2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Feb 1, 2019 at 12:18 PM
    #9561
    iexc
    iexc WerXED BH2.0 AD
    Kalede
    Toronto
    2023 TRD Sport MT
    By eliminating rev hang you will save fuel so it should compensate for the elimination of DFCO.
  2. Feb 1, 2019 at 12:27 PM
    #9562
    BallsDeep09
    BallsDeep09 Well-Known Member
    '16 DCSB TRDOR 6 spd.
    Don't apologize for anything, ever
    Professional Asian likes this.
  3. Feb 1, 2019 at 12:29 PM
    #9563
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    TD90S likes this.
  4. Feb 1, 2019 at 12:54 PM
    #9564
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Dude, I know you want this really badly. IMO, if DFCO were to be eliminated completely there would have to be changes elsewhere to improve engine braking when the injectors are on (full lift). If you don't go off road, well I guess this wouldn't affect you quite so much. I did a little experiment quite a while ago, while going down a steep decline in 4low 1st gear. When the truck was holding back nicely and slowing down (above 1300 rpm, full lift), I cut the ignition... the engine braking stayed exactly the same (good) all the way down to just above idle. I then turned the ignition back to run, and immediately the truck began to accelerate until the RPM passed 2500. The cycle then repeated. It's annoying AF and possibly dangerous in sketchy situations.
    TD90S, iexc[QUOTED] and tonered like this.
  5. Feb 1, 2019 at 1:10 PM
    #9565
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    pinochle and tonered like this.
  6. Feb 1, 2019 at 2:08 PM
    #9566
    iexc
    Kalede
    Toronto
    2023 TRD Sport MT
    Is that a standard practice to shut down the engine? I never did any kind of 4/4ing.
  7. Feb 1, 2019 at 2:11 PM
    #9567
    M1Awolf
    Rob
    Montana
    No it isn't,he was just explaining how the engine should be braking while running. As soon as he turned the ignition on it started giving it gas,no bueno in the situation he was describing. The last thing you want when offroading is a runaway truck from no engine braking.
    MOC221_, TD90S and tonered like this.
  8. Feb 1, 2019 at 2:28 PM
    #9568
    Shellshock
    Iowa
  9. Feb 1, 2019 at 2:37 PM
    #9569
    M1Awolf
    Rob
    Montana
    On Monday we had about 4" since then temps have climbed and it all melted. We are supposed to get another 5"-8" this weekend
    ETA It is 50F right now:D
  10. Feb 1, 2019 at 3:55 PM
    #9570
    TD90S
    TD90S Cool as a cucumber in a bowl of hot sauce
    GA
    ‘18 TRDOR 6MT
    Are you tuned, what version?
    If so how is it in the same situation?
    MOC221_[QUOTED] likes this.
  11. Feb 1, 2019 at 3:59 PM
    #9571
    MOC221_
    Frank
    I am running 1.05B 91.
    TBH, I've not run 1.05b in the same exact off road situation yet. I can still feel the engine braking "letting go" in 2H at 1300 rpm though (ie slowing down in 2nd gear when fully lifted off the gas), and to the best of my knowledge Mat has not touched DFCO yet.
    TD90S[QUOTED] and tonered like this.
  12. Feb 1, 2019 at 6:48 PM
    #9572
    WalkinTaco
    WalkinTaco Well-Known Member
    2018 TRD OR M/T
    HECK YES. Eliminating rev hang and DFCO based on speed would be awesome.
    PS: Love how smooth the tune is (especially at low RPM compared to 1.04) and the tip in (i believe that is what is called) is greatly improved from 1.04.
    Edit: looking for engine braking not to suddenly disappear as truck is coming to a stoplight/traveling down a steep grade. Seems like there is some confusion about that.
    tonered likes this.
  13. Feb 1, 2019 at 9:22 PM
    #9573
    venezian
    venezian Well-Known Member
    Los Angeles
    2022 7545E
    Can anyone ELI5 DFCO?
  14. Feb 2, 2019 at 2:30 AM
    #9574
    Halibut
    Halibut Well-Known Member
    Alaska
    18 OR SB MT
    DFCO is deceleration fuel cutoff.
    Example - If you are going down a hill in gear, with foot off the gas pedal above a certain RPM, the injectors will shut off.
    That is DFCO. This is because the momentum of going downhill is turning the engine fast enough where gas is not needed. As you let off the gas while coasting, the ECU cuts power to the injectors. As long as the engine is above a certain RPM, the rotational energy of the engine powers the auxiliary components like power steering, alternator, etc, but no gas is being injected/burned.
    The complaints here stem from running the engine at low RPM, right at the threshold where the engine might start to stumble in some situations (1300?) To stave this off, the ECU adds fuel to keep the engine running smoothly. Once it adds fuel, RPM jumps, and sometimes passes the threshold, cuts fuel, and creates a herky jerky ride by cycling back and forth. In other situations, especially in 4lo it creates a surge that can be unnerving while you are trying to use fine throttle control.
  15. Feb 2, 2019 at 8:20 AM
    #9575
    venezian
    Los Angeles
    2022 7545E
    Thank you
    So that's what that is... So fucking annoying.
    lapoltba and iexc like this.
  16. Feb 2, 2019 at 1:39 PM
    #9576
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    @OVTune i will be in Harlan, KY March 7-13. I would be willing to roll through on Sunday the 10 and hang until the afternoon of the 12th before I have to head back to south Florida if you need a heavy MT on 4.88’s for some testing.
    PB FAB, JJ18ORDBSBMT, iexc and 4 others like this.
  17. Feb 3, 2019 at 2:02 PM
    #9577
    MOC221_
    Frank
    So, I'm going to assume the testing of 1.05 (patched) files is coming along well?
    Livinserene and iexc like this.
  18. Feb 3, 2019 at 6:15 PM
    #9578
    jewboi
    jewboi Well-Known Member
    Does anyone know how OVtuned would do with the new TSB thst just came out for manual transmissions?
    I have an appointment this week to have my blower motor recalls work complete and they said they’d re-flash for the new TSB as well. I want to buy OV tuned soon but am curious if it will just un-do that new TSB or if it works with it ?
  19. Feb 3, 2019 at 6:17 PM
    #9579
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    It will completely replace the TSB flash, but if Mat doesn't have that data he may be interested in having you read it out and send it to him. Regardless IMHO the tune is going to be better than any TSB Toyota is going to give you.
    su.b.rat likes this.
  20. Feb 3, 2019 at 6:18 PM
    #9580
    su.b.rat
    su.b.rat broken truck
    if i were you i would get the TSB, then get your OV. you can go either way, but for some they find they are good with the TSB alone.
    it also gave me a baseline to compare my experience stock and each phase of upgrading.
Thread Status:
