2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. May 13, 2018 at 8:29 AM
    #6021
    Shellshock
    Iowa
    Agreed. Rarely do I ever go over 4k
    mZiggy and 2016trdtacoma like this.
  2. May 13, 2018 at 9:38 AM
    #6022
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    So here is an explanation of what I'm experiencing.
    I'm running the 104 87 octane tune on my '18 Sport. Here's the issue. I noticed that when I shifted out of first into second the truck would buck(small hicup) when accelerating. I decided to test if I could get the same symptom to occur in first gear. So with the truck in first gear and off the clutch and creeping along at just above 1,000 rpm I would do a full acceleration run to around 5,500 rpm. What I noticed was that the power output was not linear. It would accelerate slower from 1k say to 2k then after 2k it would accelerate strong to around 3k. Acceleration would then slow between 3k and 4k then pick up again. You would have this acceleration burst about three time from 1k to redline. The truck accelerates fine and it's quick but not linear in power delivery. My rpms that I reported are approx. because it's impossible to give and exact number because the rpms climb quickly. I notice it as well in second but not as bad and I suspect it's becuase of the higher gear ratio. Third I can't feel it. Under normal accelleration there isn't an issue.
    I decided the flash back to the stock tune and try the same test. I felt the same with the stock tune as with the 104. I flashed back to the 104 and will put some miles on it and see if it improves.
    iexc likes this.
  3. May 13, 2018 at 9:57 AM
    #6023
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    Are you turning traction control off? Pretty sure it will be limiting throttle in 1st gear with hard acceleration.
    pinochle likes this.
  4. May 13, 2018 at 10:44 AM
    #6024
    iexc
    iexc WerXED BH2.0 AD
    Kalede
    Toronto
    2023 TRD Sport MT
    DFCO and revhang:thumbsup:
    Lots can be done
    Boxerocks, ajsabra and mkivr32 like this.
  5. May 13, 2018 at 11:02 AM
    #6025
    JJ18ORDBSBMT
    JJ18ORDBSBMT Well-Known Member
    1.05 FOB 91 2018 Off road White DC M/T
    Tried it this morning. In a rolling stop, 2nd gear acceleration from 500 rpm was slow until 1500 rpm when the power snapped to. Kinda dead from 500-1500 in 2nd.
    91 tune
    MOC221_, Ruggybuggy and mkivr32 like this.
  6. May 13, 2018 at 2:01 PM
    #6026
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    I started all this because I'm getting a jerky jerky from 1st to second. Driving normal I shift from first to second clutch is out and as soon as I get back on the accelerator I get one or two jerk jerks then it accelerates normal. This happens when the rpms are around 1500 and not every time. If I hold first gear longer so the second shifts are above 2,000 rpm no jerky jerky.
    cokish, mstrbrc and iexc like this.
  7. May 13, 2018 at 2:24 PM
    #6027
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    A log would be most helpful but I'm 99% certain it's from VVT. The very low RPM range the intake VVT can go from complete retard (a lot of negative degree) to full advance, which is a huge sweep which if I recall correctly is a difference of 80 degrees. I figure most people aren't going to be flooring it right off idle so they would benefit from the additional intake retard for better mpg
    Shellshock, lapoltba and iexc like this.
  8. May 13, 2018 at 2:42 PM
    #6028
    NME
    NME Active Member
    Mark
    NW WASHINGTON
    2017 Tacoma TRD OFFROAD 6 speed manual
    6" BDS PERFORMANCE SUSPENSION FOX UPPER CONTROL ARMS FOX SHOCKS 4.88 NITRO 35X12.5X18 BFG KM2'S K&N BLACKHAWK INTAKE AIRAID TBS OV TUNING FLOW MASTER 40 SERIES NFAB RUNNERS NFAB LIGHT BAR MOUNTS RIGID BLACKOUT LIGHT BAR GTR GEN 3 LED HIGH/ LOW/ FOG
    I've only put 100 miles on the new 104 tune. But I'm liking every bid of of it. The annoying chirping of the intake at 2,500 rpms is gone, along with what others have posted. Thanks
    MOC221_ likes this.
  9. May 13, 2018 at 3:26 PM
    #6029
    iexc
    Kalede
    Toronto
    2023 TRD Sport MT
    This makes sense,but is this part of the operating soft ware adjustable or removable .?
    I to find the lack of power in the lower end very annoying.
    Witch brings us to full OTTO .
    Is this on the table?
    While I am a staunch aponant of DFCO and REV HANG I am now leaning toward this feature.
    I am finding as time passes with this project people are becoming more interested in power and driveability than fuel savings.
    Especialy with the recent interest in your turbo project.
    Boxerocks and mZiggy like this.
  10. May 13, 2018 at 5:06 PM
    #6030
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    I should clarify, this isn't flooring it. It happens when driving normally.
    MOC221_ likes this.
  11. May 13, 2018 at 5:37 PM
    #6031
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    So just after you release the clutch on an upshift to second and the RPM falls to 1500 - you feed the gas normally and get a "ruh ruh" response and then normal acceleration?
    I don't think my truck has done this on 1.04, but it definitely would stock. Maybe a 87 file or '18 thing?
  12. May 13, 2018 at 5:51 PM
    #6032
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    No “ruh-ruh” with mine when it has happened just a dead spot in acceleration. No matter how much skinny pedal you give it. I am blaming it on stability control and or traction control killing the throttle.
    su.b.rat likes this.
  13. May 13, 2018 at 6:05 PM
    #6033
    iexc
    Kalede
    Toronto
    2023 TRD Sport MT
    I just did this test and it is there .
    Like a double lag.
    It is just how you explained it from 1st then little in second.
  14. May 13, 2018 at 6:26 PM
    #6034
    JJ18ORDBSBMT
    Yea feel that. Rolling stop at a stop sign. Drop it to 2nd and u feel the ruh ruh u til rpms kick to like 1900-2100
  15. May 13, 2018 at 6:58 PM
    #6035
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Yes you described it perfectly. I flash to stock at it was there then reflashed to 104 and still there. When I was running the 103's I did have it happen. I think I may reflash to 103 and see if it persists.
    I used the truck tonight and had my wife with me and see felt it as well. Also noticed it when pulling into my parents driveway in first gear, low rpms and it did the jerk jerk climbing a slight grade.
  16. May 13, 2018 at 7:00 PM
    #6036
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Your running the 104? Did you have the same thing with the 103 tunes?
  17. May 13, 2018 at 7:01 PM
    #6037
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Do you recall it happening on the 103 tunes?
  18. May 13, 2018 at 7:02 PM
    #6038
    RedBeard1
    Red
    On mine it was really bad with the 1.03 tunes. It is significantly better on 1.04
    Ruggybuggy likes this.
  19. May 13, 2018 at 8:56 PM
    #6039
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
  20. May 13, 2018 at 8:59 PM
    #6040
    OVTune
    OVTune
    if someone wants to run through about 3-5 files with logging to dial in OTTO only on the cams, let me know and we can create a tune for it. Will it be well received ? I don't think so.
    I'll add the changes to the driver demanded torque tables too on top.
Thread Status:
