2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. May 12, 2018 at 11:47 AM
    #6001
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Sure thing. I'll PM you. I just wanted to see if anyone else was noticing an issue. I didn't want to bring up a problem that may not be tune related.
  2. May 12, 2018 at 12:03 PM
    #6002
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
  3. May 12, 2018 at 1:25 PM
    #6003
    iexc
    iexc WerXED BH2.0 AD
    Kalede
    Toronto
    2023 TRD Sport MT
    Iexc likes this
  4. May 12, 2018 at 1:57 PM
    #6004
    iexc
    Kalede
    Toronto
    2023 TRD Sport MT
    I had 2nd Gen 4 banger and had to turn ac off if I had to stomp it from a stop to get that added power.
    Less of an impact on this v6 but still there.
    If you bought Tacoma because it’s a Tacoma and you love Manuel like most here,YOU MUST GET THIS TUNE ASAP.
    This tune was worth it from version 103c.
    You will be blown away.
    Oh and use this meme when possible:burnrubber:it is our MT mascot.
    Check OVTUNE website for info
    Shellshock and Livinserene like this.
  5. May 12, 2018 at 3:47 PM
    #6005
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    Second gear in my truck has had a dead spot in it from day one. Only happens when I really should be in 1st gear but try to carry on any way in second. I agree the lack of throttle response there is kind of dangerous and can get you in some sketchy situations.
  6. May 12, 2018 at 4:46 PM
    #6006
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    A tune can only do so much. No matter what throttle response or even full throttle if you're at near idle speed or barely above 1000 rpm in a higher gear it's going to bog and pull slow until you get into a more efficient RPM range that can produce more torque. I can't make this 3.5L act like a V8. Hell even the LC500 with a 470HP 5.0L has no power whatsoever under 3000 RPM. Go into 3rd or 4th gear and floor it under 2000 RPM you're not going to accelerate faster than a prius.
    depending on configuration this truck can weight 4400+ lbs, and a 3.5L v6 at very low rpm isn't going to take off like some expect
    iexc, 17TRDOR, Livinserene and 6 others like this.
  7. May 12, 2018 at 6:33 PM
    #6007
    fzj40
    fzj40 Well-Known Member
    R
    2017 TRD OR MGM 6MT
    Mat,
    You have done wonders. I drove the tune on rural and highway roads today. Wow! Total pleasure to drive. Huge improvement in torque above 2k.
    Nicely done!
    Thank you.
    tacogravy likes this.
  8. May 12, 2018 at 7:06 PM
    #6008
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    I'm not disputing the tune but I would like to see some hard data on the improvement of the tunes. Seat of the pants tells us yes there is something but how much? Maybe some zero to 60 times on the stock tune and the 104. Dyno results if someone has access. I realize the driveability improvmments can't be measured but curious on the performance gains.
    iexc and mkivr32 like this.
  9. May 12, 2018 at 7:08 PM
    #6009
    OVTune
    OVTune
    after 1.03 where we make our most gains with 91, all improvements from that has been to create a more stabilized tune with smoother drive-ability and increase in mpg/efficiency. Not every update that comes out increases power. There has not been an increase in performance (as in measured horsepower / torque ) from 1.03 and 1.04.
  10. May 12, 2018 at 7:19 PM
    #6010
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    So was there any performance gains with the 103 on 87 octane over stock? What was the measure performance gains on the 103 91 octane?
  11. May 12, 2018 at 7:21 PM
    #6011
    jbruce
    jbruce Active Member
    2017 Tacoma TRD Off Road
    Take your truck to the drag strip stock, then tuned, and find out for us.
    milescf likes this.
  12. May 12, 2018 at 7:26 PM
    #6012
    OVTune
    OVTune
    On 87 octane no, I have explained this quite a few times I think, getting more power out of 87 is very very difficult because the ignition is knock limited Even bone stock is already knock limited on 87. Yes the dyno sheets are on the alpha thread
  13. May 12, 2018 at 7:34 PM
    #6013
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Strange then that members are reporting very little difference between the 104 91 octane and the 104 87 octane. :notsure:
  14. May 12, 2018 at 7:44 PM
    #6014
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    You mean to tell me my Tacoma won't drive like a Tesla? I want power and I want it NOW!!! :angrygirl:
    Come on people.... It's a truck. We all welcome the added low end torque (shown in dyno charts), but this truck is never going to be competitive on a drag strip or road course. Keep in mind 90% of the tune improvements were with driveability and not performance/power. NA motors can only gain so much with only a tune. The fact that Matt was able to shift the usable torque down into the lower RPM range is a huge benefit even without being able to add 100 HP/TQ.
  15. May 12, 2018 at 8:10 PM
    #6015
    AFMurse2014
    AFMurse2014 Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    THIS!!! There are days where I'm wondering why the F it is driving so damn good (I'm stock tune)
    And then I'll park it and come back a few hours later and it's back to driving like shit
  16. May 12, 2018 at 9:39 PM
    #6016
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    Sociopenguin likes this.
  17. May 12, 2018 at 10:22 PM
    #6017
    Shellshock
    Iowa
    I’ve logged about 1500 miles on 1.04A 87 so far. Yes that is correct. Yes it just came out a couple days ago.
    Everything that I said in my earlier post is still true. This revision is fantastic and there are no issues here. The power delivery is so much better now it’s pretty incredible.
    @OVTune nailed it with 1.04A
    :burnrubber:
  18. May 13, 2018 at 8:01 AM
    #6018
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    I agree. Very smooth and linear power delivery. I'm not sure how much more could be done to make the drive-by-wire feel like a cable.
  19. May 13, 2018 at 8:11 AM
    #6019
    JJ18ORDBSBMT
    JJ18ORDBSBMT Well-Known Member
    1.05 FOB 91 2018 Off road White DC M/T
    From a rolling stop I went from 2nd gear to 4K then I tried from 1st gear rolling stop to 4K rpm.
    I didn’t experience anything out of the norm.
    You rev to 5k? You youngens are crazy.
    iexc likes this.
  20. May 13, 2018 at 8:22 AM
    #6020
    mkivr32
    mkivr32 Well-Known Member
    Dan
    Long Island, NY
    2017 White TRD Pro MT
    I've noticed this too, totally get Matt's explanation on it. I wish there was something to do about this, I personally hate first gear in this truck and try to avoid it at all cost.
    pinochle likes this.
Thread Status:
