2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Mar 22, 2018 at 6:00 AM
    #3941
    iPaint
    iPaint Well-Known Member
    Nebraska
    2017 TRD OR DC 4x4 AT
    This is how I felt going from 1.03B to 1.03C. I like how 1.03C wasn’t so touchy at lower speeds but felt like it lost power vs 1.03B.
    Thank you guys for doing all this logging and testing for everyone else.
    nxcess and MOC221_[QUOTED] like this.
  2. Mar 22, 2018 at 6:14 AM
    #3942
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    It can be argued that the feeling of lost power is placebo since it's not launching forward just by breathing on the throttle. For C, Mat didn't touch power.
  3. Mar 22, 2018 at 6:28 AM
    #3943
    mZiggy
    mZiggy Honey badger
    Marc
    Alright guys, the below quoted text is a copy of what I just emailed to @OVTune
    "Alright sir, after my morning drive, all I have to report is that I experienced a single stutter. This was produced by cold start followed by immediately driving off. Under somewhat spirited acceleration within about a minute of driving off, I got a single stutter in 3rd gear at approximately 2500rpm. Other than this isolated incident, I did not experience any other issue, either previously reported by other users or new. Total length of the drive was about 20 mins covering 13 miles. Operating temp was achieved within the first couple miles of that.
    I had the opportunity to get into 5th and 6th gear and found that I can still accelerate smoothly in these gears. It should be noted that I live in a very flat area. Not many hills.
    My overall impression with the lower gears (1-3) that I've also shared with the Manual trans thread is that this map sort of puts me in mind of the saying "slow is smooth and smooth is fast". At first I perhaps thought there was a touch less power on tap, but the more I think of it I am not convinced of that as I continue to drive it and as I keep in mind that, unless I'm wrong, you've previously reported that the 87 maps don't touch on the power that is there and instead focus more on the application of the power available. At any rate, the incredible smoothness of this map more than balances that out, which is what put me in mind of the saying I quoted.
    04B12, 87 octane, 1.03C 000002T3"
    @MOC221_ @M1Awolf @2016trdtacoma
    2016trdtacoma and MOC221_ like this.
  4. Mar 22, 2018 at 6:30 AM
    #3944
    iPaint
    Nebraska
    I felt like it couldn’t hold speed on hills the same way with ANY amount of throttle in the 1800-2100 rpm range. I didn’t notice this at higher rpms.
  5. Mar 22, 2018 at 6:33 AM
    #3945
    mZiggy
    mZiggy Honey badger
    Marc
    Noted. Unfortunately I don't have reliable/easy access to hills where I live to help document/datalog that, and the one hill I do have access to is a very real mountain with a grade steep enough that attempting to climb it at 1800-2100 rpm would get me literally nowhere, no matter what map I run. Lol
    Edit** a couple other smaller hills are still steep enough where it'd be the same or similar situation
    I live in a flat desert.
  6. Mar 22, 2018 at 6:36 AM
    #3946
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    I agree completely. I've been running 1.03B as it feels more responsive than 1.03C. But like you said, it is a bit more touchy, particularly in reverse with the crazy reverse gear in this truck. Still, I prefer B. Hopefully, we'll see B and C versions of the new revision.
    Also, thank you to all the loggers!
    MOC221_ and iPaint[QUOTED] like this.
  7. Mar 22, 2018 at 6:43 AM
    #3947
    iPaint
    Nebraska
    Unfortunately I lost 1.03B and the only tune I have at the moment is 1.03C.
  8. Mar 22, 2018 at 6:46 AM
    #3948
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Thanks for that, every review helps.
    With previous files on 1.03C 91, I've always had plenty of power on the highway. On flat ground, the truck would just keep pulling in 6th. I could also accelerate up all but the steepest of hills without downshifting (I run completely stock gearing/rims/tire size).
    In my case I'm 100% positive that it's not a placebo or the smoothness masking power etc. I can't do the things I could before on the highway, or should I say the truck won't let me.
    Anyway, I think things are going to spiral out of control in this thread if we keep surmising what the issue is back and forth. This will be especially true if someone comes in and only sees that last few pages without knowing the context of what's been happening since last weekend. We need Mat to look into this and chime in. I'm very confident this will be fixed.
    Edit: The "B vs C" debate is already starting up again. How long until we hear "granny tune!". Let's wait for Mat pls.
    iexc and mZiggy[QUOTED] like this.
  9. Mar 22, 2018 at 6:48 AM
    #3949
    mZiggy
    mZiggy Honey badger
    Marc
    What ECU version do you have?
  10. Mar 22, 2018 at 6:53 AM
    #3950
    mZiggy
    mZiggy Honey badger
    Marc
    I certainly do not want to appear like I'm discrediting your findings or anything like that. Like I said earlier this morning (in an edit, so you may have missed it), this is probably also an effect of you guys being on 91 maps while I run the 87. I'm simply not expecting to see huge power advancements on 87
    MOC221_[QUOTED] likes this.
  11. Mar 22, 2018 at 6:56 AM
    #3951
    Comb
    Comb Known Member
    I'd send you the file, but I don't think your truck is 04B12.
    mZiggy likes this.
  12. Mar 22, 2018 at 7:00 AM
    #3952
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    I am going to hold off sending the log to Matt unless he asks for it. In the meantime I will do some more driving and evaluation and probably another log drive tomorrow night after work or Saturday.
  13. Mar 22, 2018 at 7:02 AM
    #3953
    MOC221_
    Frank
    Right on, thanks again :thumbsup:
  14. Mar 22, 2018 at 7:22 AM
    #3954
    iPaint
    Nebraska
    04B11
    Thanks anyways!
  15. Mar 22, 2018 at 7:26 AM
    #3955
    mZiggy
    mZiggy Honey badger
    Marc
    Was gonna offer to send like @Comb did. Sorry
    I believe @2016trdtacoma is 04b11 and could send you 1.03B
    nxcess likes this.
  16. Mar 22, 2018 at 7:30 AM
    #3956
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    Yes that is the ECU I have and I do have that file but I will be out of service range most of the day so I'll try to get it off to you ASAP PM me your email
  17. Mar 22, 2018 at 9:22 AM
    #3957
    MOC221_
    Frank
    1.03C T2 91 log sent to Mat.
    pocketsmcaaron and mZiggy like this.
  18. Mar 22, 2018 at 10:33 AM
    #3958
    MT-TACO
    MT-TACO Well-Known Member
    Edward
    3rd-Gen
    Hey would some one have the 04b12 103.b tune ?
    thanks so much
  19. Mar 22, 2018 at 10:36 AM
    #3959
    M1Awolf
    Rob
    Montana
    @MT-TACO
    I have it,send me an IM with your email addy and I can send it when I go home for lunch in about a half hour.
  20. Mar 22, 2018 at 10:38 AM
    #3960
    MT-TACO
    Edward
    3rd-Gen
    Done thanks
Thread Status:
