2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Jan 22, 2019 at 7:54 AM
    #9221
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    Ahh, I miss the late 90's. West Texas and a couple other states tested "no speed limit" or "speed limit within reason" in the barren parts of the state. This is how I learned that 177 mph was not within reason, at least according to the nice Texas DPS Officer who kindly showed me that his state issued Z28 was built as well and was in fact fast enough to catch up to me.
    inksin, iexc, disk_55FL and 3 others like this.
  2. Jan 22, 2019 at 8:17 AM
    #9222
    Reluctanse
    Reluctanse Granny shiftin, not double clutchin
    Sam
    Newberg, Oregon
    '17 Tacoma DCSB Inferno TRD OR 6MT
    OVTuned, Grabbers, 5100s, Bakflip VP
    Ok first 150 mile drive, and I will say the 91 tune is the most "natural" driving tune so far, which is exactly what I've wanted this whole time. I didn't get a lot of chances to really hoon it out, as it was dark and rainy, so I can't give a full report yet, but so far this is the best tune yet, as far as true accurate throttle responding the way it "should".
  3. Jan 22, 2019 at 8:20 AM
    #9223
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I gotta ask regarding the engine braking and increased throttle tables from the blog post, is there something to report here? Can you confirm a coasting throttle angle significantly lower that 15% to 17%?
    Thanks!
  4. Jan 22, 2019 at 8:57 AM
    #9224
    Reluctanse
    Sam
    Newberg, Oregon
    I can't say I noticed a significant change over 1.05 91 FO regarding this.... But it is definitely improved over stock. I also wasn't doing a lot of engine breaking this morning. I will give it some more attention on my way home this afternoon.
    The other improvement related to this I noticed is on 1.05 91 FO there was a rev bump at 1500rpm when decelerating or braking that was quite pronounced... That is compeletely gone.
    tonered[QUOTED] likes this.
  5. Jan 22, 2019 at 9:11 AM
    #9225
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks! :cheers:
    Regarding FO, that was part of my confusion regarding the throttle angle reported in Torque. I wasn't sure if it was the actual throttle plate angle or something related to faux-Atkinson. Either way IMVHO, too much air was flowing for good engine braking.
    I wasn't monitoring this for a while and never venture into the Alpha thread, 1.05 91 FO happened a while before the feature list for the current 1.05 was noted in the blog?
  6. Jan 22, 2019 at 9:18 AM
    #9226
    Trident904
    Brian
    17 4Runner TRD OR
    I was running the 93 FO tune until 1.06 released and I noticed at my last oil change my oil had a strong gas smell to it. I really liked the FO tune but I think it was running a bit rich as I would occasionally get a strong gas odor as I was idling at a light with a tail wind.
  7. Jan 22, 2019 at 9:25 AM
    #9227
    su.b.rat
    su.b.rat broken truck
    that's interesting. i noticed a strong smell a couple times myself on 93FO.
    Trident904[QUOTED] likes this.
  8. Jan 22, 2019 at 9:26 AM
    #9228
    Trident904
    Brian
    17 4Runner TRD OR
    Pull your oil cap and smell it.
    su.b.rat[QUOTED] and tonered like this.
  9. Jan 22, 2019 at 9:28 AM
    #9229
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks. That is interesting. In my (weak) mind, I would think that FO would work just like regular MPI with DFCO? Were you seeing the Current MPGs pegging out while coasting?
  10. Jan 22, 2019 at 9:30 AM
    #9230
    Trident904
    Brian
    17 4Runner TRD OR
    Yeah, they would peg out but any light throttle input would instantly drop the bar to about 7mpg until it settled.
  11. Jan 22, 2019 at 9:31 AM
    #9231
    Reluctanse
    Sam
    Newberg, Oregon
    Interdasting... the last oil analysis I had done mentioned a slightly higher than normal presence of fuel, but that would have been before the FO tune was out, would have been on the 1.03 87 tune. Curious if that might be tune related, or the nature of the DI engines?
    Regarding FO engine breaking, it was massively improved at least at low RPM over stock and the previous tunes, but maybe not as much mid to higher RPM, I haven't noticed much change at those ranges for engine braking.
    tonered likes this.
  12. Jan 22, 2019 at 9:37 AM
    #9232
    Trident904
    Brian
    17 4Runner TRD OR
    Not sure, but I always give my oil the sniff test to check for fuel smell. I learned the hard way when I blew a cylinder on a Cessna 182 I owned that had a slightly stuck injector. $22k to overhaul the engine.
    Shellshock and tonered like this.
  13. Jan 22, 2019 at 9:37 AM
    #9233
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It might be interesting to monitor commanded versus actual AFRs? I know that pre- and post-TSB / non-OVT during occasional monitoring, they were pretty much spot on unless coasting. Then, the actual AFR would spike as expected. We all know that for best power, a slightly rich setting is needed.
    DI is generally better at fuel control, so that by itself shouldn't be related to that problem unless it is squirting hard in some sort of cleaning cycle at shut down. There also, when just pulling the Taco into the garage from the driveway (30ft), I will get reported trip MPGs, so it can't be too bad?
  14. Jan 22, 2019 at 10:15 AM
    #9234
    GF8er
    GF8er Well-Known Member
    MT. Hood
    18 MGM DCSB TRD OR 6MT
    Any dongleless users received files yet?
  15. Jan 22, 2019 at 10:22 AM
    #9235
    Garab
    Garab Well-Known Member
    2018 TRD Sport MT6 DCSB
    OVtune 2.0 TRD Sema wheels 265/70/17 Falken Wildpeak AT/3 SL ADM BAKflip mx4
    Am I the only one who hasnt gotten their files yet?
  16. Jan 22, 2019 at 10:23 AM
    #9236
    Shellshock
    Iowa
    I haven't seen any dongle-less people say they've gotten theirs yet. Dongle users got them from the blog post.
  17. Jan 22, 2019 at 10:29 AM
    #9237
    ripdawwg
    ripdawwg Well-Known Member
    Oregon
    2003 Tacoma
    O3 Tacoma. Manual hubs Bilstein 5100 in OME 885 springs. Rear Wheeler off road 5 leaf springs. Northwest trails innovation winch bumper & 10k winch. TRD rear elocker and front 7.5 truetrac limiter slip. Built 2.7 3rz, balanced, 1mm bored, 9.75-1 compression, LC cam, 1mm oversized valves, LC 35 lb flywheel & LC clutch, ported head, balance shaft delete, bored throttle body, header & 2.5” exhaust.
    I asked and asked and asked yesterday. I have a 19 and I have not even got my registry files yet to ID the ecu.
    Has anyone with a 19 got thier registry files to communicate with the ecu??? Anyone?
  18. Jan 22, 2019 at 10:30 AM
    #9238
    Garab
    :annoyed::censored::frusty::goingcrazy::rant::smash:
    iexc likes this.
  19. Jan 22, 2019 at 10:41 AM
    #9239
    cylon58
    cylon58 Active Member
    Geoff
    East Tennessee
    2018 TRD Pro MT Black
    Not yet. Hopefully today though...
    :fingerscrossed:
  20. Jan 22, 2019 at 10:44 AM
    #9240
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    We do not work or send registries on the weekend or holidays.
    Pending reg files will be sent today if we get them back from our dev.
    Dongle-less files will also be sent out today as well ( as quickly as we can get them out ).
    2019 04B40 file specifically we are still working on for support.
Thread Status:
