2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Nov 6, 2017 at 8:11 AM
    #421
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Hey @OVTune , how long do you think it'll take to get that ECU?
    Murkules likes this.
  2. Nov 6, 2017 at 8:12 AM
    #422
    JebSmith2112
    JebSmith2112 Well-Known Member
    Jeb
    2017 Cement Tacoma Pro
    Non yet
    I have seen this chart. It was promising. The MT chart though is not. It may get better.
  3. Nov 6, 2017 at 8:15 AM
    #423
    MOC221_
    Frank
    Well I guess you just gotta wait lol. Meantime, I'm gonna enjoy the improved driveability and fat torque bump (I currently run 1.01b).
    bshammer0 likes this.
  4. Nov 6, 2017 at 8:16 AM
    #424
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Also the difference in Dyno conditions. the M/T one was done on a HOT day so the air was a concern + it was a brand new truck that hadn't yet been properly broken in. I'd be willing to bet the M/T gains would have been closer if the Dyno room had been in the 60s-70s on a truck w/ 10k miles on it.
    Comb and MOC221_ like this.
  5. Nov 6, 2017 at 8:18 AM
    #425
    MOC221_
    Frank
    And IIRC, dyno mule had oversize wheel/tire setup too.
  6. Nov 6, 2017 at 8:21 AM
    #426
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    Cool, thanks.for the observations. FWIW I don't believe any of the tps sensor readings represent absolute throttle angles. VVTI is separate. I can see Atkinson style Intake VVTI activity on the Intake VVTI Target Angle PID. At low rpm and low to medium load, there is very little advance. Once you get to make load, the Intake target angle pegs to 75degrees which I assume translates to full power Otto mode.
    There is another interesting PID. Injection Mode. On our fusion. 0 is port 1 is direct and 2 is both from what I can decipher.
    The OBD fusion developer got back to me this AM and suggested rescanning for PIDs. After doing so, things looked screwy (I showed a Boost PID reading 2000psi!). Then I deleted my vehicle and re-entered the parameters. After scanning for PID....I saw Injection Volume! So anyway, it seems the scanning of PIDs at set up is just a bit buggy.
    tonered[QUOTED] and MOC221_ like this.
  7. Nov 6, 2017 at 8:33 AM
    #427
    walterj
    walterj Well-Known Member
    PA, USA
    Sexy Black '17 Taco 4x4 DCSB TRD Off-Road 6MT
    It does beg the question why anyone would bother paying for dyno time on an invalid test subject on an unreasonably hot day to work on product development. But, OTOH knowing it wasn't an impressive result and releasing it anyway is at-least a refreshingly honest thing to do. It makes me feel like if he does get a broken in truck with OE size tires on an average day that I could trust the results weren't fudged. I like that. But I'm still going to wait for better results because $800 is $800.
  8. Nov 6, 2017 at 8:34 AM
    #428
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    No problem!
    My ears agree with that. When I get the engine under certain loads, I can hear a different, more throaty exhaust note. I was thinking that it was the DI and VVTi taking over.
    That Inject PID would be coal to see. Can you post the PID code for that one? I believe that we can manually enter PIDs in to Torque.
  9. Nov 6, 2017 at 9:22 AM
    #429
    mkivr32
    mkivr32 Well-Known Member
    Dan
    Long Island, NY
    2017 White TRD Pro MT
    I think one of his points is that it still has YET to be proven for the M/T. My thoughts are the same as well. As of right now there is not enough concrete information to justify, at least for me regarding the M/T. The dyno results were far less than intriguing. Do I anticipate getting this eventually? Yes once it is proven and the kinks are worked out.
    My complaint with the truck is that it struggles with hills upstate and to be able to really pull its weight at times. Also for me, there definitely needs to be an improvement in the rev hang, I can't stand it!
    OV Tune I will say, you have some serious patience with this crowd on Tacoma World kudos to you for that.
    2016trdtacoma likes this.
  10. Nov 6, 2017 at 9:46 AM
    #430
    pjensen641
    Boone, IA
    Unfortunately the Injection Mode PID is not a standard SAE PID. It is part of the extended package you can purchase from OBD Fusion. I don't believe there is a way to see the PID code, and that makes sense. OBD Fusion had to scan and decipher the CAN to find these codes, so its essentially protecting thier work.
    tonered[QUOTED] likes this.
  11. Nov 6, 2017 at 9:55 AM
    #431
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That's cool and makes complete sense. No worries. Fuzion is on Google Play, so I tossed it into my wishlist for now.
    The fuel burn rate and AFR is giving me the info that I need for now. If this were a turbo motor, duty cycle would be great if looking at turning up the boost.
  12. Nov 6, 2017 at 10:14 AM
    #432
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    Now that I am back in the english speaking world, has anyone wity 04B11 or 04B12 received files? I've been out of touch.
  13. Nov 6, 2017 at 10:32 AM
    #433
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    test car used did not pay anything.
    Testing conditions were not ideal, but a majority of things improved are not what you see on the graph, so the conditions of the room, or the tires, etc aren't really used in determining things to change (like throttle response, target torque maps, etc). Also dialing in valve timing is better when done when it's hot, that way we know under stressful conditions it is safe.
  14. Nov 6, 2017 at 10:33 AM
    #434
    Livinserene
    Livinserene Thejerkyguy
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
    Posts 402-404,, latest from ovtune,,
  15. Nov 6, 2017 at 10:39 AM
    #435
    Trident904
    Brian
    17 4Runner TRD OR
    Thanks, I must have missed those in my catching up.
  16. Nov 6, 2017 at 10:57 AM
    #436
    Livinserene
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
    Lol ya man ,, easy to do
    Trident904[QUOTED] likes this.
  17. Nov 6, 2017 at 5:08 PM
    #437
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Gawd, these throttle gauges are just weird.
    The first one was coasting at a lower gear / higher RPM.
    The second was coasting in 6th gear.
    Both on the highway.
    I can't really decipher these. Other than Throttle matches up with what I saw on another page.
    The readings all swing at different rates to different percentages while on the throttle.
    BTW, the Speed Diff compares ECU speed to the phone GPS.
  18. Nov 6, 2017 at 6:13 PM
    #438
    pjensen641
    Boone, IA
    I believe the pedal and tps all have redundant sensors for safety. I'd guess that is why there are so many different PIDs.
    I'm gonna refrain from any more OBD discussion on this thread so no one gets pissed:). Maybe one of us can start a new thread.
    tonered likes this.
  19. Nov 6, 2017 at 9:38 PM
    #439
    Kamille.bidan
    Kamille.bidan Well-Known Member
    2017 Blue TRD OR MT
    I see... Very interesting read.
    I could follow along for the most part, but this way outside my knowledge base. Are there other people the perform these analyses?
    I am sure OVtune knows what he (or they) are doing, but it would be a lot better if a secondary source could verify this.
    The Tacoma isn't some throw-away truck. It's one of their top selling vehicles. Why would they make all these weird decisions?
    This is, I believe, the first Tacoma to be mostly designed by Americans. I hope that's not the reason why.
    I bet a ban that the next Tacoma will share a global Platform with the Hilux and it will again be mostly Japanese designed.
  20. Nov 7, 2017 at 3:25 PM
    #440
    JebSmith2112
    Jeb
    Non yet
    I am not concerned with different dyno days, different trucks, and different temps. The proper comparison is a before run, tune, then run again. Same day, same dyno.
    AnalogDan and bshammer0[QUOTED] like this.
Thread Status:
