2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Mar 17, 2018 at 3:44 PM
    #3481
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Lol, right on, JK bud.
  2. Mar 17, 2018 at 3:46 PM
    #3482
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    4 more minutes left on idle then out for a rip
    :burnrubber:
    MOC221_[QUOTED] likes this.
  3. Mar 17, 2018 at 4:04 PM
    #3483
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    Not a problem,the sooner we have everyone on the same page sharing the same data across the ECU and tune versions,the sooner Matt can crunch the data and refine the tune. I just got back from another data logging run and sent the fresh file to Matt for evaluation. I tried to incorporate a little bit of everything in the drive. Stop/go traffic,Highway, steep hill ascent and decent along with the 5K rpm runs he wanted.
    PIDS Matt needs From post #3292 in this thread.
    Vehicle Speed
    Engine Speed
    Calculate Load
    Vehicle Load
    Mass Air Flow Sensor
    Coolant Temperature
    Intake Air Temperature
    Battery Voltage
    Accelerator Position
    Throttle Request Position
    Throttle Sensor Position
    Throttle Position Command
    Throttle Position Sensor Open Position No.1
    Throttle Position
    Target Fuel Pressure (High)
    Target Fuel Pressure (Low)
    Fuel Pressure (Low)
    Fuel Pump Control Duty Ratio
    Injector Cylinder #1 (Port)
    Injection Volume Cylinder #1
    Injection Volume
    High Pressure Fuel Pump Duty Ratio (D4)
    Injection Mode
    Injection Switching Status
    Injection Timing Cylinder #1 (D4)
    Injection Time Cylinder #1 (D4)
    Target Air-Fuel Ratio
    A/F (O2) Lambda Sensor B1S1
    A/F (O2) Lambda Sensor B2S1
    Short FT B1S1
    Short FT B2S1
    Long FT B1S1
    Long FT B2S1
    Fuel System Status Bank 1
    Ignition Timing Cylinder #1
    Knock F/B Value
    Knock Correct Learn Value
    Engine Oil Temperature
    A/T Oil Temperature No.1 (if AT)
    Power Mode SW
    Lock Up Status (if AT)
    Shift Status
    Intake VVT Change Angle Bank 1
    Intake VVT Change Angle Bank 2
    Exhaust VVT Change Angle Bank 1
    Exhaust VVT Change Angle Bank 2
    Intake VVT Target Angle Bank 1
    Intake VVT Target Angle Bank 2
    Exhaust VVT Target Angle Bank 1
    Exhaust VVT Target Angle Bank 2
    Misfire count (All Cylinder)
    note, in Techstream when you are setting up the logger and you have the list setup with these items, there is an option to SAVE the list, SAVE it and rename it "Tacoma List" or "Tacoma Logging" that way you can always reselect in the future.
    Now that you have that setup and connected to the truck go to
    FUNCTION > SNAPSHOT CONFIGURE
    this will open some options for the logger
    On the bottom set the time to : 30 or 60 minutes
    the data I need is >
    start the truck on cold idle, let it sit for 2-3 minutes
    driving around how you normally would until it is up to temp
    2x full throttle pulls to at least 5000 RPM in 2nd gear or higher
    idle, hot 2-3 minutes.
    you can capture all of this in 1 single log, save the snapshot (I recommend save it to your desktop, makes it easy to find) and then email me the snapshot data. Please do not export to CSV, I will do it.
    Please do not add ANY flags.
  4. Mar 17, 2018 at 4:21 PM
    #3484
    MT-TACO
    MT-TACO Well-Known Member
    Edward
    3rd-Gen
    Could use a hand with the techstream keep getting unable to connect VIM , has someone ran in to this same problem ?
  5. Mar 17, 2018 at 4:23 PM
    #3485
    2016trdtacoma
    Trevor
    Utah
    Well shit....(fyi, I flashed the 1.03c000..001 91 octane test tune)
    I just got back, stopped the recording and named it, then shut off the truck and I have no clue where the file went. I have been saving them in a TSE folder on my desktop, but not sure what happened....Guess its a good excuse to go for another drive after the truck cools down.
    M1Awolf and MOC221_ like this.
  6. Mar 17, 2018 at 4:23 PM
    #3486
    MOC221_
    Frank
    Documents folder?
  7. Mar 17, 2018 at 4:24 PM
    #3487
    2016trdtacoma
    Trevor
    Utah
    nope :(
  8. Mar 17, 2018 at 4:25 PM
    #3488
    2016trdtacoma
    Trevor
    Utah
    I have a TS file from today, not sure if its the idle recording I had b4 I left or not. ...ugh I guess I'll send it to matt anyway to see if its of any value.
  9. Mar 17, 2018 at 4:26 PM
    #3489
    MOC221_
    Frank
    To use the hardware from the Tune, in TechStream, at the top of the program, you should see "Setup". Select that and go to "VIM Select". Change interface to "OpenPort 2.0 J2534".
    Oh, and the truck has to be "ON". Not just accessory.
  10. Mar 17, 2018 at 4:30 PM
    #3490
    2016trdtacoma
    Trevor
    Utah
    When you save your recordings, do you do it while the truck is still on or how do you do it? Last time I shut off the truck not thinking, then when the prompt said I lost connection to TS, I turned the truck back on and then saved it and that seemed to work fine. Not sure how or why I messed it up this time.
  11. Mar 17, 2018 at 4:30 PM
    #3491
    M1Awolf
    Rob
    Montana
    If you did what I did and named the same but added a digit ie.Testrun Testrun2 it might be in the same log file but in a sub folder you don't see it unless you open it in Techstream. Click Open scan data file then chose Open service event file then a new window opens and in the left pane you will see one of your file names,if it has a + next to it,it should contain several folders with files with date stamps.
    ETA if you did the above (similar name) the file you send Matt will contain all the files in the folder.
  12. Mar 17, 2018 at 4:30 PM
    #3492
    MOC221_
    Frank
    Yeah I always save b4 shutting the truck down...
    2016trdtacoma[QUOTED] likes this.
  13. Mar 17, 2018 at 4:37 PM
    #3493
    2016trdtacoma
    Trevor
    Utah
    Thank you. I think I found it.
  14. Mar 17, 2018 at 4:45 PM
    #3494
    2016trdtacoma
    Trevor
    Utah
    So as far as some feedback goes:
    Feels really good. It does appear that the throttle response is somewhere between the B and C file. Power still feels the same and shifts feel smoother. Downshifting feels smoother and the hard "kick" when you left off the throttle seems less then I recall.
    This is with only 20 miles so far, so take with a grain of salt. I will get out later after the truck cools down and will do another recording.
    @OVTune
    commbubba19 likes this.
  15. Mar 17, 2018 at 4:56 PM
    #3495
    MOC221_
    Frank
    Sounds very similar to my experience, very smooth. In my case, initially at least, I COULDN'T MAKE IT STUTTER! HAPPY DANCE :taco:
    I hope upon hope that this is the end of them for me. Been that way in some fashion since brand new on OEM tune!
    Shellshock likes this.
  16. Mar 17, 2018 at 4:57 PM
    #3496
    nxcess
    nxcess Well-Known Member
    '17 Tacoma MT 4x4
    OVTuned
    @OVTune, Log file sent. First one is initial flash and 10 min idling. Not sure if that would be useful or not. Second is the 2nd gear pull to 6K.
    Flashed back to 1.03B.
  17. Mar 17, 2018 at 4:57 PM
    #3497
    MT-TACO
    Edward
    3rd-Gen
    What are you running for fuel?
  18. Mar 17, 2018 at 4:58 PM
    #3498
    2016trdtacoma
    Trevor
    Utah
    I was not able to as well, but with only 20 mile, this is not real data LOL
    Looking forward to a little more driving here in a bit. This time I might go up a local canyon that is pretty long with 10-15% grades up and down.
  19. Mar 17, 2018 at 4:59 PM
    #3499
    M1Awolf
    Rob
    Montana
    Is this the new test tune Matt sent after you sent in data logs?
  20. Mar 17, 2018 at 4:59 PM
    #3500
    2016trdtacoma
    Trevor
    Utah
    Really, after that you flashed back? Why?
Thread Status:
