2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Feb 23, 2019 at 6:43 PM
    CaptainVoodoo
    CaptainVoodoo Well-Known Member
    Charles
    Quebec
    2019 TRD Pro Voodoo Blue M/T
    None yet
    What issue are you having? I struggled too because of Visual C++ 2005 not installing properly, you might have the same problem. I figured it out after a couple hours and was able to flash on the side of the road lol
  2. Feb 23, 2019 at 6:52 PM
    AJSfab
    AJSfab Member
    2017 Tacoma TRD Sport 6MT
    OV Tuned
    During install, it was almost finished installing and I got a failure prompt. Now it won't let me try again.
  3. Feb 23, 2019 at 11:38 PM
    TB135k
    TB135k Well-Known Member
    Austin
    2018 TRD OR
    Try saving the file in a spot easy to access, like the desktop
  4. Feb 24, 2019 at 4:35 AM
    dbyker
    dbyker Well-Known Member
    Dave
    NE TN USA
    2018 Tacoma TRD Sport Access Cab V6 6MT 4x4 Inferno Red
    VF Tune, TRD Intake, TRD Cat-Back.
    Two Tips that might help with some issues:
    - Temporarily disable anti-virus/security software - Windows Defender, Norton Internet Security, etc.
    - Make a folder and organize all files in there - install file, Flash Manager, all tune files, documentation, etc.
    HTH, Dave
  5. Feb 24, 2019 at 4:54 AM
    dbyker
    Dave
    NE TN USA
    That's OK, the installation and Flash Manager put the files in their programmed location (C:\Users\Your User Name\Toyota Flash Manager) and run them from there by default, which should work fine.
    I'm just fussy and also like to copy all files to their own folder with all my other data, so I have them organized and know where they are in the future.
    I believe you can point Flash Manager to the tune files in either location, and flash from there.
    tonered likes this.
  6. Feb 24, 2019 at 5:04 AM
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    I have a 2016 that was manufactured Oct-2015. My calibration ID is 04B04 which was not listed in the software for 2016 but it was for 2017 so I used the 2017 04B04 tune. Is that okay?
  7. Feb 24, 2019 at 6:31 AM
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    I also had trouble locating the files right after I downloaded them. "the download location" in the pull down menu should take you right there but if it doesn't, try toggling the button in the lower right corner from "encrypted" to "all" then check the "download" file in you computer's directory tree
  8. Feb 24, 2019 at 7:00 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You got an AT. We be rowing here.
    I'm not sure how the AT ECUs were split?
  9. Feb 24, 2019 at 7:06 AM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    I had the same problem finding the files. It said they were saved in the "users" folder so I looked there to no avail. I had to go into C:\users/yourname...to find them not the "users" file in the quick access menu ;)
  10. Feb 24, 2019 at 7:08 AM
    M1Awolf
    Rob
    Montana
    I also had to do this before they showed.
  11. Feb 24, 2019 at 7:28 AM
    AJSfab
    AJSfab Member
    OV Tuned
    I went to shut down my computer last night, and there it was, Toyota flash manager, right on my home screen. But when I click on it, I get a "application was unable to start correctly", prompt.
    Edit- I did some research and got it sorted.
  12. Feb 24, 2019 at 7:32 AM
    Shellshock
    Iowa
    As long as you use the calibration ID that matches what’s on your truck you are all good.
    VangaSTL[QUOTED] and tonered like this.
  13. Feb 24, 2019 at 8:55 AM
    venezian
    venezian Well-Known Member
    Los Angeles
    2022 7545E
    It's hard reading all these comments.. i'm stuck driving a Ford Eco Sport while i'm working out of town... The driveability and throttle response is a hair worse than the stock Tacoma lol
  14. Feb 25, 2019 at 11:56 AM
    BearWithMe
    BearWithMe Well-Known Member
    2025 OR 6MT Celestial Silver
    Prior: '18 OR 6MT
    @OVTune Will you be developing a method for performing realtime reprogramming? That is, for modifying the ECU firmware image in the ECU's battery-backed DRAM rather than the flash RAM.
    Cobb offers this with their AccessPort to accomplish two things: 1) allow for on-the-fly (while driving) changes between maps and 2) allow for reflashing without using up the limited write-endurance of the ECU's flash RAM.
  15. Feb 25, 2019 at 11:59 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    This is extremely, extremely difficult code to do with this ecu. Cobb has some of the best RE engineers out there.
    Maybe if toyota uses the off the shelf SH725xx processor.. But they use a proprietary version of a discontinued brand of Renesas processor, that nobody in the world's has the documentation for except Renesas and toyota.
  16. Feb 25, 2019 at 12:07 PM
    BearWithMe
    Prior: '18 OR 6MT
    Thanks for the speedy reply! I can live with the lack of realtime flashing. :)
    I'm enjoying the tune so far. Got my fingers crossed for a reduction in rev-hang in the future.
    iexc and fatboyfirebass like this.
  17. Feb 26, 2019 at 2:39 PM
    OVTune
    OVTune
    Later this week there will be a test version for MT available (04B13 ECU), that would be worthy for heavy trucks to test.
    This is a file that is FOB + modified Acoustic valve control. Instead of the Intake Manifold valve kicking in at higher RPM, the tune will be modified to fully open the intake manifold at 1600 RPM low and 1800 RPM high.
    Totally optional.
  18. Feb 26, 2019 at 2:41 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    If an 87 tune, I'd be up for that? Of course, I'm light-weight but loving FOB 87.
    Rainman70, iexc and Shellshock like this.
  19. Feb 26, 2019 at 2:43 PM
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    Good deal I have been trying to figure out a way to have it fully open all the time without throwing codes. Truck feels so choked until it opens it is not funny. I have seriously thought about buying another intake to gut the valve out of and blank off the openings.
  20. Feb 26, 2019 at 2:46 PM
    OVTune
    OVTune
    Definitely helpful on trucks that need extra high load response at lower RPM. Instead of having the sudden surge after half way through the rpm band.
    I am still working on the custom patch for single torque table request. Will be a while before that's ready.
Thread Status:
