2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Feb 25, 2018 at 10:01 AM
    #2701
    Shellshock
    Iowa
    Did another 250 miles. Aside from the throttle being too touchy for my liking I don’t really have anything to complain about. I haven’t had any more weird stutters. I thought about reflashing and letting it idle to see if I notice any difference but at this point I don’t really see a need to and it’s cold outside.
    MPG have been pretty much the same as before. Last fill up was 19.7 mpg over 253 miles which is pretty good considering the weather and winter blend fuels.
    The in dash calculations have been all over the place. For a while it was like 2 mpg low then last tank it was about 1 mpg high. I’ve never really trusted it’s accuracy but seems to be off a little more than before.
    MOC221_ and 2016trdtacoma like this.
  2. Feb 25, 2018 at 11:06 AM
    #2702
    Frostbyte
    Frostbyte Well-Known Member
    Northern Utah
    18 Super White TRD OR Manual
    SOLD - 03 Black SR5 4x4 TRD OR RIP - 07 Radiant Red SR5 4x4 TRD Sport Fabtech 6" lift, 33x12.50.18 Toyo M/T on All black XD Hoss wheels
    With the new low end torque everyone is talking about, what is the winter/wet driving like? Granted I just got my 18, and it has 150ish miles on it, winter wet driving is half the year (usually) in northern Utah. The nice throttle response and low end kick of torque, I imagine to be terrifying to drive in the weather.
  3. Feb 25, 2018 at 11:27 AM
    #2703
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    So not going to sugar coat it, it is a little scary. I live in Utah as well so I have some experience driving pre-tune and post.
    I was on the freeway heading to my dads from Sandy to Woodcross. It was snowing as as I got further past SLC, the roads were getting worse. I was in 3rd gear( which is damn amazing at low speeds now) and as traffic was speeding up, I gave it some more throttle and break the end loose with what I considered not much input.
    Now, with that being said, the roads were slushy and appeared to be getting icy or were already slightly so. For full disclosure, I was wearing heavy work boots and that could be playing a role in how I feel the pedal etc....
    Another note to consider: I have been driving this with stock tune for 20k miles and have been use to the gutless and anemic response of the stock tune. So, being that it is awake now, I most likely am not use to the response and power that is available now.
    I found that being able to drive in a higher gear now helped tremendously with that issue, so I used 4th gear at about 30 mph and about 1k rpm's and it was very, very nice in those conditions.
    With the upcoming storms on the horizon her this week, I will have plenty of opportunites to test this more and plan on doing so.
    Matt said he was going to release a milder tune to help alleviate some of that, but I will stay with 1.03b for some time and get use to driving a truck with power :)
  4. Feb 25, 2018 at 11:37 AM
    #2704
    iPaint
    iPaint Well-Known Member
    Nebraska
    2017 TRD OR DC 4x4 AT
    We recently had some ice and snow. I didn’t put a lot of miles on in it but it was far from terrifying with a slightly taller tire than stock (265/70R17).
    If the torque has become too terrifying then just try a taller tire.
    :mudding:
    2016trdtacoma likes this.
  5. Feb 25, 2018 at 11:45 AM
    #2705
    fmfdadbod88
    fmfdadbod88 Well-Known Member
    2016 Black Tacoma TRD Off Road 4x4
    I successfully downloaded and flash 1.03b 87 octane. Now I'm going to flash the 91 octane and get an error message that the file is either corrupted or in the wrong format. Anyone else with this issue?
  6. Feb 25, 2018 at 11:45 AM
    #2706
    2016trdtacoma
    Trevor
    Utah
    255/85R16 are my next ones, but not for a year or so
  7. Feb 25, 2018 at 11:49 AM
    #2707
    nxcess
    nxcess Well-Known Member
    '17 Tacoma MT 4x4
    OVTuned
    Check the file size. Should be around 1,536KB. If you downloaded the 1.03B tune recently, it might be invalid cause it's not available for download with the new flash manager.
  8. Feb 25, 2018 at 11:56 AM
    #2708
    Shellshock
    Iowa
    It’s a bit sketchy currently. When first flashing it’s a pretty huge change and takes a while to adjust your driving habits. The throttle sensitivity was also adjusted which ovt has said he can easily tone down if we desire. I think a slight tweak there and it’ll be just fine. I’ve got enough miles on it now I’ve mostly adjusted to it but it’s still a bit touchy for my liking, at least for winter driving. No complaints about the extra power though.
  9. Feb 25, 2018 at 12:17 PM
    #2709
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    Had same issue email Matt he will fix you up.
  10. Feb 25, 2018 at 12:19 PM
    #2710
    fmfdadbod88
    right on, thanks!
  11. Feb 25, 2018 at 12:52 PM
    #2711
    su.b.rat
    su.b.rat broken truck
    how's it doing for you now 24 hrs in? worth all the wait and trouble?
  12. Feb 25, 2018 at 1:00 PM
    #2712
    charlieyankee88
    charlieyankee88 Well-Known Member
    2017 TRD OR DCSB MT
    RADFLO Suspension, JBA HD UCAs, Mobtown low pro bumper, Mobtown bolt-on sliders, Engo SR10s, SCS Stealth 6, AFE CAI, URD Spec U, OV Tuned, Gobi Rack, Softopper, CMC
    Ok. So after a few days with the 1.03b tune still liking the over all performance. However, I have noticed the stutter at 2500. It is quite noticeable. Today I reflashed to stock, shut the truck off, then reflashed the 1.03b tune. After that I let it idle for 15 minutes and then held revs at 500 rpm intervals to try and allow then computer to learn the idle and changes. After that I took it out for a spin. I am still noticing the stutter. Should I have run the vehicle on the stock tune for a bit before reflashing? Any inputs to get rid of the stutter?
  13. Feb 25, 2018 at 1:09 PM
    #2713
    filbert
    filbert Well-Known Member
    Chicago
    2016 Tacoma TRD OR DCSB V6 MT
    I've been lurking reading the 15,000 posts on this... and submitted order #2485!
    dYL0n, 2016trdtacoma and JJ18ORDBSBMT like this.
  14. Feb 25, 2018 at 1:43 PM
    #2714
    Livinserene
    Livinserene Thejerkyguy
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
    Hahahahahah, about 48 lol :playball:wifey is picking me at airport there in Halifax ,, I’ll be doin the tune before we leave Parkin lot:bananadance:
    JJ18ORDBSBMT likes this.
  15. Feb 25, 2018 at 1:44 PM
    #2715
    su.b.rat
    do your 10 minute idle touching nothing before leaving. explain to your wife the importance to the universe for this... takes about 10 mins :alien:
    Livinserene[QUOTED] likes this.
  16. Feb 25, 2018 at 1:46 PM
    #2716
    Livinserene
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
    Hahha she will totally get it ,, she’s been along for the ride ,, maybe a run around the bases in the ol canopy:pwhile were waiting ,,,hee hee
  17. Feb 25, 2018 at 1:55 PM
    #2717
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Right on man, but seriously don't skip that step :thumbsup:
  18. Feb 25, 2018 at 2:00 PM
    #2718
    MOC221_
    Frank
    The only thing I did differently (besides reloading the god awful stock tune - NOPE) was to do the idle learning from cold.
    Try re-doing the idle learning on 1.03B from stone cold up to operating temp without re-flashing (took close to 20 min). That worked for me the first time I tried it.
    Edit: In Mat's words, don't touch anything during the idle learning...
  19. Feb 25, 2018 at 2:12 PM
    #2719
    RedBeard1
    Red
    I’ve been stuck at work so I only have about 85 miles on it so far but I’m liking it.
    su.b.rat[QUOTED] and MOC221_ like this.
  20. Feb 25, 2018 at 3:02 PM
    #2720
    fzj40
    fzj40 Well-Known Member
    R
    2017 TRD OR MGM 6MT
    @mat - yes 1.03B w/ PC on sport attenuation all the way down. It's great!
    Boxerocks likes this.
Thread Status:
