2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Jan 22, 2019 at 11:10 AM
    #9241
    dc4e
    dc4e Active Member
    2019 TRD OR DCSB
    Gibson cat back Intake tube KN Cali raised grill LEDs Pro grill Step rail Popnlock tailgate 2x Kicker hideaways OV Tune (pending 2019 release)
    I have. I sent my ecu id back in early December.
    Garab likes this.
  2. Jan 22, 2019 at 2:39 PM
    #9242
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    @OVTune Mat if you have a version that was “too touchy” in 6th for say a 5000 lbs truck it might be spot on for a 5800+/- lb truck.
    2016trdtacoma likes this.
  3. Jan 22, 2019 at 3:38 PM
    #9243
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Actually we have already sent out 50%+ of all dongleless customers so far today
  4. Jan 22, 2019 at 3:44 PM
    #9244
    jjam
    jjam Active Member
    2018 TRD OR DCSB MT
    Can we assume the rest will be sent tomorrow?
    Hawkbill likes this.
  5. Jan 22, 2019 at 6:20 PM
    #9245
    TD90S
    TD90S Cool as a cucumber in a bowl of hot sauce
    GA
    ‘18 TRDOR 6MT
    This is a little concerning to me. Any notice of that with the other tunes?
    I wonder what measures OV is taking to make sure the fueling is correct?
  6. Jan 22, 2019 at 6:33 PM
    #9246
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    Only noticed it the one time. I’ve been on OVTune since 1.01 22k miles ago. This was the only oil change I noticed the fuel smell and I sniff test the oil every change. I’m going to change it again this weekend to give it a clean fill.
  7. Jan 22, 2019 at 6:54 PM
    #9247
    RedBeard1
    Red
    The dongle is great for the consumer for the simple fact that you can change the system you operate it on at will. My laptop crashed and I had to swap and other than a USB 3.0 issue it was seamless. I can understand why Mat swapped to the other setup for convenience. The dongle set up was probably taking up more of his time to get everyone set up. I feel he probably made the swap to streamline things on his end a bit.
    Melmantaco likes this.
  8. Jan 22, 2019 at 6:58 PM
    #9248
    OVTune
    OVTune
    Fueling is tightly controlled by closed loop fueling.
    Direct injection can create excess crankcase fuel vapors. A well regulated PVC takes care of it to a degree but get a PVC oil catch can setup to truly see how bad it is.
    It gets worse during winter where start up is open loop and more fuel is required, and piston wall gap is looser, resulting in more fuel getting past the rings.
    Ford actually has tables in the ecu setup to help minimize this on ecoboost during cold starts. Toyota...havent found such tables.
  9. Jan 22, 2019 at 6:59 PM
    #9249
    Trident904
    Brian
    17 4Runner TRD OR
    That makes sense. It’s been in the high 30’s and low 40’s here in the mornings.
    cylon58 likes this.
  10. Jan 22, 2019 at 7:21 PM
    #9250
    Shellshock
    Iowa
    Where do you live? The south pole?
  11. Jan 22, 2019 at 7:51 PM
    #9251
    orangeracer
    orangeracer Well-Known Member
    18' DCSB TRD OR 4x4 w/6spd MT
    Confirm this tune is called 1.06? That’s what it showed when I downloaded it.
  12. Jan 22, 2019 at 7:52 PM
    #9252
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Mat named the folder 1.06 to prevent confusion with the 1.05 v1. It's actually 1.05B and the individual files reflect that
  13. Jan 22, 2019 at 8:01 PM
    #9253
    orangeracer
    Thanks, its been several months since I flashed, so here goes nothing.
  14. Jan 22, 2019 at 8:20 PM
    #9254
    orangeracer
    It only shows the zip file, and it wont upload that. what part am I doing wrong?
  15. Jan 22, 2019 at 8:22 PM
    #9255
    GF8er
    GF8er Well-Known Member
    MT. Hood
    18 MGM DCSB TRD OR 6MT
    unzip it
  16. Jan 22, 2019 at 8:28 PM
    #9256
    orangeracer
    I'm a dummy, copy that. It's been unzipped and I dragged the individual files to the regular OVTune folder I have. Flash complete, just letting truck warm up for 15 minutes then its off to a test drive!
  17. Jan 22, 2019 at 8:29 PM
    #9257
    mZiggy
    mZiggy Honey badger
    Marc
    10 minutes is sufficient. We don't need a repeat of additional time being tagged on to the initial idle time for no reason. At one point people were recommending that people idle for 20-25mins
  18. Jan 22, 2019 at 8:30 PM
    #9258
    Shellshock
    Iowa
    ^this
    Truck also doesn’t need to be warmed up to flash.
  19. Jan 22, 2019 at 8:33 PM
    #9259
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Only cuz it's-40 in toba
  20. Jan 22, 2019 at 10:13 PM
    #9260
    Watch Surf
    Watch Surf Well-Known Member
    Kyle
    Honolulu
    16 TRD Sport 4x4 6M Silver Short-Bed
    VF Tuned ADM DS18 Tweeter swap Hella H9 headlamps Xenon Depot LED Headlamps in highs Morimoto LED Fog Replacements LED interior lights and plate lights Replaced all Toyota speakers with coaxials Meso Total Tails Stage I Plasti-Dipped rims, grille, emblems, and drink holder chrome. AVS window rims and wind deflector Toyota 2-Fold Truck Lid Spidertrax 1.25" spacers (black) Pool Noodle mod Rick's knurled delrin 6M shift knob
    Flashed my 2016 Sport MT for the first time this morning after an early morning email (Thanks Mat!).
    Unbelievably different than the stock 04B11 calibration. It delivers so much more of an engaging driving experience. Any speed, any rpm, any gear is possible with the engine's responsiveness to the throttle with 1.05B. Orange Virus is undoubtedly the best performance upgrade to the overcome the lackluster performance that Toyota delivered. I'm waiting to see if I'll get an MPG improvement, but that would just be the icing on my cake and make this the perfect upgrade on all fronts.
Thread Status:
