2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Mar 15, 2018 at 6:38 PM
    #3361
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    Details brah
    Chipi3s and mZiggy like this.
  2. Mar 15, 2018 at 6:40 PM
    #3362
    2016trdtacoma
    Trevor
    Utah
    Ya, going to flash back to B as soon as I get home from my nieces birthday event
  3. Mar 15, 2018 at 6:40 PM
    #3363
    tacogravy
    tacogravy Well-Known Member
    Gravy
    Mantua, Ohio
    17 TRD OR 4x4 Quicksand 6MT
    TRD Pro Grill, TRD Sport Hood, BAMF Sliders, Bilstein 5100's F&B, BF Goodrich KO2 265/75R16, Old Man Emu 887 Front, Head Strong 3 Leaf AAL Rear (Overload Leaf Left In), OVTuned, De-Badged. Accumulator Delete Mod.
    So that's how I get the trunk to open! Where do I get one of those?
  4. Mar 15, 2018 at 7:00 PM
    #3364
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Pm me your email and I'll send it to you.
  5. Mar 15, 2018 at 7:01 PM
    #3365
    nxcess
    nxcess Well-Known Member
    '17 Tacoma MT 4x4
    OVTuned
    I order this: http://www.keyecu.com/index.php?route=product/product&product_id=4757
    FCC ID: HYQ12BDP << This has to be exact match.
    When key arrives, you have 2 options
    1. transfer transponder chip from old key to new key [I did this since my chip was already removed for the other flip key]
    2. program new transponder chip via techstream [youtube the video, it'll explain how to do it]​
    Once the chip has been programmed, you need to program the remote.
    1. Put key in ignition and turn to ON.
    2. Open techstream.
    3. Select MainBody
    4. Click on Utility
    5. Select Wireless Code Registration and follow the prompts.
    BTW, you should get the key cut by a locksmith.
    If I can figure out where the wiring for trunk release is, it wouldn't be a bad idea for a powered tailgate lock.
  6. Mar 15, 2018 at 7:10 PM
    #3366
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    "Stick" around dood, you gots knowledge. Granted the banter in here is more along the line of MT affect but there are common parts in this Venn diagram.
    mZiggy likes this.
  7. Mar 15, 2018 at 7:22 PM
    #3367
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Since a key is still required (naturally, since we have an ignition), I'll admit to not understanding the excitement I'm seeing over this rav4 fob...
    Stopmithering likes this.
  8. Mar 15, 2018 at 7:23 PM
    #3368
    mZiggy
    mZiggy Honey badger
    Marc
    No worries. We weren't upset about your mishap. Just pointing you in the right direction since this is the MT thread. No biggie if you join in on our shenanigans.
    TeecoTaco likes this.
  9. Mar 15, 2018 at 7:26 PM
    #3369
    TeecoTaco
    SW Ontario
    Shellshock, su.b.rat and mZiggy like this.
  10. Mar 15, 2018 at 8:19 PM
    #3370
    JJ18ORDBSBMT
    JJ18ORDBSBMT Well-Known Member
    1.05 FOB 91 2018 Off road White DC M/T
    found the 103b file. tried to unpack the rar file but it failed.
  11. Mar 15, 2018 at 8:22 PM
    #3371
    2016trdtacoma
    Trevor
    Utah
    Back on 1.03b :)
    MOC221_ likes this.
  12. Mar 15, 2018 at 8:24 PM
    #3372
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Why was it zipped? If you want I could send the 103b to you.
  13. Mar 15, 2018 at 8:25 PM
    #3373
    nxcess
    '17 Tacoma MT 4x4
    OVTuned
    Are you referring to techstream? Try using 7zip to extract it.
  14. Mar 15, 2018 at 8:35 PM
    #3374
    nxcess
    '17 Tacoma MT 4x4
    OVTuned
    It's my inner geek. I prefer the flip key fob over the standard key and have been searching for a better solution than the one that is currently available.
    Travis11 likes this.
  15. Mar 15, 2018 at 8:45 PM
    #3375
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    @nxcess
    Can you clarify the part in bold please,not following exactly what and where. Can you break it down Barney style for me...LOL
    Unrar Techstream to a folder.
    1. install the Techstream V12.10.019.
    2. right click the techstream shortcut icon on your desktop
    a. select "open file location"
    b. copy the "MainMenu" exe from the unrar'd folder and replace the "MainMenu" exe in the folder.
    3. When it ask for the key, copy and paste the string of numbers from the key.txt files.
    To use the hardware from the Tune, in TechStream, at the top of the program, you should see "Setup". Select that and go to "VIM Select". Change interface to "OpenPort 2.0 J2534".
  16. Mar 15, 2018 at 8:47 PM
    #3376
    nxcess
    '17 Tacoma MT 4x4
    OVTuned
    What part?
  17. Mar 15, 2018 at 8:49 PM
    #3377
    M1Awolf
    Rob
    Montana
    Step B, copying the Main menu and replacing it in another file/folder.
  18. Mar 15, 2018 at 8:57 PM
    #3378
    nxcess
    '17 Tacoma MT 4x4
    OVTuned
    When you extracted techstream, it should have created a folder with 3 files.
    1. In that folder, right click the mainmenu.exe file, and a selection menu should pop up. Select and click on copy.
    2. On the desktop, there should be an icon label techstream. Right click that icon, and at the selection menu, select & click "open file location"
    3. A folder should appear with a bunch of files. Right click on empty spot somewhere in the folder, and at the selection menu, select & click "paste".
    4. It'll ask if you want to overwrite/replace the file. Select yes.
  19. Mar 15, 2018 at 9:00 PM
    #3379
    M1Awolf
    Rob
    Montana
    I had the parts of copying from the unrar'd and opening the desktop file,the replace part is where it got a little fuzzy. Techstream is installing now and I should be GTG from this point. Thanks for the clarification.
  20. Mar 15, 2018 at 9:06 PM
    #3380
    nxcess
    '17 Tacoma MT 4x4
    OVTuned
    tacogravy likes this.
Thread Status:
