2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Feb 27, 2018 at 1:32 PM
    #2801
    Yzkiley
    Yzkiley Well-Known Member
    British Columbia, Canada
    2016 MGM Tacoma Sport DCSB MT
    rain guards, hood deflector, oem tonneau, BFG ko2's, led lightbar behind grill, highlift jack mount side rail, husky Xact front & rear mats, bedrug, AFE cold air intake with scoop, TB spacer, Spec U exhaust, Hikari - lumileds Led's, any time backup cam and gps, OV tune 103B, TRD pro grille, Cali raised pod fog lights, ECGS needle bearing, Bilstein 5100's, Low range offroad 3-1 level kit, SPC light racing ctrl arms, spidertraxx 1.25in spacers, Ride right airbags, clazzio seat covers, carrier bearing spacer, diff drop spacer.....
    I tried the full warm up cycle as suggested. Let the truck warm up from cold with all hvac off for 20 mins. Seems better and less bouncy rpms. However stutter is still there. Its exactly at 2700- 3000 rpms under light throttle. My cold air intake will go chirp, chirp, chirp consistently every time. This is right in the sweet spot of driving and very annoying. The truck surges or has a slight hesistation and is hella annoying.
  2. Feb 27, 2018 at 1:42 PM
    #2802
    su.b.rat
    su.b.rat broken truck
    mind me asking which ECU base you have? (04B12 over here)
  3. Feb 27, 2018 at 1:48 PM
    #2803
    commbubba19
    commbubba19 Well-Known Member
    '23 TRD PRO
    Any 18's have the stutter?
    02Duck likes this.
  4. Feb 27, 2018 at 2:51 PM
    #2804
    iexc
    iexc WerXED BH2.0 AD
    Kalede
    Toronto
    2023 TRD Sport MT
    Understandable .just that i would be very interested to see how this engine wood perform in full Otto compared to gen2 taco.
    More torque ,wider power band?
  5. Feb 27, 2018 at 3:36 PM
    #2805
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Eliminating the Atkinson cycle won't make any difference in power. Atkinson only comes into on light throttle applications. I can't see any benifit in removing it. The truck will loose some MPG that the conservative drive would notice.
    Tharris242 likes this.
  6. Feb 27, 2018 at 3:40 PM
    #2806
    Yzkiley
    04B11
  7. Feb 27, 2018 at 4:02 PM
    #2807
    su.b.rat
    i was just checking, because it has looked like the xx10's and xx11's are having these issues at times. but i'm not totally sure of that since 1.03B. so, just watching and seeing if there's any possible pattern to it.
  8. Feb 27, 2018 at 4:08 PM
    #2808
    su.b.rat
    speaking for myself, and i suspect speaking for others that were interested in trying Otto only, it was not for a power gain, but for sharpening the throttle response. the Atkinson cycle is so numb, and we're all used to a sharper edge with the throttle. from Otto, historically speaking anyway. i mean, who the hell has ever driven a proper Atkinson motor? ours isn't an Atkinson motor, but the bit of Atkinson cycle at low rpm is enough to numb things down to make lots of the MT guys unhappy.
    Boxerocks and 2016trdtacoma like this.
  9. Feb 27, 2018 at 5:01 PM
    #2809
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    It may help with throttle response but most member that have the 103b tune are saying that the throttle response is too abrupt. I have no issues with my 18 with the 103b. If Matt does make a tune that eliminates it I would still be interest in trying it.
  10. Feb 27, 2018 at 5:06 PM
    #2810
    Shellshock
    Iowa
    Only 4 dongles left. Better hurry or you’ll be waiting a bit for the next batch.
  11. Feb 27, 2018 at 5:06 PM
    #2811
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    as soon as I have the new version of flash manager out that fixes the MT file download I will have it with the updated throttle maps. this will be a really easy fix
    2 left now
  12. Feb 27, 2018 at 5:11 PM
    #2812
    Shellshock
    Iowa
    Looking forward to the updated throttle maps :goingcrazy:
    mZiggy likes this.
  13. Feb 27, 2018 at 5:40 PM
    #2813
    scareurpasenger
    scareurpasenger Well-Known Member
    Roswell, ga
    2022 TRD Pro MT
    Anything for the stuttering or will that require a manual truck to figure out?
    MOC221_ and mZiggy like this.
  14. Feb 27, 2018 at 6:02 PM
    #2814
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    Mine had the stuttering on my test drive after flash. I disconnected the battery for 10 minutes. The next morning I started it with everything turned off and let it warm up to operating temperature. This cut the stuttering in half I would say. After that just putting some miles on it and it is all but gone. I think after another tank of fuel or so the should clear right on up. My opinion.
  15. Feb 27, 2018 at 6:11 PM
    #2815
    su.b.rat
    I'm about to get on the road on Thursday, so I'm planning to start fresh by reflashing 1.03b and then let it sit and idle to see if that cleans it up through a 'dedicated' learning cycle. my stutters aren't bad and only when cold, but the low throttle position modulation is a bit too choppy and i can use more smooth with all this rain.
  16. Feb 27, 2018 at 6:22 PM
    #2816
    RedBeard1
    Red
    Add some weight to the bed and see if your throttle doesn't feel a lot better. My truck is a pig and it feels good to me...
    On a side note if Matt could broaden the Atkinson cycle engine load tables a little more for those of us who have a lot of extra weight on our trucks so we could see some benefits from it that would be great. I'm pretty sure my truck only sees low enough loads to get any benefits from it when I am rolling down hill in neutral. @OVTune
    Edit: I assume the Atkinson cycle is transmission specific in the engine tunes. If not it would be nice to know if it can be altered so that it is moved up in the rpm range in the manual transmission tunes to say 2200-3000rpm range. That is the 65-80 mph range for most of us I think I am safe to say for stock gearing.
    su.b.rat[QUOTED] likes this.
  17. Feb 27, 2018 at 7:12 PM
    #2817
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    Not sure if everyone knows but when you flash, Matt said to let it idle for 10minutes so the truck can learn. He said dont touch anything while its idling, not even the brake. ‘Maybe’ that could fix the stuttering you are experiencing ?
    dYL0n likes this.
  18. Feb 27, 2018 at 7:55 PM
    #2818
    venezian
    venezian Well-Known Member
    Los Angeles
    2022 7545E
    I tuned as soon as the update was released and did not idle.
    Should I just reflash with the update again and let idle for 10 mins? I'm not sure what the stuttering you'll are referring to.
  19. Feb 27, 2018 at 8:35 PM
    #2819
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    I’m sure it’ll be fine if you let it idle tomorrow for 10 min.
    You can always hook up PCM flash and select “reset DCTs” which will allow the truck to learn the new idle maps.
    No need to flash again.
    bshammer0 and venezian[QUOTED] like this.
  20. Feb 27, 2018 at 9:27 PM
    #2820
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    In Hurricane, Utah right now in the hotel getting ready for bed. Hauling the bike down and around while down here has been outstanding! It really feels like it's not even there. The truck pulls very well, holds rpm's well, and accelerates well.
    Love this damn truck now!!!
Thread Status:
