2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Nov 5, 2017 at 2:07 PM
    #401
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    errr ummm.. ahhhh..
    Sorry guys :anonymous:
  2. Nov 5, 2017 at 2:09 PM
    #402
    MOC221_
    Frank
    So I take it you know the scope of the differences between all versions... cool!
    This stuff i'd like to know (freaking Toyota :mad:).
    Ares32 likes this.
  3. Nov 5, 2017 at 2:21 PM
    #403
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    Thanks @OVTune! You're the bomb! Can't wait for everyone to get 1.03
    Ares32 and MOC221_ like this.
  4. Nov 5, 2017 at 2:52 PM
    #404
    Ares32
    Ares32 Well-Known Member
    America
    2016 MGM TRD off road DCSB M/T
    :bananadance:
    stealthmode, Livinserene and MOC221_ like this.
  5. Nov 5, 2017 at 4:02 PM
    #405
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    I was just doing some experimentation with OBD Fusion today. I'm beginning to think that the only time DFCO acts weird is either when the engine is not yet up to temp, or when the A.C. compressor is on. Anyone else have any input?
    I let my truck coast down to <1000rpm today on an off ramp, and my lambdas were pegged lean until <1000rpm. That tells me the injectors were probably in DFCO until then.
    Side note, still can't read injector duty cycle or injection volume to be able to directly see when DFCO is active:mad:
    MOC221_ likes this.
  6. Nov 5, 2017 at 4:07 PM
    #406
    MOC221_
    Frank
    I've found that it acts weird without A/C, and when up to temp. Most notably when I'm decending a steep hill in low range, the injectors kicking back on at about 1100-1300 RPM feels like you just lost your brakes. They don't cut off again until about 2000 RPM if you let the truck speed up. Some of us have requested that Mat decrease the cut in RPM to something closer to idle.. we shall see.
    Did you buy the in-app Toyota specific upgrade for OBD fusion? I've seen the PIDs for injector timing and volume etc, but have not tried them yet.
  7. Nov 5, 2017 at 4:12 PM
    #407
    pjensen641
    Boone, IA
    I did purchase the extended PIDs for 2017. Either the Android version is missing the PIDs or the 2017 add-on is. I actually have an email to the developer based on your list of PIDs you were seeing.
    Interesting...wonder if 4LO triggers yet another modification to DFCO. I swear the Toyota control software engineers over thought many useless things....and then d idnt spend enough time getting the basics optimized.
    speedtre and MOC221_[QUOTED] like this.
  8. Nov 5, 2017 at 4:21 PM
    #408
    MOC221_
    Frank
    I will try them out on the IOS version once I get a BT dongle that works for more than 10min at a time lol! I've got another Carista scanner on the way.
    Perhaps the effect is just amplified in 4lo because of the gearing. In any case, it's a fuel economy thing so all other considerations were out the window I'm sure.
  9. Nov 5, 2017 at 4:48 PM
    #409
    MOC221_
    Frank
    @OVTune -
    So in the scenario where someones 2016 ends up at the dealership and has not been flashed back to the OEM, will the new "updated to 04B12" calibration still appear as 04B10/04B11 to techstream?
  10. Nov 5, 2017 at 4:56 PM
    #410
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    No, it will appear as 04B12. But that' still an OEM Toyota calibration number. Toyota would have a hard time figuring out if it wasn' them who put it on the truck.
    Livinserene likes this.
  11. Nov 5, 2017 at 5:02 PM
    #411
    MOC221_
    Frank
    Understood, I was just wondering because there aren't any TSBs that could be applied to a M/T truck that call for an ECM flash update. I suppose if a tech was on the ball (and actually gave a shit) he'd know that 04B12 was not the calibration my truck came with. Just asking in case someone forgets to flash back to OEM...
    Just thinking out loud, no worries here :)
    Ares32 likes this.
  12. Nov 5, 2017 at 5:57 PM
    #412
    sphilly28
    sphilly28 Well-Known Member
    2017 DCSB TRD Sport MGM 6MT
    Unless there was a specific issue relating to ECU version, or the tech is a member of TW and has kept up on these threads, I highly doubt they will pick out ECU software level when they are doing quick scans for fault codes. The only thing I can think of relates to BMW (my background as a dealership tech and now independant shop owner) and when they are doing software updates at a dealer level. The scan tool will look at Vehicle Order and compare software levels of the vehicle at Plant level to what is actually installed. When they do updates to modules they typically update the whole vehicle instead of doing just one module. So if there is a discrepancy in ecu software level it could get picked up and flagged.
  13. Nov 5, 2017 at 6:37 PM
    #413
    pjensen641
    Boone, IA
    The techs don't even check diff fluid (even though they check the box on the service record). They ain't gonna find this. I bet most struggle with techstream. They aren't engineers.
    MOC221_ and bshammer0 like this.
  14. Nov 5, 2017 at 6:39 PM
    #414
    TonyQ
    TonyQ Active Member
    Thornton
    2016 Taco
    Please work on the 4:88 and larger size tires Speedo fix next please.
    taco 16 and bshammer0 like this.
  15. Nov 6, 2017 at 2:31 AM
    #415
    MOC221_
    Frank
    o_O
    Or maybe REV HANG/DFCO... the really annoying stuff.
    02Duck and nevadabugle like this.
  16. Nov 6, 2017 at 5:06 AM
    #416
    JebSmith2112
    JebSmith2112 Well-Known Member
    Jeb
    2017 Cement Tacoma Pro
    Non yet
    I never said anything about total gains. I am interested in what is under the curve, everywhere. I am also not sure why you think the truck is almost undrivable, that is a very bold statement. The truck drives fine, just needs more torque in the midrange, which the autos seem to have. Also, why would you assume this is the wrong truck/motor for me? Simply because I need some hard evidence before dropping $800? You say you have gains, but did you do a before and after dyno? I don't trust your butt dyno, or anyone's for that matter. I added a TRD intake. I know it didn't do a thing for power or performance, but my butt dyno could have sworn that pretty noise it made effected power. It was nothing more than a placebo. I am not saying that the tune is doing that, just that you may be confusing actual gains for gains you are wanting to happen. That is why I like to see graphs.
  17. Nov 6, 2017 at 5:10 AM
    #417
    JebSmith2112
    Jeb
    Non yet
    When I was tuning with HPtuners on my Sky, the GM Tech2 could detect how many times the computer had been flashed. I don't know if Toyota has any way of doing this.
  18. Nov 6, 2017 at 5:14 AM
    #418
    su.b.rat
    su.b.rat broken truck
    the only reason I offered that was to help with more info. I'm not in sales and get nothing from this, whether you buy it or not. goodbye.
    Boxerocks and nevadabugle like this.
  19. Nov 6, 2017 at 7:15 AM
    #419
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    In Torque, I cannot see an injector setting, but it does have a fuel flow meter. While coasting, it does show zero. Similarly, I see the AFR shoot up.
    That said, the throttle percentage seems to hang at 17%. I don't know if this represents the electronic throttle plate, the Atkinson VVTi, or the reading from the pedal sensor itself. I think this might be the source of the hang?
    There are five different throttle position settings to read (Throttle %, A THR2, PedalD, PedalE, and PedalF). I just made gauges out of all of them and will see what it says on the way home today.
    MOC221_ and RaunchBox like this.
  20. Nov 6, 2017 at 8:08 AM
    #420
    MOC221_
    Frank
    OVtune dyno results during auto trans development phase (1.01b I think). 30+ ft/lbs peak gain around 3200 RPM. It's on page 1 of the dev thread BTW:
    There's no reason to believe we won't see gains like this with the M/T once Mat gets things dialed in.
    bshammer0 likes this.
Thread Status:
