2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Jul 4, 2018 at 8:48 AM
    #6761
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    The one for the dongle version only lets me download 1.03C.
  2. Jul 4, 2018 at 10:17 AM
    #6762
    orangeracer
    orangeracer Well-Known Member
    18' DCSB TRD OR 4x4 w/6spd MT
    Yes mines a manual. It also happens in other gears during acceleration and sometimes at 5k-6k rpms. It does not happen with the stock tune. Definitely not the clutch rattling.
    2016trdtacoma[QUOTED] likes this.
  3. Jul 4, 2018 at 2:25 PM
    #6763
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    I am into the game a little later than some, and only have the dongleless version with 1.04. I believe 1.04 is only with the dongleless version. Also, I think you have to work with Matt to get switched over, if you originally started tuning with the dongle set-up. I do remember reading where the newer files are liked to your computer and you would have to work with him if you had to replace your computer for some reason.
  4. Jul 5, 2018 at 3:26 AM
    #6764
    iexc
    iexc WerXED BH2.0 AD
    Kalede
    Toronto
    2023 TRD Sport MT
    0b410 87oc knock sensor recal.
    I am experiencing somthing very similar but it is not repeat able.
    I have tech stream but what am I looking for.is it the same as the test file perameters and 2 gear hard pulls to red line?
  5. Jul 5, 2018 at 3:27 AM
    #6765
    iexc
    Kalede
    Toronto
    2023 TRD Sport MT
  6. Jul 5, 2018 at 11:35 AM
    #6766
    JOSH_R
    JOSH_R New Member
    Josh
    2016 Tacoma TRD Off-Road MT
    Does anyone else experience weak engine braking going downhill? The engine just keeps revving up no matter what gear I downshift to. It is very annoying and potentially unsafe constantly hitting the brakes going down long mountain passes. Is this from the "Atkinson" cycle? If so is this something that can be tuned out?
    AFMurse2014 likes this.
  7. Jul 5, 2018 at 1:02 PM
    #6767
    Halibut
    Halibut Well-Known Member
    Alaska
    18 OR SB MT
    Where I live the dump is up a half mile, 10-15 degree grade with switchbacks. I use first downhill, get up to maybe 2750 rpm max, and don't have to touch the brakes, 2nd works if it's dry and I want to go a little faster but also use the brakes before corners.
    I think many on this thread have noticed, esp in low range, the engine resumes fueling around 1500 rpm. Over that, it should be engine braking.
  8. Jul 5, 2018 at 4:07 PM
    #6768
    iexc
    Kalede
    Toronto
    2023 TRD Sport MT
    That’s the the rev hang. If you don’t rev past around 2700rpm rev hang will kik in.it is being introduced in to all modern vehicles and is a nightmare for manual drivers.
  9. Jul 5, 2018 at 4:12 PM
    #6769
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    Like @iexc said there is some component of the “rev hang” and the DFCO that cause the poor engine braking. Pick a gear that gets you into the 3k rpm range and it will do a lot better.
  10. Jul 5, 2018 at 4:22 PM
    #6770
    RedBeard1
    Red
    @OVTune
    After taking your advice and switching to the 1.04a 87 tune my pinging issue has been resolved from what I can tell. I have a CPS on order to swap mine out and I and give the 91 tune a try again.
    I have still been unsuccessful in getting Techstream up and running on my laptop. If anyone could offer some advice on getting the available versions of it to load and run properly it would be welcomed. PM box is open...lol
  11. Jul 5, 2018 at 6:32 PM
    #6771
    JOSH_R
    JOSH_R New Member
    Josh
    It happens on anything over about a 5% grade, coasting downhill in any gear, not touching any pedals. There is some weak engine braking but rpms will keep climbing to 4500 rpm+ (It would go higher but I'm hitting the brakes by then).
    @OVTune Does the OVTune fix this or can it be programmed to?
  12. Jul 5, 2018 at 7:15 PM
    #6772
    yotatoy4me
    yotatoy4me Member
    Eric
    2017 MGM Tacoma OFF ROAD MT DC
    My truck has been doing this same thing intermittently. Can only make truck produce noise when pulling a steep grade usually at higher elevations. Most recently when pulling a trailer (3500lbs) up a moderate grade around 3500 rpm's. I am running on a stock motor and do not want to tune due to this unknown noise.
  13. Jul 5, 2018 at 8:05 PM
    #6773
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    People who complain about rev hang will be happier once they allow themselves to acknowledge the fact that they drive a truck, not a racecar. Rev hang will be there. This motor doesn't need to be as responsive and hyperactively rev happy as the hot turbo hatch you used to race from stoplight to stoplight in. Plus, the rev hang has been reduced in the tune anyway. Way worse on the stock tune.
  14. Jul 5, 2018 at 8:44 PM
    #6774
    JOSH_R
    JOSH_R New Member
    Josh
    Whoah there! I’m just trying to find a solution for the lack of engine braking while going downhill in gear causing me to have to ride the brakes.
  15. Jul 5, 2018 at 8:48 PM
    #6775
    mZiggy
    mZiggy Honey badger
    Marc
    Lol sorry. Seeing any mention of rev hang is kind of a pet peeve for me, borne of months of people complaining about it.
  16. Jul 5, 2018 at 8:57 PM
    #6776
    Burro09
    Burro09 Well-Known Member
    Miami, FL
    2017 Tacoma TRD Pro Cement MT
    This truck isnt bad with rev hang during normal driving, much better than early 2000s manual toyota products which had brutal rev hang, even to the point where the revs rised a bit between shifts.
    But lets be honest, the throttle response from this truck is so hit and miss. There is a strange excessively long rev hang under moderate load in the upper RPM range. It makes it hard to shift smoothly without jerking it into the next gear. It doesnt happen when shifting near redline or at low rpms and loads.
    Rev matching on down shift, not even while braking not to bob passengers heads (im ocd with this) is so inconsistent. Muscle memory in your foot never applies as to how much throttle to quickly give it before releasing the clutch.
    The day this tune gives us near cable throttle function, I am in.
    Its not even the power. Truck is fine power wise for me. Its the throttle acting like a ships telegraph which is annoying.
  17. Jul 5, 2018 at 9:02 PM
    #6777
    mZiggy
    mZiggy Honey badger
    Marc
    i hear you, but i disagree about the muscle memory and whatnot not resulting in consistent accurate downshifts. I do it every day without issue or fail. Still had issues with it on 1.03 and 1.03B, but I stopped having the issue with 1.03C and I'm now on 1.04 and still no issues with downshifting smoothly, consistently.
    If it makes you feel better, it's been well established within this thread that my truck has far less issues with tunes flashed than others. @MOC221_ calls it the honey badger lol so if operator error isnt an issue (and I'm not saying you're at fault), then maybe my cement flavored unicorn is the key ingredient for some reason
    pinochle likes this.
  18. Jul 5, 2018 at 9:13 PM
    #6778
    Burro09
    Miami, FL
    Guess I should try the tune already lol.
    We have the same truck.
    The thing is while it may not feel bad to some, its frustrating for peeps who have old cable operated manual toyotas. Going from my taco to my old cars (toyotas) is a breath of fresh air on the throttle behavior. Guess they dont make them like they used to lol.
    I wonder if its even possible to get a 1:1 response between pedal and throttle plate in these.
    For example, rev the engine in neutral with clutch pedal in = faster response. Release the pedal and try that again and you get an artificial closing of the throttle, way slower. Cars did this back in the day with dashpots on the throttle plate, but it was consistent and unobtrusive. Just to keep the throttle body from slamming shut and reducing emissions a bit.
    Just voicing my take on the trucks accelerator behavior. I should get the tune but im waiting for it to mature even more.
    I guess il end my rant lol. Still love this truck. Thank toyota you can even get it with 3 pedals.
    Boxerocks, 02Duck, iexc and 1 other person like this.
  19. Jul 6, 2018 at 3:05 AM
    #6779
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    You and I are on the same page sir. My biggest complaint about the M/T was the inconsistent and drunk AF throttle. I'm not going to say it's perfect (honeybadger style), but throttle response is much MUCH better tuned. You'll notice Mat is still working on it, in that he commented on making it even better (possibly with 1.05 release). I'm not sure why you're waiting to get the tune, as you'll have access to all future updates anyway.
    Your call of course, but I wouldn't go back to the stock calibration if you paid me to do it.
    Oh and for future reference, my truck is at the opposite end of the scale to @mZiggy 's. Redheaded stepchild of 3rd gen M/Ts. Stuttering mof@cker. Lol, anyway.. patiently awaiting update to throttle in next version of OVtune.
    Livinserene and Boxerocks like this.
  20. Jul 6, 2018 at 3:06 AM
    #6780
    MOC221_
    Frank
    @iexc
    Good morning, sir.
    :wave:
Thread Status:
