2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Mar 7, 2019 at 6:37 AM
    xxtavixx
    xxtavixx Well-Known Member
    Jacksonville fl
    2018 6MT
    ARB rear locker OVtune Mobtown sliders Core-shifter short throw Trd bro-phony grill Caliraised bumper light bar Caliraised ditch lights Rigid ignite back up lights FN Five Star 16x8 Et0 255/85/16 cooper st maxx MesoJDM fuse box cover MesoJDM led interior lights Bilstein 6112 fronts Bilstein 5100 rears Headstrong 3 aal Toytec 3* shims Mesjodm dome and map lights Diode dynamix ss3 pro yellow Mobtown aluminum front skid 2lo mod SOS front recovery point
    Thanks, and the 87/91/93 are OEM tunes? Thats the part that confuses me. I figured the FOB was FO.2 basically, but the base tunes are where I dont understand
  2. Mar 7, 2019 at 6:39 AM
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    No, the 87,91,92 are the MPG tunes. The OEM tune is the "Stock" choice. You would pick this instead of "1.05"
  3. Mar 7, 2019 at 6:41 AM
    xxtavixx
    Jacksonville fl
    2018 6MT
    Oooo and see I thought only the auto guys got the MPG tunes. How much improvement does the MT see with the mpg tunes? Anually I do a massive road trip, so that could be interesting.
  4. Mar 7, 2019 at 6:45 AM
    fatboyfirebass
    I went 87 FOB right out of the gate. I do 80 miles a day, Max speed is 55 MPH stock gears and tires. maybe 20 miles or so of that is going through a couple small towns. I am getting 20.8 to 21.1 right now on winter gas.
    TD90S likes this.
  5. Mar 7, 2019 at 6:54 AM
    xxtavixx
    Jacksonville fl
    2018 6MT
    We dont get winter gas down here, so I cant compare evenly. With cooper at3 265/75/16 at 65 and 3 guys and some gear I can do about 22mpg. Just me and some gear I can manage 23-24
  6. Mar 7, 2019 at 7:01 AM
    fatboyfirebass
    I am currently carrying 200 pounds of rock salt in the bed right now, (for weight and traction aid if needed), plus about another 100 pounds of assorted tools. The extra weight of salt or sand is just something we do up here, so I don't really even think about it any more when doing MPG comparisons, but I suppose I should at least mention it, for full disclosure.
  7. Mar 7, 2019 at 7:11 AM
    jewboi
    jewboi Well-Known Member
    I’d rather be able to work the clutch with heel toe movement than having to move my entire leg up and down which is what I’m doing now.
  8. Mar 7, 2019 at 7:14 AM
    jewboi
    I thought doing the rod free play adjustment was to fix this exact issue? My clutch grabs and releases way too high off the floor for my liking. Is rod free play adjustment a fix for this? Sorry I think I’m getting myself confused.
  9. Mar 7, 2019 at 7:28 AM
    xxtavixx
    Jacksonville fl
    2018 6MT
    I think you are correct here, and I believe there is also a spring that you can fiddle with
    MOC221_ likes this.
  10. Mar 7, 2019 at 7:30 AM
    jewboi
    Ok cool. I understand not wanting the release/grab bottoming out the floorboard, but I don’t know how anyone would ever WANT it closer to the top. My left leg has to do some serious work in stop and go traffic the way it is now lol
    MOC221_ likes this.
  11. Mar 7, 2019 at 8:45 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Just to be clear, if you follow the procedure in the SM with respect to clutch rod free play adjustment, you're not going to move the release point away from the top all that much. If anything, you'll create a "gap" between the pedal assy and the rod. You'll see when you get under there and fiddle with the lock nut and rod. All I'm saying is that for those ppl thinking you can adjust this thing to where you want it - well you can't really. It's still going to be quite near the top of the stroke. When I adjusted out the "click" in my clutch, it moved the release point a bit closer to the top, actually. I did the adjustment within spec, to ensure the clutch was not being partially disengaged when the pedal was fully released.
  12. Mar 7, 2019 at 8:46 AM
    MOC221_
    Frank
    Not really. There's no adjustment in the spring. You either leave it in place or take it out if you really want to. Or mash some grease into it, to try and destroy the barn door creak!
  13. Mar 7, 2019 at 11:19 AM
    Loqu!to
    Loqu!to Somewhat skilled Rookie
    North VA
    2018 Tacoma TRD Sport MT OVTune
    MBRP Dual 409 SS Exhaust, many exterior mods.
    Very skinny. 125 pounds
  14. Mar 7, 2019 at 11:22 AM
    Loqu!to
    North VA
    I would be willing to help mat with dynos. Since I pretty much have a stock car with 91 FOB tune. I could flash it to stock, dyno it, then flash the tune to see differences. Stock tires, engine, transmission, etc. Just some little more weight from side steps
    Steelhead Taco and M1Awolf like this.
  15. Mar 7, 2019 at 11:25 AM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    Thanks for offering,hopefully @OVTune will take you up on it.
  16. Mar 7, 2019 at 12:41 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I was playing the fat kid today. 420lb in the bed (300lb of foam and 120lb of sand):
    This is for the run from Tacoma to Arlington with the load in some stop and go traffic:
    So far, only one full tank (407mi) on 87 FOB that calculated to 19.5mpg.
  17. Mar 7, 2019 at 12:45 PM
    CaptainVoodoo
    CaptainVoodoo Well-Known Member
    Charles
    Quebec
    2019 TRD Pro Voodoo Blue M/T
    None yet
    I think there's no correct answer here, I was taught to always fully depress the clutch, so it makes more sense for me to have the grab point closer to the floor. I guess you were told to only depress as much as you need it, so I was either taught wrongly and need to adapt my driving now or both are good way to operate a clutch lol
    jewboi likes this.
  18. Mar 7, 2019 at 12:54 PM
    Kamille.bidan
    Kamille.bidan Well-Known Member
    2017 Blue TRD OR MT
    That sounds too good to be true
  19. Mar 7, 2019 at 12:54 PM
    xxtavixx
    Jacksonville fl
    2018 6MT
    Depressing the clutch all the way is the safest, there is no question there. Anything past that is driver preference. I like my clutch to engage about half way in trucks and Zin cars I want it right off the floor
  20. Mar 7, 2019 at 2:50 PM
    Shellshock
    Iowa
    300 miles today at 70 mph averaging 20-21 mpg on FOB with 87e0 winter fuel. Way better than the 17-18 on any previous tune.
    2001 4x4 and tonered like this.
Thread Status:
