2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Feb 26, 2018 at 12:00 PM
    #2761
    Shellshock
    Iowa
    I’m stock at this point which will make a huge difference with the reduced weight both in truck and tires
    RedBeard1[QUOTED] and MOC221_ like this.
  2. Feb 26, 2018 at 12:04 PM
    #2762
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    My truck is a pig I’m probably close to 8-900lbs over stock weight when I am just kitted out for daily driving. Tack another 5-700lbs on that for when I am heading out to parts unknown and it will get pretty sluggish.
  3. Feb 26, 2018 at 12:31 PM
    #2763
    RedBeard1
    Red
    I also told you guys I’d give a report on towing with 1.03b today.
    Towed my 16’ car hauler (1287lbs) to go pick up some steel today I also took a load of scrap to the recycling yard. Load to the scrap yard was 1145 scrap+1287 trailer = 2432 lbs for 46 miles. Return load back to the house was 1915 lbs of 3/16 steel plate five 5’x10’ sheets + 1287 trailer = 3202 lbs.
    Fuel mileage on the first leg of trip into a slight head/cross wind was 13.4 according to the truck.
    Fuel mileage on the return trip was 14.1 according to the truck had a cross wind on the return.
    My mileage is up close to 2mpg over the stock tune from similar trips in the past to the same 2 locations.
    The truck definitely benefits from this tune while towing. The low end improvements Matt made are heading in the right direction. If Matt could pull some more on the lower end of the rpm range he would have it nailed.
    I do all of my towing at 65mph with the truck in 5th gear when cruising loaded. I’ll use 6th if I am empty. This trip I was loaded both ways like I typically try to do. Running to town empty doesn’t make me any money.
    Hope this helps y’all.
  4. Feb 26, 2018 at 1:13 PM
    #2764
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    Ya, and this is why I stated that it's most likely a by product of the crap stock tune and will take time to re adjust.
    MOC221_ and RedBeard1[QUOTED] like this.
  5. Feb 26, 2018 at 1:37 PM
    #2765
    commbubba19
    commbubba19 Well-Known Member
    '23 TRD PRO
    stupid question, but i'm assuming i have to wait for the dongle before doing anything. Order was put in last week but i read that he was low on usb dongles. no hurry here but i wanted to make sure i wasn't holding up the process.
  6. Feb 26, 2018 at 1:54 PM
    #2766
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Thanks for reporting your experiences with towing - first I've seen w/ 1.03 thus far with this kind of load! Monitor transmission temps or anything with a scanner on your trip? I'm not a MT so will be a different story for us nasty A/T owners, but the biggest concern w/ towing tuned would be (for me) any excess heat created w/ the additional power/torque. Without load I'm seeing very good results so hopefully holds true with a few thousand LBs are hooked up! travel trailer season is upon us!
  7. Feb 26, 2018 at 2:27 PM
    #2767
    fzj40
    fzj40 Well-Known Member
    R
    2017 TRD OR MGM 6MT
    @bshammer0 - MT temps are not monitored by the ECU like they are in an AT.
    MOC221_ likes this.
  8. Feb 26, 2018 at 2:51 PM
    #2768
    bshammer0
    Brandon
    Nashville, TN
    Yeah, I wondered that as I was posting up my question but still didn't know if there was some sort of temp sensor on the MTs. Been a few years since I've driven a real truck - lol. When kiddo is older I'll be back assuming I can still get an MT by then and not some autonomous electric flying prius with no steering wheel by the time I dump the Taco...!
    Shellshock likes this.
  9. Feb 26, 2018 at 3:02 PM
    #2769
    iexc
    iexc WerXED BH2.0 AD
    Kalede
    Toronto
    2023 TRD Sport MT
    i would like to give an opinion or observation concerning Atkinson Otto transition and how there is a smoother transition reported by most.
    is it possible that this transition is a result of more balanced power between the two,in witch case.is the Atkinson stage working to hard or are we missing something big from full Otto.i have noticed very little to no fuel consumption between the tunes.
  10. Feb 26, 2018 at 3:08 PM
    #2770
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Thanks for the towing review, do you think you'll copy this over to the poll/review thread?
    Cheers :)
    RedBeard1[QUOTED] likes this.
  11. Feb 26, 2018 at 3:10 PM
    #2771
    MOC221_
    Frank
    Yeah I suppose us M/T guys could monitor oil and coolant temps while towing for comparison to unloaded.
  12. Feb 26, 2018 at 3:22 PM
    #2772
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    This goes completely against your screen name....
  13. Feb 26, 2018 at 3:23 PM
    #2773
    iexc
    Kalede
    Toronto
    2023 TRD Sport MT
    didnt no how to quote from another thread. this is from
    redaccount36
    Yeah I mean honestly for me, I don't get what everyone is saying about the pedal being too sensitive. I love it, and if anything wish it was even more sensitive. I think it's absolutely just reprogramming our brains from the old sluggish unresponsive pedal. Before 1.03, my wife's lexus, that has the same engine, felt to me like a hair-trigger pedal. There were a few times where I jerked forward quite a bit as a result of being used to my Tacoma. 1.03 gets me closer to the way the Lexus feels, but still not quite as hair-trigger sensitive. I think it's a good in-between compromise, since after all, it is a truck.
    it might help to jump in another vehicle to see how stock tune screws with our foot
    MOC221_ likes this.
  14. Feb 26, 2018 at 4:52 PM
    #2774
    Yzkiley
    Yzkiley Well-Known Member
    British Columbia, Canada
    2016 MGM Tacoma Sport DCSB MT
    rain guards, hood deflector, oem tonneau, BFG ko2's, led lightbar behind grill, highlift jack mount side rail, husky Xact front & rear mats, bedrug, AFE cold air intake with scoop, TB spacer, Spec U exhaust, Hikari - lumileds Led's, any time backup cam and gps, OV tune 103B, TRD pro grille, Cali raised pod fog lights, ECGS needle bearing, Bilstein 5100's, Low range offroad 3-1 level kit, SPC light racing ctrl arms, spidertraxx 1.25in spacers, Ride right airbags, clazzio seat covers, carrier bearing spacer, diff drop spacer.....
    Same problem hear. I hear the same chirp, chirp, chirp from the CAI at the same rpm
    MOC221_ likes this.
  15. Feb 26, 2018 at 4:57 PM
    #2775
    scareurpasenger
    scareurpasenger Well-Known Member
    Roswell, ga
    2022 TRD Pro MT
    Fast is smooth and high cornering Gs is more effective at scaring passengers:)
    Back on topic, I still have the stuttering so I am not sure how others don’t feel it. It would be cool to see a full Otto tune just to see how it changes the feel and possibly the 3krpm power spike.
    MOC221_ likes this.
  16. Feb 26, 2018 at 5:04 PM
    #2776
    su.b.rat
    su.b.rat broken truck
    anyone suspect injector cleaning weirdness?
    MOC221_ likes this.
  17. Feb 26, 2018 at 5:33 PM
    #2777
    Yzkiley
    Nope. I had a single chirp from the CAI before the 103b tune at around 3k rpms or so when hard on the gas. I now get a chirp, chirp, chirp at 2500rpms under mild acceleration and thats where the stutter is happening.
  18. Feb 26, 2018 at 5:48 PM
    #2778
    2016trdtacoma
    Trevor
    Utah
    Leaving for a dirt bike trip 4 hours south to Southern Utah tomorrow. Hauling my bike down so I will have a good ride to test some weight in the bed and a good highway ride :)
    TWTaco likes this.
  19. Feb 26, 2018 at 6:00 PM
    #2779
    tekoma
    tekoma Member
    Apex, NC
    24 Tacoma TRD Off Road Manual
    Method MR318 17x8.5 Bronze BF Goodrich KO3 285/70R17 XPEL Partial PPF XPEL 70% tint windshield XPEL 35% tint front sides
    I never flashed back to 1.03 after my surging issues. Ended up leaving the 87 tune and followed the procedure suggested by Mat and @MOC221_ (cold engine, 20 min idle). Note that I did NOT have surging at idle. I’ve noticed an immediate improvement. Previously the surging was getting bad even on my short commute, but this seems to have resolved it. I need to get it out on the highway to see if it officially did the trick.
    2016trdtacoma likes this.
  20. Feb 26, 2018 at 6:07 PM
    #2780
    2016trdtacoma
    Trevor
    Utah
    Glad to hear. I did not experience any surging after flashing, but I did let it idle for 5 minutes after flashing, shut off the truck, then started it and drove 30 miles up to my dads.
    I also have not experienced any surging/stuttering in the 2-3k rpm band while shifting through 2nd and 3rd.
    I am still in love with this tune. Every time I shift into 2nd and 3rd, I get a smile knowing how well the truck feels compared to the stock garbage.
Thread Status:
