is just awesome :)
    TL;DR - Right after flashing your truck, start and let it idle for at least 10 min from cold and don't touch it (according to Mat's posts). It really does need to learn that FIRST.
    AS it turns out, following Mat's advice to the letter works.... :hattip:
  17. Feb 24, 2018 at 3:21 PM
    #2677
    2016trdtacoma
    Trevor
    Utah
    Heading out to do a little 4 low driving I'll report back ASAP
    MOC221_ likes this.
  18. Feb 24, 2018 at 4:18 PM
    #2678
    Livinserene
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
    COME ON TUESDAY!!!!
  19. Feb 24, 2018 at 4:22 PM
    #2679
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    pedal commander AND 1.03B??
    pm me your email I can send you the files directly
    MOC221_ likes this.
  20. Feb 24, 2018 at 4:36 PM
    #2680
    Boxerocks
    Washington State
    Sounds great to me! Personally I don't think it would be possible to make the throttle response too quick for my taste on this truck, I'll take it turned up as much as possible!
    PM sent, just wasn't sure if I was overlooking some minor step or if I actually had a problem with my download
Thread Status:
