2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Mar 16, 2018 at 12:07 PM
    #3401
    nxcess
    nxcess Well-Known Member
    '17 Tacoma MT 4x4
    OVTuned
    Yeah. It's nice.
    Search for HYQ12BDP
    That should be the FCC ID on the back of your key.
  2. Mar 16, 2018 at 1:04 PM
    #3402
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Ruggybuggy likes this.
  3. Mar 16, 2018 at 5:14 PM
    #3403
    commbubba19
    commbubba19 Well-Known Member
    '23 TRD PRO
    Had an interesting drive home in stop and go traffic. Learned with 1.03c you can’t drive 5mph in first. Just touch the throttle and I surged forward. Let off and I get major compression braking. I couldn’t just touch the throttle and maintain 5mph. Idle was able to keep it at about 2-3 mph.
    Made for a fun drive home.
  4. Mar 16, 2018 at 5:21 PM
    #3404
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Sounds like you guys are describing the same issue....
  5. Mar 16, 2018 at 5:47 PM
    #3405
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    I experimented today (I'm stock tune)...I can do 600 rpm in 1st and 2nd with no bucking or jerking. Never a problem in that arena. Its soggy getting out of that range, but does it slow and smooth. It takes some ginger input on the skinny pedal but I have a hyper vigilant right foot.
    commbubba19 likes this.
  6. Mar 16, 2018 at 5:56 PM
    #3406
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
  7. Mar 16, 2018 at 6:09 PM
    #3407
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    20180316_191030[1].jpg Ok,having a problem getting Techstream to load. I followed the instructions up to the point of replacing the main menu file. I click the shortcut on the desktop and it asks for area selection then language and then asks for Dealer info and code. Any help?
  8. Mar 16, 2018 at 6:11 PM
    #3408
    TeecoTaco
    SW Ontario
    Just put gibberish in those fields...only one that important is when you get challenged to put in the key code. It's in the third file of the zip. Just cut/paste that code in and Roberts your fathers brother
  9. Mar 16, 2018 at 6:14 PM
    #3409
    M1Awolf
    Rob
    Montana
    That worked thanks.
    TeecoTaco[QUOTED] likes this.
  10. Mar 16, 2018 at 6:23 PM
    #3410
    nxcess
    '17 Tacoma MT 4x4
    OVTuned
  11. Mar 16, 2018 at 6:27 PM
    #3411
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    I may have gotten some bad fuel.
    I am getting some clattering under heavy acceleration from 2500-3500 rpm the last two days. I am getting this clatter or pinging after holding steady rpm in 4th at 60 mph coming out of one of the towns I go through on my commute then accelerate hard to 70 mph up an incline approx 150-200’/.25miles. I am pretty sure it is the fuel I got Thursday on the way to work but wanted to see if any one else has this issue.
  12. Mar 16, 2018 at 6:44 PM
    #3412
    nxcess
    '17 Tacoma MT 4x4
    OVTuned
    Same problem here. Severe bucking trying to hold 1K RPM in 1st gear. Definitely difficult to hold 1st at that RPM, 2nd gear no issue there. Looking at the TS log, my Intake VVT Target Angle Bank 1 fluctuates from 30° to nearly 5°. Not sure if this is the cause of the surging.
  13. Mar 16, 2018 at 7:03 PM
    #3413
    RedBeard1
    Red
    I am getting this same bucking issue in first gear here.
  14. Mar 16, 2018 at 7:14 PM
    #3414
    M1Awolf
    Rob
    Montana
    I got Techstream up and running and was able to turn off my seatbelt buzzer. Can someone do a quick rundown on how to setup Techstream to do the actual data logging.
    ETA I printed out the list of data Matt posted a couple pages back. I just need pointed in the right direction to get Techstream setup.
  15. Mar 16, 2018 at 7:31 PM
    #3415
    commbubba19
    '23 TRD PRO
    Click on obd 2 button and when that loads click on data.
    You can then add custom data pids to a new or use the existing which captures all.
    Make sure the cable is plugged in and you have the ignition to on or engine running before clicking on the obd button.
  16. Mar 16, 2018 at 8:04 PM
    #3416
    M1Awolf
    Rob
    Montana
    Ok I hit the OBD II button then data,do I then configure snapshot for 60 mins with all data?
  17. Mar 17, 2018 at 5:48 AM
    #3417
    commbubba19
    '23 TRD PRO
    You can. The record button is on the bottom right. You can stop it at any time.
    Once stopped you can fill out some details and then save the file.
  18. Mar 17, 2018 at 6:42 AM
    #3418
    lapoltba
    CT - 06076
    I like the flip key for my VW Sportwagen, but I don't like extra buttons that don't do anything. I wasn't able to find the 3 button version anywhere except Ebay for 2x the price. Have you found one that doesn't have the trunk button?
  19. Mar 17, 2018 at 6:49 AM
    #3419
    nxcess
    '17 Tacoma MT 4x4
    OVTuned
    I haven’t found one yet.
  20. Mar 17, 2018 at 7:57 AM
    #3420
    MOC221_
    Frank
    Did anyone get a test file back from Mat?
Thread Status:
