2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Jan 8, 2019 at 11:58 AM
    #8461
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Send me yours i'll throw it in the Bridgeport with a ball endmill.... I've got an ultrasonic cleaner and an air gun should take care of everything.
  2. Jan 8, 2019 at 12:00 PM
    #8462
    kgautier
    kgautier Active Member
    2016 TRD OR 4X4 6MT
    Ironically I ordered a CNC Shopmaster mill in August but it hasn't got here yet. So I used a Dremel hahaha.
    MOC221_ likes this.
  3. Jan 8, 2019 at 12:01 PM
    #8463
    Shellshock
    Iowa
    I don’t think @mZiggy has done either yet. He can be the guinea pig
    pinochle, nxcess and kgautier like this.
  4. Jan 8, 2019 at 12:02 PM
    #8464
    lapoltba
    CT - 06076
    I bought a South Bend "fourteen" last year thinking I would have a ton of use for it. Seems like I should have gotten a mill instead. I haven't put the lathe to much use unfortunately and it just sits there looking sad.
  5. Jan 8, 2019 at 12:04 PM
    #8465
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Normally I would do this in a second (for scrience!), but my accumulator had corrosion that crept in past the metal disc on the back, and managed to get in under the rubber seal in a few places. I wasn't too gentle scraping around the edge and underneath, so I'm not even sure if it would seal properly, especially under pressure. It would most likely be problematic and I wouldn't want that to happen.
    You can see the ring of crap on my backing plate in the pics I posted over in the delete thread...
    tonered likes this.
  6. Jan 8, 2019 at 12:05 PM
    #8466
    lapoltba
    CT - 06076
    I did see that. Pretty ugly. Makes you wonder how long it would have taken to start leaking....
    MOC221_[QUOTED] likes this.
  7. Jan 8, 2019 at 12:06 PM
    #8467
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Nice! I will add that to the OP of the Delete thread.
    kgautier[QUOTED] likes this.
  8. Jan 8, 2019 at 12:12 PM
    #8468
    MOC221_
    Frank
    Yeah man, I'll post a pic of the accumulator body if I think of it tomorrow. Black crusty shit under the rubber seal, when I scraped it the stuff was white and powdery (like corroded aluminum). I had the same thought, a few more years and that thing might have started leaking.
    Now, no one freak out. I live in one of the worst rust belts around, so my scenario is probably worst case. Although I undercoat my truck every year (Rust Check), that spot is covered by the heat shield so no product got in there.
  9. Jan 8, 2019 at 12:15 PM
    #8469
    kgautier
    2016 TRD OR 4X4 6MT
    I wanted CNC and I needed both mill and lathe. I only have 770sq feet for my whole basement shop so this was my only option. Really excited for it to arrive!
    MOC221_ likes this.
  10. Jan 8, 2019 at 12:31 PM
    #8470
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    True, I haven't done either, but I also haven't cared to. :notsure: lol
    Honestly I've been barely following the developments of the ADM, so I don't actually know a whole lot about what to do either
  11. Jan 8, 2019 at 12:41 PM
    #8471
    mZiggy
    mZiggy Honey badger
    Marc
    I live in the desert. What is this "rust" you speak of? :D
    AFMurse2014, iexc and MOC221_[QUOTED] like this.
  12. Jan 8, 2019 at 1:25 PM
    #8472
    TD90S
    TD90S Cool as a cucumber in a bowl of hot sauce
    GA
    ‘18 TRDOR 6MT
    I talked about this early in the delete thread after making a line. It has been on my list of things to do. Keep getting distracted with other truck stuff. Pro suspension and alignment, MT-90 trans fluid. I’ll get there eventually.
  13. Jan 8, 2019 at 7:24 PM
    #8473
    KillerSeabass
    KillerSeabass Well-Known Member
    Seb
    San Fransisco, CA
    Stock taco getting a incentive over
    None yet
    Has anyone gotten a message saying "not enough resources" when trying to open the flash file for this tune?
  14. Jan 8, 2019 at 7:30 PM
    #8474
    kgautier
    2016 TRD OR 4X4 6MT
    That is your computer telling you it doesn't have enough RAM. You need to open your task manager and close all the applications that's taking up your RAM.
    20tacoma17 likes this.
  15. Jan 8, 2019 at 7:34 PM
    #8475
    KillerSeabass
    Seb
    San Fransisco, CA
    None yet
    That's what my suspicion was. I am a mac user, so I bought a brand new (super cheap) pc laptop for this purpose with 32 gb of memory and 4gb of ram. There is literally nothing else on the computer and nothing else running.
  16. Jan 8, 2019 at 7:40 PM
    #8476
    mZiggy
    mZiggy Honey badger
    Marc
    4GB should be murderous overkill for these OV programs. Try ensuring everything is closed out with Task Manager (Ctrl+alt+delete)
    And only 32gb of memory....like the hard drive? Not 320gb? 32 is tiny af
  17. Jan 8, 2019 at 7:41 PM
    #8477
    kgautier
    2016 TRD OR 4X4 6MT
    Win 10 is taking too much RAM idling prob. Disable Cortana and everything in the startup.
    If that's not enough you can create virtual memory using HD space. This guy explains it well:
    https://youtu.be/flpNUxvislo
    pinochle and mZiggy like this.
  18. Jan 8, 2019 at 7:49 PM
    #8478
    KillerSeabass
    Seb
    San Fransisco, CA
    None yet
    I appreciate the tips. Will give this a try.
  19. Jan 8, 2019 at 8:47 PM
    #8479
    KillerSeabass
    Seb
    San Fransisco, CA
    None yet
    For an update, the 32 gb of memory is basically only enough to run the computer's operating software. After deleting google chrome it is working with less issues. I am hoping that the OVTune program will continue running once I the flash files get downloaded, but TBD.
    hopefully this info helps someone in the future.
    kgautier and mZiggy like this.
  20. Jan 9, 2019 at 8:30 PM
    #8480
    kgautier
    2016 TRD OR 4X4 6MT
    Since 1.05 for manual is behind all of these complaining automatic people I thought I'd try to spark a debate.
    My guess is, since we are being patient, Matt may be willing to listen to our feedback.
    He mentioned a 7k rpm option of the tune. He says we are a 1 to 50 ratio to the auto. I personally want this version. If we all agreed maybe he could make the 7k rpm rev limit the default for 1.05 manual version. I think this would help us really start in the power at the beginning of 2nd :-D
    WalkinTaco, mZiggy and M1Awolf like this.
Thread Status:
