2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. May 23, 2018 at 11:11 AM
    #6241
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    Where does one send a gas sample to be tested?
  2. May 23, 2018 at 11:12 AM
    #6242
    Halibut
    Halibut Well-Known Member
    Alaska
    18 OR SB MT
    Looks like he sent it to CAT
    Edit maybe Blackstone does this also, like a used oil analysis
    2016trdtacoma[QUOTED] likes this.
  3. May 23, 2018 at 12:35 PM
    #6243
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    I sent mine into Caterpillar because it is readily available to me but any company that does petroleum products testing should be able to test it for you.
    Yeah the truck went to running bad after 2500-3000 miles on the 1.03c tune so I was pretty sure it was not the tune. No changes to the truck and the weather was pretty consistent at the time. Fuel was the obvious culprit in me case.
    Keeping close tabs on my fuel as always and religiously using Lucas upper cylinder lubricant has kept me and the engine happy.
  4. May 23, 2018 at 5:16 PM
    #6244
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Welp, here we go...
    Will it be OV or Stamkos moving on to the final?
  5. May 23, 2018 at 8:26 PM
    #6245
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    This is what I would love for throttle response on my Tacoma. Highland 2GR-FKS VS TACO 2GR-FKS.
  6. May 23, 2018 at 8:31 PM
    #6246
    BeaverNation
    BeaverNation Well-Known Member
  7. May 23, 2018 at 8:52 PM
    #6247
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    Yes, flywheel rather than flex plate...
  8. May 23, 2018 at 9:02 PM
    #6248
    ajsabra
    ajsabra Fully locked 3rd gen
    Sin city
    2016 Tacoma DCSB 4X4 Manual
    Front suspension : Extended travel Kings with Total Chaos UCAS Rear suspension : Deaver progressive AAL w/out overload & Kings Rims : SCS SR8 17" Tires : Bfg KO2s 285/70/R17 ARB Compressor ARB Lockers front and rear with 4.88 gears Nitro 4.88 Gears TRD Pro Grill, and fogs Headlight BHLM Rigid Radiance 32 stealth mounted.
    I would be so happy if that was possible on a tacoma....
    iexc likes this.
  9. May 23, 2018 at 9:10 PM
    #6249
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Your still turning the torque converter which I suspect weights more than a flywheel. Also the auto Tacoma has the same throttle response as the manual.
    Boxerocks and iexc like this.
  10. May 23, 2018 at 9:11 PM
    #6250
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    I want to know why isn' it possible? :notsure:
    2016trdtacoma and iexc like this.
  11. May 23, 2018 at 9:15 PM
    #6251
    ajsabra
    Sin city
    You and I both, but everyone tells me its our flywheel, and that I'm too picky....
    Maybe @OVTune can chime on in of why it isn't implemented in the tune.
  12. May 23, 2018 at 9:45 PM
    #6252
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    That's BS about the flywheel. The auto taco has the same slow throttle response.
    Boxerocks and 02Duck like this.
  13. May 23, 2018 at 10:14 PM
    #6253
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Hmm I have driven the auto and the manual and I think the manual has worse response stock.
  14. May 24, 2018 at 3:30 AM
    #6254
    iexc
    iexc WerXED BH2.0 AD
    Kalede
    Toronto
    2023 TRD Sport MT
    :wave:
    cylon58 likes this.
  15. May 24, 2018 at 3:55 AM
    #6255
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    If you've noticed a difference it's marginal and neither are even close to the Highland, Sienna or Camry.
    Boxerocks and 0uTkAsT like this.
  16. May 24, 2018 at 3:56 AM
    #6256
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    Shellshock and iexc[QUOTED] like this.
  17. May 24, 2018 at 4:14 AM
    #6257
    MOC221_
    Frank
    Not to mention the throttle response is way better when stopped/clutch in than it is when in neutral/clutch out OR when blipping (in motion).
    Flywheel is in play the whole time guys. Don't try and tell me that adding the transmission internals/fluid to the equation is making that much of a difference.
    I'm sure if Mat had access to a M/T test mule for more than a day he could dial the throttle in for us. You can only do so much by remote testing.
    Anyway, just an observation..
  18. May 24, 2018 at 5:09 AM
    #6258
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Go try the auto Taco. It still has a slow throttle response and isn't even close to the Highlander. Would you like me to add a video?
  19. May 24, 2018 at 12:45 PM
    #6259
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    Looks like maybe the Highlander gets kind of a head-start?
    It starts out about 200 or 300 higher in RPM before you punch it?
  20. May 24, 2018 at 8:26 PM
    #6260
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    No trickery here. It's indisputable that the Highland, Sienna and Camry have a quicker throttle response. Go try one for yourself.
    I would really love to see if OV can get our throttle to act in a similar way.
    Boxerocks, iexc and orangeracer like this.
Thread Status:
