2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Jan 4, 2019 at 11:00 AM
    #8401
    su.b.rat
    su.b.rat broken truck
    certainly sounds like your return spring. let them look at it and if they turn you down and it's the spring, the disk brake grease will fix that 100%, you just need to apply it correctly... if your spring is dry and that's the issue.
    tonered likes this.
  2. Jan 4, 2019 at 11:34 AM
    #8402
    KillerSeabass
    KillerSeabass Well-Known Member
    Seb
    San Fransisco, CA
    Stock taco getting a incentive over
    None yet
    A little side bar from the current convo (and a return to an older discussion). The Ovtune website doesn’t have that much info on computer requirements besides it can’t be Mac (I know ppl are using bootcamp) or windows xp.
    Are there any memory requirments? I’m assuming the files are not the smallest out there. Would an android based tablet work (assuming irnhad the appropriate number of USB ports?
  3. Jan 4, 2019 at 11:36 AM
    #8403
    Shellshock
    Iowa
    need windows 7/10 so no Android would not work. Outside of that, its a fairly lightweight application so hard drive/memory/cpu don't really matter.
  4. Jan 4, 2019 at 11:37 AM
    #8404
    KillerSeabass
    Seb
    San Fransisco, CA
    None yet
    Perfect thanks for the input!
  5. Jan 4, 2019 at 3:12 PM
    #8405
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    Now that you mention it, my pedal squeak is gone since I did the accumulator delete. Not sure if it's coincidence or what.
    tonered likes this.
  6. Jan 4, 2019 at 3:16 PM
    #8406
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Master cylinder can make noise if they have air bubbles in them. Bleeding might have helped with that?
    Has the weather been warmer there? It seems that we have more pedal noises when it is cold. Mine has started clicking while the truck warms up.
  7. Jan 4, 2019 at 3:19 PM
    #8407
    Trident904
    Brian
    17 4Runner TRD OR
    It's always warm in South Florida. Our winter was December 17th - 19th where it got in to the high 40's at night. I have noticed that the squeak is gone now.
    tonered[QUOTED] likes this.
  8. Jan 4, 2019 at 3:23 PM
    #8408
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Crap! I forgot where you where. Haha!
    Trident904[QUOTED] likes this.
  9. Jan 4, 2019 at 3:23 PM
    #8409
    Trident904
    Brian
    17 4Runner TRD OR
    I hate it here!
    pinochle and tonered[QUOTED] like this.
  10. Jan 4, 2019 at 3:25 PM
    #8410
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I hate it here!
    pinochle likes this.
  11. Jan 4, 2019 at 3:26 PM
    #8411
    Trident904
    Brian
    17 4Runner TRD OR
    I spent 8 weeks in Bremerton when I was active duty and I couldn't wait to get out of there!
  12. Jan 4, 2019 at 3:28 PM
    #8412
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Geez! It is nicer over there with less people. Too many douchey people in the Seattle-opolis.
  13. Jan 4, 2019 at 3:33 PM
    #8413
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    I have a dumb question about bleeding the clutch after the accumulator delete..
    Would it make any difference if I had the bleeder valve cracked slightly when I have my helper remove the clamp from the resevoir line up top?
    Maybe over thinking this, but perhaps if the air had somewhere to go until the fluid began to run out, maybe it would be a bit easier... dunno.
    I mean then I just close the valve and carry on with the rest of the process..
  14. Jan 4, 2019 at 3:36 PM
    #8414
    Trident904
    Brian
    17 4Runner TRD OR
    I did the gravity method when I did mine but didn't clamp the rubber line by the reservoir so I could drain all the fluid and refill with new fluid. Once I had the new line installed at the top (to the flex line) I filled the reservoir and let the line fill with fluid before connecting to the cylinder. I then topped off the reservoir and filled as my son worked the clutch pedal. Took maybe 3 or 4 pumps.
  15. Jan 4, 2019 at 3:37 PM
    #8415
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    There are dumb questions. That wasn't one?
    Even with my larger-ish clamp, it didn't completely close off the flow, which helped. I think.
    I was also in there for a long while modding that elbow and had no problems with air. You're gonna be in and out in minutes. I did connect the upper fitting first to allow it to fill, so there was very little air in there.
    Cracking the slave nipple won't hurt.
    Trident904 and MOC221_[QUOTED] like this.
  16. Jan 4, 2019 at 3:38 PM
    #8416
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    I don't think it will hurt. The big this is to be sure the valve is closed when the pedal is moving up.
    tonered and MOC221_[QUOTED] like this.
  17. Jan 4, 2019 at 3:38 PM
    #8417
    MOC221_
    Frank
    Right on, thanks :thumbsup:
  18. Jan 4, 2019 at 3:38 PM
    #8418
    MOC221_
    Frank
    Yessir, thank you!
    tonered likes this.
  19. Jan 4, 2019 at 3:39 PM
    #8419
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Too right! :smash:
  20. Jan 4, 2019 at 3:42 PM
    #8420
    MOC221_
    Frank
    Thanks for that as well :thumbsup:
Thread Status:
