2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Mar 17, 2018 at 7:48 PM
    #3521
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    Sure, the more data we can get to Matt I think the better off the tune will be.
  2. Mar 17, 2018 at 7:56 PM
    #3522
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    I hate seeing him swamped with data but this way he can do side by side comparisons and narrow it down to common characteristics and anomalies between trucks and tunes...
    mZiggy likes this.
  3. Mar 17, 2018 at 7:58 PM
    #3523
    2016trdtacoma
    Trevor
    Utah
    I agree, but I think if he gets too much data he will tell us :)
    Shellshock likes this.
  4. Mar 17, 2018 at 7:59 PM
    #3524
    tekoma
    tekoma Member
    Apex, NC
    24 Tacoma TRD Off Road Manual
    Method MR318 17x8.5 Bronze BF Goodrich KO3 285/70R17 XPEL Partial PPF XPEL 70% tint windshield XPEL 35% tint front sides
    Agreed - Got Techstream up and running, will log tomorrow.
  5. Mar 17, 2018 at 8:00 PM
    #3525
    M1Awolf
    Rob
    Montana
    Will that be anything like spoon feeding a baby....?:puke::D
  6. Mar 17, 2018 at 8:03 PM
    #3526
    M1Awolf
    Rob
    Montana
    Did you plug into your truck and configure the PID data yet?
    Here are the things Matt needs in your data log.
    PIDS Matt needs From post #3292 in this thread.
    Vehicle Speed
    Engine Speed
    Calculate Load
    Vehicle Load
    Mass Air Flow Sensor
    Coolant Temperature
    Intake Air Temperature
    Battery Voltage
    Accelerator Position
    Throttle Request Position
    Throttle Sensor Position
    Throttle Position Command
    Throttle Position Sensor Open Position No.1
    Throttle Position
    Target Fuel Pressure (High)
    Target Fuel Pressure (Low)
    Fuel Pressure (Low)
    Fuel Pump Control Duty Ratio
    Injector Cylinder #1 (Port)
    Injection Volume Cylinder #1
    Injection Volume
    High Pressure Fuel Pump Duty Ratio (D4)
    Injection Mode
    Injection Switching Status
    Injection Timing Cylinder #1 (D4)
    Injection Time Cylinder #1 (D4)
    Target Air-Fuel Ratio
    A/F (O2) Lambda Sensor B1S1
    A/F (O2) Lambda Sensor B2S1
    Short FT B1S1
    Short FT B2S1
    Long FT B1S1
    Long FT B2S1
    Fuel System Status Bank 1
    Ignition Timing Cylinder #1
    Knock F/B Value
    Knock Correct Learn Value
    Engine Oil Temperature
    A/T Oil Temperature No.1 (if AT)
    Power Mode SW
    Lock Up Status (if AT)
    Shift Status
    Intake VVT Change Angle Bank 1
    Intake VVT Change Angle Bank 2
    Exhaust VVT Change Angle Bank 1
    Exhaust VVT Change Angle Bank 2
    Intake VVT Target Angle Bank 1
    Intake VVT Target Angle Bank 2
    Exhaust VVT Target Angle Bank 1
    Exhaust VVT Target Angle Bank 2
    Misfire count (All Cylinder)
    note, in Techstream when you are setting up the logger and you have the list setup with these items, there is an option to SAVE the list, SAVE it and rename it "Tacoma List" or "Tacoma Logging" that way you can always reselect in the future.
    Now that you have that setup and connected to the truck go to
    FUNCTION > SNAPSHOT CONFIGURE
    this will open some options for the logger
    On the bottom set the time to : 30 or 60 minutes
    the data I need is >
    start the truck on cold idle, let it sit for 2-3 minutes
    driving around how you normally would until it is up to temp
    2x full throttle pulls to at least 5000 RPM in 2nd gear or higher
    idle, hot 2-3 minutes.
    you can capture all of this in 1 single log, save the snapshot (I recommend save it to your desktop, makes it easy to find) and then email me the snapshot data. Please do not export to CSV, I will do it.
    Please do not add ANY flags.
  7. Mar 17, 2018 at 8:06 PM
    #3527
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    These two are also AT only I believe, although not labeled as such. Couldn't find them in the list when I was creating my custom list
    2016trdtacoma likes this.
  8. Mar 17, 2018 at 8:09 PM
    #3528
    2016trdtacoma
    Trevor
    Utah
    Ya, I could not find them either.
    mZiggy[QUOTED] likes this.
  9. Mar 17, 2018 at 8:09 PM
    #3529
    M1Awolf
    Rob
    Montana
    Correct but you missed acouple ;)
    These are for Auto trans.
    Power Mode SW
    Shift Status
  10. Mar 17, 2018 at 8:09 PM
    #3530
    mZiggy
    mZiggy Honey badger
    Marc
    Neither could moc. He was walking me through it all
  11. Mar 17, 2018 at 8:10 PM
    #3531
    mZiggy
    mZiggy Honey badger
    Marc
    i ignored the two that are labeled as AT because, well, I hope it's self explanatory lol
  12. Mar 17, 2018 at 8:25 PM
    #3532
    Shellshock
    Iowa
    It’s amazing seeing the MT crew work together to help get this resolved :thumbsup:
    Unlike those auto clowns who just complain
    Looking forward to the update, running on 1.03B in the mean time.
    mZiggy and M1Awolf like this.
  13. Mar 17, 2018 at 8:29 PM
    #3533
    mZiggy
    mZiggy Honey badger
    Marc
    I mean, who knows, perhaps the auto guys would do some logging if they were in the same situation. But there does seem to be a lot more whining about stuff in the alpha tune thread. Idk about the new auto trans specific thread
  14. Mar 17, 2018 at 8:29 PM
    #3534
    tekoma
    tekoma Member
    Apex, NC
    Got Techstream downloaded, not sure what function to choose - connect to vehicle? then at what point do a choose what to record? Perhaps it will be intuitive when i plug in to the truck.
  15. Mar 17, 2018 at 8:29 PM
    #3535
    M1Awolf
    Rob
    Montana
    Look at it this way,us M/T guys like to drive our trucks whereas the A/T guys just want the truck to drive itself. So it makes sense that we want to be involved in the evolution of this tune whereas the A/T guys want it done for them ;) They probably drive out of the way for full service gas and to get the air checked in their tires too or have their wives do it for them.:stirthepot:
    jbruce, iexc and Shellshock[QUOTED] like this.
  16. Mar 17, 2018 at 8:30 PM
    #3536
    mZiggy
    mZiggy Honey badger
    Marc
    Yeah you're going to need to have it plugged into the truck to proceed.
  17. Mar 17, 2018 at 8:32 PM
    #3537
    tekoma
    tekoma Member
    Apex, NC
    Right, figured that much... but i assume i use the "connect to vehicle" to get started? I just don't want to go clicking random buttons in techstream. I'm a techstream nooby.
  18. Mar 17, 2018 at 8:32 PM
    #3538
    mZiggy
    mZiggy Honey badger
    Marc
    Also, right click on the shortcut for the techstream program, choose open in folder location or whatever it is, and then copy and paste the main menu file from the folder that you extracted the files to, into the folder that opens when you chose open to folder for the techstream shortcut. You're replacing the one that is there
  19. Mar 17, 2018 at 8:32 PM
    #3539
    M1Awolf
    Rob
    Montana
    You are at the same stage I was in last night, MOC helped get me squared away. Hang on I will see if I can invite you to the IM we have.
    mZiggy likes this.
  20. Mar 17, 2018 at 8:33 PM
    #3540
    tekoma
    tekoma Member
    Apex, NC
    yep, got that part from the setup video, thanks.
Thread Status:
