2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Jan 29, 2019 at 7:19 PM
    #9441
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    @filbert
    If you have the dongle version of the tune you can download the 1.05 files directly from here.
    https://www.ovtuned.com/blogs/news/1-05-update-details
  2. Jan 29, 2019 at 7:31 PM
    #9442
    filbert
    filbert Well-Known Member
    Chicago
    2016 Tacoma TRD OR DCSB V6 MT
  3. Jan 29, 2019 at 7:44 PM
    #9443
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    For the MT we now have table controls for:
    - All various idle RPM targets
    - Closed loop limit targets
    few other tables.
    working on solving DFCO. Along with modified patch.
  4. Jan 29, 2019 at 7:47 PM
    #9444
    Shellshock
    Iowa
    @iexc SOLVING DFCO!!!!!
  5. Jan 29, 2019 at 7:55 PM
    #9445
    M1Awolf
    Rob
    Montana
    IIRC the files for all ecu versions are there for both pre and post TSB ECU ID's,just look for your ECU version. The 04b13 file is for 16's and 17's that have had the TSB done.
    ETA I don't think you "have" to flash your ECU with the update as I think Mat incorporated a lot of the TSB benefits into 1.05, I am sure I will be corrected if I am wrong.
  6. Jan 29, 2019 at 8:53 PM
    #9446
    BearWithMe
    BearWithMe Well-Known Member
    Four Corners
    2025 OR 6MT Celestial Silver
    Prior: '18 OR 6MT
    @OVTune If I buy this tune right now, I'll have the "dongleless" version, right? I've previously used a handheld programmer (Cobb AccessPORT) on my other cars, but I have a Win10 laptop that I could use for this.
    So the current OVtune product uses a registry key in Windows to authenticate, or some other unique hardware ID like Ethernet MAC address? Is OVtune using their own flashing software (the tool, not the firmware image) or something off the shelf? Can I obtain and run any version of the OVtune firmware, or only the latest OVtune firmware?
  7. Jan 29, 2019 at 8:55 PM
    #9447
    Professional Asian
    Professional Asian Ridgeline Enthusiast
    Andrew
    Eureka, California
    2017 DCSB TRD off road MT [OVtuned]
    Yes, you'll be dongleless. You'll send Mat your system ID that pops up on the toy flash software, and he will send you a registry key.
  8. Jan 30, 2019 at 5:48 AM
    #9448
    OVTune
    OVTune
    Regarding DFCO, looks like the way it works is unorthodox, unlike other cars.
    There are fuel switch(es), Vehicle speed thresholds, and RPM trigger. not at all like other cars that use a full 2D mapping and other points.
    Regarding Rev Hang.
    I've found why you guys get the hang, and it's related to something else completely. Idle throttle feedback control.
    I won't post what RPM it triggers but.. it's adjustable.
  9. Jan 30, 2019 at 5:49 AM
    #9449
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Oh man, now you're moving past foreplay.
    DFCO - my guess WRT RPM - Injectors back on at ~1300 while decel; injectors off again when RPM reaches ~2500 while still fully off the gas pedal. That damn cycle drives me crazy when in 4low going down a steep decline in 1st gear. Feels like I just blew a few spark plugs out of the heads lol.
    Rev hang RPM trigger - let's see, maybe 8000??!!
    @iexc , where you at???
  10. Jan 30, 2019 at 6:13 AM
    #9450
    OVTune
    OVTune
    Sorry to ask again, but could anyone share with me again the 10k page service manual. There was a link floating around somewhere
    MOC221_ likes this.
  11. Jan 30, 2019 at 6:14 AM
    #9451
    Shellshock
    Iowa
    Any rpm is too high! I’m all for that shiz being gonezo
  12. Jan 30, 2019 at 6:15 AM
    #9452
    MOC221_
    Frank
    FtWayne Gen3, lapoltba and dc4e like this.
  13. Jan 30, 2019 at 6:17 AM
    #9453
    OVTune
    OVTune
  14. Jan 30, 2019 at 6:19 AM
    #9454
    Shellshock
    Iowa
    nxcess, mZiggy and MOC221_[QUOTED] like this.
  15. Jan 30, 2019 at 6:22 AM
    #9455
    MOC221_
    Frank
    @OVTune , with this new knowledge regarding DFCO - is there a way to make changes that affect it differently when in 4lo as compared to 4hi?
    The engine braking effect is way stronger when the injectors are off in 4low. There's also that tidbit you gave us regarding valve timing to improve engine braking....
    Damn, this is cool shit.
    mZiggy likes this.
  16. Jan 30, 2019 at 6:23 AM
    #9456
    MOC221_
    Frank
    You'd be surprised how many times I've linked it for people lol.
  17. Jan 30, 2019 at 6:24 AM
    #9457
    charlieyankee88
    charlieyankee88 Well-Known Member
    2017 TRD OR DCSB MT
    RADFLO Suspension, JBA HD UCAs, Mobtown low pro bumper, Mobtown bolt-on sliders, Engo SR10s, SCS Stealth 6, AFE CAI, URD Spec U, OV Tuned, Gobi Rack, Softopper, CMC
    Yes, to everything previously said about the mod and the new flash. Also, for the slow cold clutch issue I have heard more expensive or better dot 3 fluid may help. I can’t confirm but something pretty easy and cheap to try.
  18. Jan 30, 2019 at 6:24 AM
    #9458
    MOC221_
    Frank
    There's no such thing as good rev hang lol.
    20tacoma17 likes this.
  19. Jan 30, 2019 at 6:28 AM
    #9459
    OVTune
    OVTune
    No, because the DFCO is way too simple. Global switches with thresholds. Regardless of any external modes
  20. Jan 30, 2019 at 6:29 AM
    #9460
    MOC221_
    Frank
    Ah ok, thank you sir.
Thread Status:
