2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Aug 30, 2018 at 10:58 PM
    #7341
    JJ18ORDBSBMT
    JJ18ORDBSBMT Well-Known Member
    1.05 FOB 91 2018 Off road White DC M/T
    I couldn’t find my laptop charger. I bought one that arrived today. Ended up not needing it. Oh well. Oct1?
  2. Aug 31, 2018 at 8:48 AM
    #7342
    Reluctanse
    Reluctanse Granny shiftin, not double clutchin
    Sam
    Newberg, Oregon
    '17 Tacoma DCSB Inferno TRD OR 6MT
    OVTuned, Grabbers, 5100s, Bakflip VP
    Quiet in here lately. Maybe the calm before the storm?
    2016trdtacoma likes this.
  3. Aug 31, 2018 at 9:03 AM
    #7343
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    Hope so. Really hoping it drops in today or the next :fingerscrossed:
    M1Awolf likes this.
  4. Aug 31, 2018 at 10:03 AM
    #7344
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    Today would be nice,I have a trip this weekend and it would be a great test drive on the new tune.
  5. Aug 31, 2018 at 10:40 AM
    #7345
    2016trdtacoma
    Trevor
    Utah
    Exactly :)
  6. Aug 31, 2018 at 6:14 PM
    #7346
    Shellshock
    Iowa
    I have no trips to take but if 1.05 drops I’ll take one to somewhere
    iexc, MOC221_ and mZiggy like this.
  7. Sep 1, 2018 at 12:14 PM
    #7347
    frstflt
    frstflt Member
    andrew
    Just flashed for first time, 1.04 87. Initial thoughts are that it is pretty good and nice that they can do anything with a normally aspirated engine. I keep a FWC Swift camper on most of the time so was excited to get some power back. However, it is not really a game changer and truck still a bit of a dog below 2200(which is better than 3400). From a dead stop it is still a stinker and cannot comfortably start in 2nd as I have been able to with every other MT truck I've owned. Looking forward to calculating MPG and will try the 91 with the next tank. Toyota should have dropped a more torquey engine in it because everything else about it is wonderful.
  8. Sep 2, 2018 at 4:02 PM
    #7348
    ajsabra
    ajsabra Fully locked 3rd gen
    Sin city
    2016 Tacoma DCSB 4X4 Manual
    Front suspension : Extended travel Kings with Total Chaos UCAS Rear suspension : Deaver progressive AAL w/out overload & Kings Rims : SCS SR8 17" Tires : Bfg KO2s 285/70/R17 ARB Compressor ARB Lockers front and rear with 4.88 gears Nitro 4.88 Gears TRD Pro Grill, and fogs Headlight BHLM Rigid Radiance 32 stealth mounted.
    Well, looks like ovtune started his new thread about the twin turbo setup!
  9. Sep 2, 2018 at 4:21 PM
    #7349
    iexc
    iexc WerXED BH2.0 AD
    Kalede
    Toronto
    2023 TRD Sport MT
    For those waiting for 105 and not on the alpha thread.
    FROM MAT
    I just posted in the thread the reason why it is taking longer, Toyota went from updating 2 ECU versions to updating more than 6. Does not sound like much but each one has different shift control characteristics and tables (except for the 2 manuals). Not to mention table locations, addresses, etc are all changed.
    It is being actively worked on while I finish a solution that can be given to everyone without worry. I do not have a set in stone date yet but it won't be that much longer. I am not sure what else I can say. I'll show you guys the differences and what the current obstacles are to overcome if that is what you want to know. Here is 1 of the major issues, the exact same transmission (auto) is in the tacoma (Mexico version, South American version) and Prado (China, Australia) with different shift control tables. You can take just the OEM "USA" shift tables, plug it into the Mx vehicles and the truck cannot shift. There is no clear reason as to WHY this is, yet.
    That's one of a few obstacles at the moment.
    That's excluding the investigation of detonation on the new TSB on NON tuned trucks.
    This truck has a very serious problem with detonation and I WILL NOT RELEASE A MAJOR UPDATE UNTIL THIS IS SOLVED.
    It all comes back to this configuration of tables in this ECU, I am 99% sure it's the root of all of the issues and reason for multiple updates by Toyota. The 16+way "demand" tables... They don't exist in older ECUs, they don't exist in most newer ECUs, nor Toyotas new stragety on their Dynamic Force engine and RH850 ECUs. Almost like the 2GR-FKS and 8AR-FTS were experiments....
    It exists on literally the 2GR-FKS and 8AR-FTS and nothing else (that I have seen, and I've seen damn near every toyota calibration on the planet, including custom firmware like SAARD, etc)
    JJ18ORDBSBMT likes this.
  10. Sep 2, 2018 at 6:22 PM
    #7350
    orangeracer
    orangeracer Well-Known Member
    18' DCSB TRD OR 4x4 w/6spd MT
    That does that mean us manual guys may get our 1.05 release first?
    GF8er likes this.
  11. Sep 2, 2018 at 9:18 PM
    #7351
    HeyMrCarter
    HeyMrCarter Well-Known Member
    Anyone with an 18 MT running 1.04R (for A71)?
    MOC221_ likes this.
  12. Sep 3, 2018 at 8:05 AM
    #7352
    AFMurse2014
    AFMurse2014 Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    Untuned truck, but have the tsb done. I used to buck really bad on speed bumps/poor roads with low RPMs. I was a -10 ECU though. With the TSB it has smoothed out a ton but is still there and I still get some hesitations/stutters in 2nd but not nearly as bad.
    iexc likes this.
  13. Sep 3, 2018 at 5:03 PM
    #7353
    JJ18ORDBSBMT
    So I do feel the hesitation when the engin is cold. 1st to 2nd. It’s slight but it’s there.
    When 1.05?
    iexc likes this.
  14. Sep 5, 2018 at 2:19 PM
    #7354
    Reluctanse
    Sam
    Newberg, Oregon
  15. Sep 5, 2018 at 2:42 PM
    #7355
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    Everybody is oohing and ahhing over the idea of something that will be ridiculously expensive. I’m pretty sure there are a shit ton of the mpg whiners in there talking about how they can’t wait to get boosted. That right there is the definition of dumbassery.
    iexc likes this.
  16. Sep 5, 2018 at 3:07 PM
    #7356
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Ok? :notsure:
  17. Sep 5, 2018 at 3:28 PM
    #7357
    Trident904
    Brian
    17 4Runner TRD OR
    Just providing a theory as why this thread went quiet.
  18. Sep 6, 2018 at 2:28 AM
    #7358
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    Im honestly more interested in the equal length dual exhaust than I am the turbos. I am more apt to spend $5-10k on a turbo diesel swap than adding turbos to the 3.5L
  19. Sep 6, 2018 at 6:43 AM
    #7359
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    Whether or not people will want to accept it, adding boost will come with additional costs too. For us MT owners any high RPM shifts will quickly lead to the need for more clutch pressure and the accelerated loss of the OEM friction plate material. I've seen this stuff before and lots of people get excited for boost and then the cost of the applications typically kills 80-90% of them. Then watching those with boost need to replace parts kills the hopes of a few more. I encourage people to be excited, but also realistic.
    When I had my 4Runner a lot of people got excited for the Magnuson SC, the eventual cost of being 6500+ resulted in a hand full of people actually doing it. It looked no different than here, pages of interest and maybe 3-5 actual applications.
    As far as power and cost is concerned, I hope the Tacoma is more robust since it is a truck. But from my history, not with the Tacoma, I've seen that crossing the 350-400 to the ground eventually results in needing re-enforced gears and clutches. Cryoing the diffs and new clutches can easily push the out of pocket cost to very undesirable numbers.
    I'm sure that'll get some people heated, but it is what it is.
  20. Sep 6, 2018 at 8:03 AM
    #7360
    Trident904
    Brian
    17 4Runner TRD OR
    You failed to mention the aspirations of pulling up to a stop light and drag racing every fucking vehicle they line up with even if it’s a Honda Odyssey driven by a 47 year old Asian woman.
Thread Status:
