2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Feb 21, 2019 at 5:32 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    No shuddering that I've noticed, and I've been very low in the RPM range in 5th because the FOB tune pulls so well down low. Gotta be due to the auto tranny playing games.
    tonered likes this.
  2. Feb 21, 2019 at 5:33 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Same on FOB 91 for 04B13, you can drive at 30mph in 6th and maintain speed and accelerate without difficulty. No weirdness that I've noticed. The BFO test file was the same.
    On a side note, 2nd seems slightly held back in the 2200-2800 rpm range. If you're pulling hard in 1st and shift above that range, it goes like a scalded cat. If you get on it while in that range though, it seems to smoothly accelerate and then all of a sudden take off (below the 3500 kick). Yes guys, I know it's kinda low in the RPM band for these engines, but previous tunes would pull harder than this in that range. Not a complaint, just a note. Lol, I don't want to give up the low end in this file!
    Midrange is awesome on the highway though, effortless in 6th at 70. I was following this Grand Cherokee doing 90 the other day, for shits and giggles. No problem.
    Also, how is that single table file coming?
    Junkhead, nxcess and tonered[QUOTED] like this.
  3. Feb 21, 2019 at 5:52 AM
    Kclamer
    Kclamer Well-Known Member
    Konstantin
    2018 Toyota Tacoma TRD Off-Road 4x4
    2.5" lift, 4.88 gears
    Im sorry if this post is out of place but I have an auto 2018 and it was not nice to drive in low rpms even with 4.88 gears. After the latest 1.05 mpg 91 update it is really good. I have no problem cruising at 1k to 1.5k rpms. With the first release of 1.05 it was dead in thattrange and I had to jam the gas pedal to get the truck moving.
  4. Feb 21, 2019 at 6:02 AM
    Shellshock
    Iowa
    10-20% increase for me on the highway. Seeing 20+ with cold and winter fuel. I’d been 17-18 prior to 1.05FOB
    Roddy13[QUOTED], TD90S and tonered like this.
  5. Feb 21, 2019 at 6:05 AM
    Shellshock
    Iowa
    I haven’t noticed anything weird yet over 300ish miles. 1.05FOB 87. Truck seems very happy <2000 rpm, actually feels normal for once.
    tonered likes this.
  6. Feb 21, 2019 at 6:16 AM
    dbyker
    dbyker Well-Known Member
    Dave
    NE TN USA
    2018 Tacoma TRD Sport Access Cab V6 6MT 4x4 Inferno Red
    VF Tune, TRD Intake, TRD Cat-Back.
    Never noticed this problem running stock, 1.04 91 or 1.05B 93.
  7. Feb 21, 2019 at 7:41 AM
    Roddy13
    Roddy13 Well-Known Member
    Thanks, if this tune makes more low end power, improves driveability and improves my MPG's then I'm likely going to order it. 20% improvement the tune would pay for itself over time in fuel costs alone.
  8. Feb 21, 2019 at 7:43 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yep. At my pre-tune costs and MPGs, a 2mpg bump pays for it in about 5yrs. If fuel costs increase, then even faster.
  9. Feb 21, 2019 at 7:45 AM
    su.b.rat
    su.b.rat broken truck
    04B13, 2017 truck... smooth as silk at all rpms as far as i can tell.
  10. Feb 21, 2019 at 7:46 AM
    tacogravy
    tacogravy Well-Known Member
    Gravy
    Mantua, Ohio
    17 TRD OR 4x4 Quicksand 6MT
    TRD Pro Grill, TRD Sport Hood, BAMF Sliders, Bilstein 5100's F&B, BF Goodrich KO2 265/75R16, Old Man Emu 887 Front, Head Strong 3 Leaf AAL Rear (Overload Leaf Left In), OVTuned, De-Badged. Accumulator Delete Mod.
    None that I've noticed.
  11. Feb 21, 2019 at 8:08 AM
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    04B13 1.05 FOB 91 Smooth and running with mine even with all the extra weight hanging off of it. Patiently waiting for the single table Fat Kid tune.
    MOC221_ likes this.
  12. Feb 21, 2019 at 8:31 AM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Just tested this on my commute and didn't have any issues. Sounds like a slushbox problem lol
    Shellshock and nxcess like this.
  13. Feb 21, 2019 at 10:13 AM
    GF8er
    GF8er Well-Known Member
    MT. Hood
    18 MGM DCSB TRD OR 6MT
    On my to work in the morning while cruising around 70mph in 6th gear I get the bumpy road feeling/very faint stuttering. This happens in on a small grade (5-7%) with an outside temp of 35-40 degrees F. It has been present on every @OVTune I've run so far. (1.04, 1.04R. 1.05, 1.05 FOB all 91oct) I'm not sure if it did it on the stock tune or not. I haven't flashed back to stock to try.
  14. Feb 21, 2019 at 12:25 PM
    FtWayne Gen3
    FtWayne Gen3 Active Member
    Jon
    TRD PRO Skid Plate TRD PRO Wheels (4Runner) 265/70x17 BFG AT KO2
    No shuddering from my truck (2017, TRD, OR, 265/70x17 BFGs, 9500 miles)
    I would also like to add that I really like the FOB. Makes the truck more smooth and functional at lower RPM. Also makes the shift from 1->2 much more comfortable. I think there were some other posts that said you had not touched rev hang, but it certainly seems like it is reduced. Maybe it is indirectly impacted by the FOB, either way ---> GREAT PROGRESS!
  15. Feb 21, 2019 at 1:16 PM
    dbyker
    Dave
    NE TN USA
    Just flashed 93 FOB and drove 20 miles. Very impressed with the performance right out of the chute, know from experience it will improve even more with miles. Nice easy fairly linear tip-in, seemingly better power below 2-3K RPM, very fat (or is it phat) mid-range and high-end. Drives like it should have from the factory.
    Every iteration has gotten better - 1.04 91, 1.05 93 and now 93 FOB. Every flash went without a hitch, worked first time, truck started right up, ran better than before, and got better with more miles.
    The ONLY hitch I've encountered in three flashes is, I have to remember to temporarily disable my anti-virus/security software (Norton Internet Security) to allow the Flash Manager to run. Otherwise, it's all been good!
    Mat is on his game :)
    su.b.rat likes this.
  16. Feb 21, 2019 at 1:54 PM
    TB135k
    TB135k Well-Known Member
    Austin
    2018 TRD OR
    That could be something else, driveline vibrations, out of balance wheel, or even maybe the road is bumpy. Do you only notice it under power?
  17. Feb 21, 2019 at 2:04 PM
    GF8er
    MT. Hood
    yes, only under load and only when I'm climbing a slight grade. It's pretty obvious its coming from the engine. If I let off the gas slightly it goes away. If down shift to raise the RPM's its not present either.
  18. Feb 21, 2019 at 5:26 PM
    charlieyankee88
    charlieyankee88 Well-Known Member
    2017 TRD OR DCSB MT
    RADFLO Suspension, JBA HD UCAs, Mobtown low pro bumper, Mobtown bolt-on sliders, Engo SR10s, SCS Stealth 6, AFE CAI, URD Spec U, OV Tuned, Gobi Rack, Softopper, CMC
    Is anyone running 93 FOB with other aftermarket parts? I have AFE CAI and URD Spec u and was wondering how it is performing for others with similar mods. No issues on mine it runs great. Just curious.
  19. Feb 21, 2019 at 6:20 PM
    su.b.rat
    TRD CAI and a full custom free flow exhaust with rear cat removal. 93FBO. absolutely totally great.
  20. Feb 21, 2019 at 6:22 PM
    Shellshock
    Iowa
    Mine is up for highway cruising. A few hundred miles definitely helps.
    Melmantaco likes this.
Thread Status:
