2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Nov 1, 2018 at 1:53 PM
    #7861
    bradshawnh
    bradshawnh ...to the rescue!
    Boston, MA
    2017 TRD OR DCSB 6MT, Tech, Inferno
    But more gutless than the stock tune?
    Tac0Tic0 likes this.
  2. Nov 1, 2018 at 1:57 PM
    #7862
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    Feels about the same to me in that situation. Try getting some more miles on it and let it learn in. Then see how it is.
  3. Nov 1, 2018 at 2:12 PM
    #7863
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
    Why does it matter? When is mashing it in 6th ever beneficial?
  4. Nov 1, 2018 at 2:14 PM
    #7864
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    45 is crazy low rpm in 6th. That is 1500rpm in 6th going 45mph. I wouldn't even try that in 5th. I stay in 4th and use 5th at 50mph and switch to 6th at 60+mph on flats.
    WalkinTaco and MOC221_ like this.
  5. Nov 1, 2018 at 2:27 PM
    #7865
    RedBeard1
    Red
    Where I do this is a down hill run through a small town. I only do this when traveling south through this town. My return trip is during school hours and then here are 2 school zones that are signaled by local sheriffs officers so there is no just rolling through town.
    If you haven’t done it you would not know but you have to get really deep into the lower rpm range to get this engine to lug. It performs really well in the low rpm range. Especially when crawling around off road. Better than the 4.0 in my FJ ever did.
  6. Nov 1, 2018 at 2:31 PM
    #7866
    bradshawnh
    Boston, MA
    If you know, you know.
  7. Nov 1, 2018 at 3:01 PM
    #7867
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    How true,I rarely if ever use 6th gear 4th @70mph or 5th @80 mph on the highway keeps it close to the powerband needed for passing and hills around here.
    Trident904[QUOTED] likes this.
  8. Nov 1, 2018 at 3:37 PM
    #7868
    iexc
    iexc WerXED BH2.0 AD
    Kalede
    Toronto
    2023 TRD Sport MT
    Steelhead Taco likes this.
  9. Nov 1, 2018 at 3:40 PM
    #7869
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    if someone is having actual issues with 6th I would like to know and get some logs of it. If you're driving the same way you always have been, and it doesn't feel right we need to know. Send us an email to request the logger, or download it from Flash Manager update in a few days and submit logs.
    Ruggybuggy and Tac0Tic0 like this.
  10. Nov 1, 2018 at 3:54 PM
    #7870
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    I'm in 6th at 40-45 daily during my commute. Back road, mostly flat. The truck will do it easily, you only have to give it a bit of throttle. It's not lugging either. Usually 5th is enough to get along over small hills at that range.
  11. Nov 1, 2018 at 3:54 PM
    #7871
    bradshawnh
    Boston, MA
    Thanks Mat for summing it up. Let me know how to take logs, I’d love to send them. I am doing a few hundred miles over the weekend so this could be a great opportunity.
    Halibut likes this.
  12. Nov 1, 2018 at 3:56 PM
    #7872
    bradshawnh
    Boston, MA
    AMEN.
  13. Nov 1, 2018 at 3:57 PM
    #7873
    fmfdadbod88
    fmfdadbod88 Well-Known Member
    2016 Black Tacoma TRD Off Road 4x4
    Any new eta on the earlier version mt ecu's?
    Boxerocks and disk_55FL like this.
  14. Nov 1, 2018 at 4:08 PM
    #7874
    RedBeard1
    Red
    Logs emailed earlier requests (2327).
  15. Nov 1, 2018 at 4:42 PM
    #7875
    tacogravy
    tacogravy Well-Known Member
    Gravy
    Mantua, Ohio
    17 TRD OR 4x4 Quicksand 6MT
    TRD Pro Grill, TRD Sport Hood, BAMF Sliders, Bilstein 5100's F&B, BF Goodrich KO2 265/75R16, Old Man Emu 887 Front, Head Strong 3 Leaf AAL Rear (Overload Leaf Left In), OVTuned, De-Badged. Accumulator Delete Mod.
    Can anyone describe their experience with 1.05 tip-in in first gear taking off from a stop? My two pet peeves with the truck is the inconsistency taking off from a stop and the first to second gear stumble. Although temperature does seem to play a part, it seems humidity effects both scenarios even more. Sometimes she takes off like a champ from a stop, other times it seems she hiccups as soon as the clutch grabs and sometimes results in an embarrassing stall. Thus the result of the inconsistency in throttle response.
  16. Nov 1, 2018 at 4:45 PM
    #7876
    specter208
    California
    Get more speed and momentum when you switch to 2nd or don't press on the pedal too hard is my only advice.
    tacogravy[QUOTED] likes this.
  17. Nov 1, 2018 at 5:15 PM
    #7877
    su.b.rat
    su.b.rat broken truck
    probably too early to assess this since you want to see climate variations. but so far it's totally different from all previous versions on take off for me. just one day, 60F medium humidity, clear sunny day.
  18. Nov 1, 2018 at 5:21 PM
    #7878
    Axxra
    Axxra Well-Known Member
    NC
    2017 DCSB TRD OR 4x4 6MT
    I'm waiting to post a more comprehensive review, but shifting has been much better for me. First to second has been smooth with almost no bogging and I haven't noticed my normal 4th to 5th driveline clunk.
  19. Nov 1, 2018 at 5:56 PM
    #7879
    tacogravy
    Gravy
    Mantua, Ohio
    Appreciate the feedback.
  20. Nov 1, 2018 at 7:04 PM
    #7880
    M1Awolf
    Rob
    Montana
    I can second this
    Axxra[QUOTED] likes this.
Thread Status:
