2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Feb 20, 2019 at 8:36 PM
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    Push the traction control button on the overhead console one time...
    Wixo likes this.
  2. Feb 20, 2019 at 8:43 PM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    FIFY
  3. Feb 20, 2019 at 9:03 PM
    kgautier
    kgautier Active Member
    2016 TRD OR 4X4 6MT
    It disengages auto LSD once you begin turing. That's definitely the best mode for drag racing though.
    Auto LSD sucks anyway. The last thing I want while trying to slide around is the axles to have brakes applied to them robbing power.
  4. Feb 20, 2019 at 9:09 PM
    Shellshock
    Iowa
    I miss the real LSD my 2005 had
  5. Feb 20, 2019 at 9:11 PM
    kgautier
    2016 TRD OR 4X4 6MT
    It can be done. 2nd gen axle is interchangeable. You can get 4.30 gearset and clutch type LSD from Yukon.
    I can't figure out how to do it for under $2k though. Blehhhhh
  6. Feb 20, 2019 at 9:23 PM
    RedBeard1
    Red
    Why not the axle from 3rd gen 2.7L/AT? 8” diff with 4.30:1 true trac is available for that configuration.
    kgautier[QUOTED] likes this.
  7. Feb 20, 2019 at 9:24 PM
    kgautier
    2016 TRD OR 4X4 6MT
    I had not been able to confirm if it's the same as a 2nd gen axle yet. Is it?
    Edit: Hmmmm it's looking like you are right. Really smart. I haven't found one under $1k yet though. The Duragrip is $600 and you need the $200 overhaul kit to install it. So it's still $2kishh. This saves $250ish and it'll be a newer axle so less worried about doing the wheel bearings.
  8. Feb 20, 2019 at 9:36 PM
    Roddy13
    Roddy13 Well-Known Member
    Mpg’s?
  9. Feb 20, 2019 at 9:39 PM
    kgautier
    2016 TRD OR 4X4 6MT
    Dude we're having a conversation about something way more important.
    Want good MPG? Don't push the gas pedal much. Gain speed down hills and bleed it up hills.
    This is the manual transmission group. I would imagine most of us are hammer down shifting at 6800 getting ~11mpg like me.
    M1Awolf and mZiggy like this.
  10. Feb 20, 2019 at 9:41 PM
    Roddy13
    Oh cool bro I had no idea. Racecar hey?!
    bigmw, tonered and Dubiousveracity like this.
  11. Feb 20, 2019 at 9:41 PM
    RedBeard1
    Red
    Yep 3rd gen NON TRD automatic transmission trucks use the pre Tacoma 8” Toyota third member in the rear axle. 1st and 2nd gen use the “8.4” rear axle which is still an 8” ring gear but the case has a stiffening frame on the back of it.
  12. Feb 20, 2019 at 9:43 PM
    Roddy13
    For anyone who isn’t all hammers down redline’z all that jazz ... how is the MPG’s on 87 FOB.
    bigmw likes this.
  13. Feb 20, 2019 at 9:43 PM
    kgautier
    2016 TRD OR 4X4 6MT
    Yep the Duragrip compatibility chart includes that axle now. Last time I checked I don't think it did.
    I also have to figure out how to defeat the codes it's gonna throw when I unhook the E-locker.
  14. Feb 20, 2019 at 9:47 PM
    RedBeard1
    Red
    4wd ECM from a sr,sr5,sport or limited?
  15. Feb 20, 2019 at 9:55 PM
    kgautier
    2016 TRD OR 4X4 6MT
    Think that plugs and plays? Would certainly be simple.
    I wonder what the used market is like for a E-locker and OR 4wd ecm.
  16. Feb 20, 2019 at 10:03 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Freaking stellar. I saw a 2mpg bump with 04B13. FOB 87 is looking like another 2mpg? I'm still early in it though.
    Junkhead and Roddy13[QUOTED] like this.
  17. Feb 20, 2019 at 10:08 PM
    RedBeard1
    Red
    Possibly would knowing Toyota.
    No idea. I personally would not pay over breaker price for one but that’s me.
  18. Feb 21, 2019 at 5:03 AM
    dbyker
    dbyker Well-Known Member
    Dave
    NE TN USA
    2018 Tacoma TRD Sport Access Cab V6 6MT 4x4 Inferno Red
    VF Tune, TRD Intake, TRD Cat-Back.
    This.
    And This.
  19. Feb 21, 2019 at 5:19 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Hey MT guys and gals. Curious, anyone with the tune, does 5th and 6th drive smoothly at low rpm cruising? Between 1000 and 2000 rpm, any shuttering?
    This issue is present even on brand new autos and I want to rule out the engine..
    Junkhead and Wixo like this.
  20. Feb 21, 2019 at 5:25 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    On 04B12, I had to stay above 2k in the higher gears. I could pull slight hills in 6th at 40.
    On 04B13, I got a small power bump and could slightly accelerate up those same hills in 6th at 35. About 1,500rpm.
    On FOB 87, 6th at 30 is pulling hard and smooth. 1,000rpm is a happy zone in the upper gears. When doing this, I am finding myself overshooting the speed that I want.
Thread Status:
