2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. May 8, 2018 at 12:34 PM
    #5821
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    Still waiting on new flash manager, but you can direct download the tune files for now:
    Edit: I see your confusion now. It does sound like these are for final testing purposes.
    RaunchBox[QUOTED] likes this.
  2. May 8, 2018 at 12:34 PM
    #5822
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    If you've tuned your truck in the past already, just grab the correct file for your ecu using the links in Mat's last post, point PCMFlash at that file and flash!
  3. May 8, 2018 at 12:41 PM
    #5823
    MOC221_
    Frank
    Initial review of 1.04A.
    My 04B10 equipped 2GR is UNCORKED again.
    No weirdness noted (stutters have not returned);
    Power of 1.03C with good throttle control (maybe just a C hair more sensitive off idle to 1000 rpm than the 1.03C T2 file was);
    35-40 mph back road cruising in 6th with no issue at all;
    Low end and especially midrange torque is back to 1.03 B/C levels;
    MTF over in the review thread once all the trims n shit have settled in (100's of kms).
    :burnrubber: Great work Mat and testers, this file is a good one so far :)
  4. May 8, 2018 at 12:47 PM
    #5824
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    After my "extensive test drive", 1 mile back to work, I can say without a doubt that the truck still runs:anonymous: in all honesty,I drive this route 4 time a day and am very familiar with how my truck behaves. Initial impression is that throttle is responsive and predictable not too touchy at low rpms and the "drive by wire lag feeling" seems diminished. I was flashed back to 1.03b before flashing this new file and the power is very similar if not more refined. I will be doing a little more "testing" and a log after work.
    ETA 04b12
  5. May 8, 2018 at 12:59 PM
    #5825
    AFMurse2014
    AFMurse2014 Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    Wooooo
    MOC221_ likes this.
  6. May 8, 2018 at 1:00 PM
    #5826
    RaunchBox
    RaunchBox Well-Known Member
    Tim
    Mooresville, NC
    2017 Tacoma TRD Pro 6MT
    RCI Sliders RCI Control arm Skids Prinsu Cabrac Tepui RTT KB Voodoo bed rack OVTuned
    Thank you!
  7. May 8, 2018 at 1:18 PM
    #5827
    disk_55FL
    disk_55FL Well-Known Member
    disk
    Buckeye
    '17 TRD Sport MT
    91 only ? ....... 87 tune is not released ..... right ?
  8. May 8, 2018 at 1:19 PM
    #5828
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    87 will be, the 91 tunes are ones that the ECU calculates different torque figures (as all things like vvt, airflow, ignition, fuel, etc go into what is the final torque calculation) so as long as all things match on 91, 87 will be no trouble at all
    17TRDOR likes this.
  9. May 8, 2018 at 1:41 PM
    #5829
    fzj40
    fzj40 Well-Known Member
    R
    2017 TRD OR MGM 6MT
    I'm still searching for the link - can someone please repost?
  10. May 8, 2018 at 1:42 PM
    #5830
    Comb
    Comb Known Member
  11. May 8, 2018 at 1:46 PM
    #5831
    fzj40
    R
    2017 TRD OR MGM 6MT
    Gracias!! - now i remember reading that, lol!
  12. May 8, 2018 at 1:57 PM
    #5832
    disk_55FL
    disk
    Buckeye
    '17 TRD Sport MT
    Thanks Mat ....... rapid response !
  13. May 8, 2018 at 2:04 PM
    #5833
    Livinserene
    Livinserene Thejerkyguy
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
    Hahahha love your timing sir Matt!! 14 days till I can tune,,!!:rofl::p
    MOC221_ likes this.
  14. May 8, 2018 at 2:14 PM
    #5834
    fzj40
    R
    2017 TRD OR MGM 6MT
    OK, took me a while to remember how to start PCM Flash as it does not show up in my applications. Anyway, 1.04A_91 is installed, and I removed the Pedal Commander that I have been running on 1.03B. Will wait until it cools and start it to let it idle from cool. Have kept it on 93 octane since first version of the tune (early adopter). Will report either tonight or tomorrow. PC is riding with me in case of error. Good luck everyone!!!
    su.b.rat likes this.
  15. May 8, 2018 at 2:39 PM
    #5835
    bradshawnh
    bradshawnh ...to the rescue!
    Boston, MA
    2017 TRD OR DCSB 6MT, Tech, Inferno
    I ran 1.04A tonight on the 20 miles home. I also went on a 10ish mile lunchtime drive with 1.03C to calibrate.
    1.04A seems to me to basically be 1.03C with a much more smooth and controllable throttle. No delay (expected that) and no other weirdness noted. I did the 10 minute idle suggestion both times I flashed. I also love how there’s no more rev hang. When you move to neutral or push in the clutch, BAM. Idle. Much more predictable for a seasoned MT driver.
    I did not see a MPG improvement as many of the AT owners have noticed. Maybe I am still in the “honeymoon” phase with the additional power and acceleration.....:D
    One thing to note - it seems engine braking is reduced on 1.04A. I am well acquainted with this since I am in a lot of stop and go traffic every day, and it was definitely reduced from stock levels. I’d like to see more.
    I drive the same road every day...I always used to have trouble at 65mph going up a certain local highway hill. I usually downshifted to 5th to keep from losing speed. On 1.03C and 1.04A both, I am able to accelerate up the same hill, while remaining in 6th gear. TRULY impressed!
    Quick details - 17 OR 04B12 lifted on 285s with 400lb of armor
  16. May 8, 2018 at 3:28 PM
    #5836
    su.b.rat
    su.b.rat broken truck
    I'm just curious about this, what settings were you using on the Pedal Commander and what were you looking to accomplish with it exactly? you know i ran one for months until the Alpha here dropped and i haven't used it since. but for 1.03C I'm curious what you're getting out of it.
  17. May 8, 2018 at 3:29 PM
    #5837
    cylon58
    cylon58 Active Member
    Geoff
    East Tennessee
    2018 TRD Pro MT Black
    I'm excited that this has dropped the day I placed my order from OVTuned. If I remember correctly the order said it would ship on May 15th, so hopefully by the time I get the kit the 2018 files will be ready!
    :fingerscrossed::bananadance:
    MOC221_, mZiggy and su.b.rat like this.
  18. May 8, 2018 at 3:46 PM
    #5838
    fzj40
    R
    2017 TRD OR MGM 6MT
    @St.Germain - I liked the throttle on 1.03B and so retained it; never flashed 1.03C. I was already running the PC on Sport with attenuation set all the way low when I loaded 1.03B, so I never experienced the tune without the PC. I live in Tampa FL, and run A/C all year except a few nice days, and a good number of mornings in the "winter". No issues with traction on ice / snow around here. I flashed 1.04A today and removed the PC. If I don't the like throttle response I will reinstall the PC and fiddle with the settings to get what I like. Hope this helps!
  19. May 8, 2018 at 3:48 PM
    #5839
    iexc
    iexc WerXED BH2.0 AD
    Kalede
    Toronto
    2023 TRD Sport MT
    :smack:
  20. May 8, 2018 at 3:49 PM
    #5840
    su.b.rat
    and you have armor/added weight as well? thought I've seen it mentioned maybe..
Thread Status:
